[Solved] Privileg-DeLonghi Esperienza EAM 3000 B: Descaling Program Indicator Light Issues
hurtovnik32 74447 16
Why does the descaling light keep blinking on a Privileg-DeLonghi Esperienza EAM 3000 B after running the automatic descaling program, and how do I stop it?
The blinking usually means the descaling cycle was not completed correctly or the water hardness setting is wrong, so repeat the procedure with the proper descaling fluid and then reset the hardness setting if needed [#7722153] [#16834541] [#17103687] Start the machine, wait until the coffee lights stop flashing, then hold the descaling button for at least 5 seconds until the descaling light stays on continuously; on some units you may need to press the button more firmly [#9500928] [#12649272] Use about 125 ml of De'Longhi descaling liquid mixed with 1 liter of water in the tank, then run the descaling through the steam nozzle/valve as described in the manual [#7861363] During the rinse phase, do not stop the process when the machine shows 'no water'; add fresh water and continue rinsing [#18250194] If the machine seems to do nothing after the light stays on, wait, because the descaling process can still be running even when the coffee lights are off [#16491908]
  • #1 7722056
    hurtovnik32
    Help: 35
    Rate: 219
    I have a problem with the Privileg-DeLonghi Esperienza EAM 3000 B machine, namely the machine has an automatic descaling program. After pressing this function, everything seems to work, but the indicator light is blinking all the time. I repeated this operation several times, unfortunately to no avail. Besides, other functions work. I do not have a manual for the coffee machine, so if someone had it, I would be grateful for help.
  • #2 7722153
    kosmik903
    Help: 13
    Rate: 29
    manual in English.
    As for descaling, it is described on page 32, point 10.3 of the manual
    You need to use a special descaling fluid.
    • EAM_series.pdf (1.54 MB) You must be logged in to download this attachment.
  • #3 7861363
    e_dytko
    Rate: 17
    I have a different model, but it probably looks similar.
    The red light flashes when descaling is required. You can still make jackdaws then, but remember to descale it soon.
    125 ml of delongi descaling liquid is poured into the tank, then a liter of water is added to the tank and the tank is installed. We turn on the coffee machine. When it is ready to make coffee, hold down the descaling button for a moment. Then the indicator light is constantly red and the machine starts to do its job. The green lights for the quantity of coffee go out. Now we have to place the condensate container under the steam nozzle and unscrew the valve from the nozzle and ... we wait until the machine lets us know that there is no water, which takes some time. Then we turn off the nozzle, pour out what we have in the container with water, rinse the container, pour clean water and install it in place. Again, place something under the steam nozzle and unscrew the valve. The water now rinses the descaling agent residue. When the coffee machine info appears again that there is no water, turn the nozzle off, pour fresh water, and we can simply make coffee.
  • #4 9500928
    tomal_
    Rate: 58
    I have a similar problem with descaling.
    After turning on the machine, the red light flashes constantly, informing you that the machine needs descaling. Proceeding according to the instructions: after turning on the machine, when the coffee lights stop flashing, hold down the descaling button for at least 5 seconds - then it should stop flashing and stay on continuously - then the cleaning process begins.
    I cannot start descaling for me. The lamp flashes all the time .....
    has anyone had a similar problem, or knows the solution?
  • #5 10918581
    mrobar2
    Rate: 73
    Hello, I have a similar problem, namely I did everything (I think) as written in the manual, but the lamp continues to flash that I need to decalcify and I do not know whether the whole cycle should be repeated or not to worry about this situation, please, enlightened in this topic for an answer, best regards
    and let me just add that for now he normally makes coffee for me, but for how long ???
  • #6 12649272
    tomal_
    Rate: 58
    some time after pressing the button more firmly ... the light stopped flashing and the descaling process started.
  • #7 16234076
    radeks1968
    Rate: 420
    For me, the problem is that after turning on the power, all the controls light up, then they go out, the engine starts left right flickering relays and everything goes out. Any suggestions?
  • #8 16474800
    makowsk
    Rate: 28
    In my coffee machine, after completing the descaling procedure:
    The 1st decanting lamp stops flashing
    2. the cup / 2 cups lights are off
    3rd descaling light is on permanently (according to inst, descaling mode is activated)
    4. Further silence nothing happens
  • #9 16475679
    radeks1968
    Rate: 420
    I have the same and I do not know whether the descaling cycle was badly completed or another problem
  • #10 16491908
    dadus18
    Rate: 95
    For me, the same problem, the world of descaling light and silence, I am asking for help.
    Added after 9 [hours] 39 [minutes]:
    The problem is solved, you have to wait, the coffee lights are not on as described in the manual, but the descaling process is working. greetings
  • #11 16515364
    ankach88
    Rate: 85
    Hello, I have a problem with the delonghi magnifica s coffee machine. After descaling the machine, the red light is still flashing. What to do to stop flashing?
  • #12 16834541
    jadwigapi
    Rate: 30
    I had the same problem.
    It helped to set the water hardness according to the instructions, which hardly anyone remembers.
  • #13 17103687
    AP1973
    Rate: 17
    I confirm that descaling several times did not help, it continued to flash, I changed the water hardness from 4 to 2 and the indicator light went out, the problem disappeared
  • #14 17104219
    radeks1968
    Rate: 420
    As for the change of the hardness scale, it also works for them
    The harder the water, the faster the descaling process takes place, and the less hard the water, the more time it takes. Please remember that frothing the milk is like making 3 coffees
  • #16 18250194
    lukiiiii
    Help: 82
    Rate: 392
    I had it today too. That's why I came across this thread.
    In the rinsing phase, when "no water" appears, we do not finish the process, but add water. After such a long rinsing, the red diode went out again.
  • #17 18280494
    hurtovnik32
    Help: 35
    Rate: 219
    The topic is quite old, so I close it.
The discussion revolves around issues with the descaling program indicator light on the Privileg-DeLonghi Esperienza EAM 3000 B coffee machine. Users report that despite following descaling procedures, the indicator light continues to blink, signaling a need for descaling. Several solutions are suggested, including using the correct descaling fluid, ensuring the water hardness setting is appropriate, and confirming that the descaling process is completed properly. Some users found success by adjusting the water hardness setting or by simply waiting for the machine to complete the descaling cycle, even if the indicator light remained on initially. The importance of following the manual's instructions for descaling is emphasized, and users express a need for the manual itself.
