[Other] how to tighten the power steering pump belt on a Volkswagen sharan 2006
zenonwujkow 10509 10
How do I tighten the power steering pump belt on a 2006 Volkswagen Sharan, and can it be done without a lift or pit?
Loosen the two 13 mm bolts on the pump, then turn the toothed adjusting screw/nut to move the pump and tension the belt; after setting the tension, tighten the 13 mm bolts again [#17084118] If your pump does not have the toothed nut, it was likely removed previously, and there is also a 13 mm bolt at the back of the pump that must be loosened [#17084118] If the pump will not move because it is seized or corroded, use a solid tube/lever between the pump and the bracket/bowl and push the pump away hard enough to shift it [#17086200] A video example of the same pump on a Golf was linked as a visual guide [#17085911] The original poster later confirmed that applying a bit more force made it work [#17086742]
  • Clarifying belt tensioner hardware and access needs
    #1 17083884
    zenonwujkow
    Level 4  
    Rate: 64
    I am asking for help with tensioning the power steering pump belt.
    There is a screw 13 (there are teeth near the screw hole). I saw on the net that this screw 13 should have a nut with teeth on it - probably 22 (mine does not have it). I don't know if my model should have such a nut to adjust the tension.
    Please provide step-by-step instructions on how to stretch the strap (unfortunately I do not have access to the channel) - is it possible without a channel.
  • Power steering belt tension adjusted by toothed screw
    #2 17084118
    pdemski
    Help: 36
    Rate: 71
    The screw 13 is only for countering the larger with teeth. Loosen the 13th and now turning the one with the teeth (I don't remember its size) you will see whether the belt is stretching or loosening - depending on whether you are turning right or left. After stretching, you counter 13 and village.
    Added after 5 [minutes]:
    If you don't have that nut with teeth, someone has dumped it before. In Sharan I have two passats before and there were also these nuts.
    I forgot to add that from the back of the pump there is another 13 screw that should be loosened.
  • #3 17084841
    zenonwujkow
    Level 4  
    Rate: 64
    I'm sorry I wrote the year 2006 by mistake, my sharan is 2000.
    Does anything change what I wrote
    Added after 8 [minutes]:
    And one more thing - which second screw 13 is about - because on the right side of the screw with teeth there are two screws 13 - is there any other screw (because you write that on the back of the pump - please describe exactly where it is) - -thanks
  • #5 17086120
    zenonwujkow
    Level 4  
    Rate: 64
    I've seen this video before but unfortunately after loosening the screws like in the movie, the pump will not vibrate. That's why I asked if maybe some other screw still holds it.
  • #6 17086200
    pdemski
    Help: 36
    Rate: 71
    To adjust the belt there are only these two 13s, apparently you have everything tarnished and therefore you cannot move the pump. you have to put a decent "lag" (tube) between the pump and the bowl and push the pump properly away from the bowl.
  • #7 17086378
    zenonwujkow
    Level 4  
    Rate: 64
    Ok thanks - I'll try
    pdemski
    Help: 36
    Rate: 71
    Let me know how it went. Greetings.
  • #9 17086742
    zenonwujkow
    Level 4  
    Rate: 64
    Approx. you were right - I used a little more strength and everything is ok - thanks.
    Now I'm struggling with the lack of backlight of the dashboard and license plate lighting - the bulbs I have checked are ok - maybe you have some idea where the reason may be - is the lighting of the board and the board passing through the fuse - because initially I checked the fuses and it seems ok.
  • #10 17086775
    pdemski
    Help: 36
    Rate: 71
    I don't know that because in my shark the backlight has not yet been repaired, as for the license plate, look for cracked wires in the wiring harness that goes into the tailgate, if you open the tailgate, the wires are in this rubber at the top right. A common ailment in these cars. I already did it two years ago but I have to look there again because it is failing me again.
  • #11 17087454
    zenonwujkow
    Level 4  
    Rate: 64
    In fact, I noticed that this bundle is slightly battered to put it mildly. I will look at it tomorrow. Thanks
The discussion revolves around tightening the power steering pump belt on a 2000 Volkswagen Sharan. The user initially inquired about the adjustment process, specifically regarding a screw labeled "13" and the absence of a nut with teeth for tensioning. Responses clarified that the screw "13" is used to counter another screw with teeth, which adjusts the belt tension. It was noted that if the nut is missing, it may have been removed previously. Users suggested using a lever to apply force to the pump for proper adjustment. After some trial and error, the user successfully tightened the belt. The conversation later shifted to troubleshooting dashboard and license plate lighting issues, with advice on checking wiring harnesses for damage.
