How to turn off the internet without disconnecting the network
diabeel 30261 8
  • #1 15412492
    diabeel
    Rate: 119
    I have question for you. Is it possible to turn off Internet access on Windows 8.1 without turning off the Wifi network and how?
    My point is to completely disconnect the net by some command on the computer, but so that the internal Wifi network works.
  • #2 15412698
    Epic
    Level 30  
    Help: 147
    Rate: 108
    Do you mean completely disconnecting the computer from the network, without shutting down the network itself? The easiest way is to disable the network card in the computer.
    Do you mean disconnecting the computer only from Internet access so that it simultaneously has access to resources in the LAN?
    If so, then there are many methods, on the PC itself you can create appropriate rules in the firewall blocking everything from outside your subnet, for example 192.168.1.x .. Or you can also, depending on the router you use (and you did not specify the model) and block it on it computer access to the Internet.
  • #3 15458421
    diabeel
    Rate: 119
    I mean quickly disabling the Internet from a given computer, but without disconnecting it from the LAN / WIFI network - preferably with a command.
  • #4 15459308
    Epic
    Level 30  
    Help: 147
    Rate: 108
    Ok, you want to do it e.g. on the router (if so, enter the model) or directly on the computer.
    You have several methods on your computer, apart from creating rules in the firewall which I wrote about, which is the most reliable method, you can also:
    -Use the parental controls built into the system, it has options to restrict internet access
    -Changing network card settings (bad default gateway will prevent connection to external network)
    When it comes to accessing sites only, setting a non-existent proxy will also work.
  • #5 15459401
  • #6 15460568
    pioflo
    Help: 26
    Rate: 27
    Removing the gates is the best way.
    If your internal network needs to pass through a gateway, you can also remove DNSes. Then the internet will be, but no website will start.
  • #7 15588690
    diabeel
    Rate: 119
    [quote = "jurek.adam"]
    diabeel wrote:
    you cut off the internet with the command to remove the internet gateway.
    What does the command for turning the internet on and off look like?
The discussion centers on methods to disable Internet access on a Windows 8.1 computer while maintaining connectivity to the local Wi-Fi network. Users suggest various approaches, including disabling the network card, creating firewall rules to block external access, utilizing parental controls, changing network card settings to set a bad default gateway, and removing DNS settings. Commands such as "route del" are mentioned for cutting off Internet access. The conversation emphasizes the need for quick solutions that do not disrupt local network resources.
