Toyota Avensis 2010 2.0 Diesel - DENSO Piezo Injection System Not Starting, P1604 & P062D Errors
akamix21 16263 4
  • Unplugging all injectors causes no ECU errors or response
    #1 16170178
    akamix21
    Rate: 70
    Hello!
    Toyota Avensis 2010 patient. 2.0 diesel, DENSO injection system (piezo injection)
    Malfunction: turns does not start.
    Mistakes:
    P1604 - start control, incorrect operation
    Sometimes there is an error p062D- injector - current circuit A
    The injectors have been replaced and it still does not smoke. The pressure on the bar is there, the speed can be seen, immo OK,
    The question here is how to fire it? :D
    Thanks for the facts.
    By the way, I unpin all plugs from injections and no reaction - 0 errors
  • #2 16170477
    Bunny82
    Help: 15
    Rate: 242
    Maybe the capacitor in the computer is dead
  • #3 16170875
    akamix21
    Rate: 70
    will not see the injections because of it?
  • #4 16171285
    Mateusz1560
    Rate: 187
    Ie. how does it not see injections? If there is a signal to the driver on pin B43 while turning the starter, it is most likely the engine driver to be replaced. The error from the injector will be related to the fault of the engine controller itself.
  • #5 16172750
    akamix21
    Rate: 70
    Problem solved. The injection made a short circuit (no errors), and secondly, the DPF was completely clogged. subject to close.
