[Solved] TV Sony KDL-40R450B: Backlight Repair, Strip Replacement & Matrix Image Issues
Wiesław.K. 9597 9
  • #1 17081976
    Wiesław.K.
    Help: 6
    Rate: 64
    In this TV, the replacement of the strips will only give them new ones in the matrix, and there will be no image anyway. :D
  • #2 17082207
    max300
    Rate: 22
    And you can brighter, buddy? So far, the picture is there, but from time to time it does not want to connect to the error 6. 2 diodes are damaged in one of the 5 circuits with 10 diodes each. I assumed that this is why error 6 is.
  • #3 17083438
    Wiesław.K.
    Help: 6
    Rate: 64
    Yes. For this reason, and also because this invention has an error buffer like in old sharpas. It will get full and replacing the led bars is not enough :D
  • #4 17083453
    max300
    Rate: 22
    So the question is how do I clear this buffer? If it's not "full" yet and it will light up through the service menu? And if it doesn't light up anymore, how?
  • #5 17093046
    altonserwis
    Rate: 35
    Hello, I'm joining the topic, I have exactly this TV on the table with exactly this fault.
    Could someone confirm the theory of colleague Wiesław about the error buffer?
    Even the Sony service center does not mention anything about it, moreover, they write in it to replace only a single strip of LEDs :)
    Best regards.
    FHU ELEKTRONIKA
    Targowa 4, Rzeszów, 35-064
  • #6 17093107
    max300
    Rate: 22
    As I wrote, the TV before the replacement worked only sometimes it did not want to surprise with the error 6. After replacing the TV strip, the TV starts 100/100 and works. The error counter shows 054.
    The method given by Col. Wiesław to reset does not work for me.
  • #7 17093168
    altonserwis
    Rate: 35
    Could you post a way to reset errors here?
    FHU ELEKTRONIKA
  • #8 17275494
    Cobra
    Help: 6
    Rate: 64
    Problem solved ?? I am struggling with the same problem.
  • #9 17275512
    altonserwis
    Rate: 35
    Hello, I bought two slats:
    Link
    The TV got up right away, it works until now.
    FHU ELEKTRONIKA
  • #10 17726543
    Wiesław.K.
    Help: 6
    Rate: 64
    To delete errors, you need to enter the service mode "info, 5.v +, power" and in errors of lamps on the remote control press 8888 or 0000. If after replacing the led bars it is ok, that is, the error buffer is not yet fully loaded.
✨ The discussion revolves around issues with the Sony KDL-40R450B TV, specifically related to backlight repair, LED strip replacement, and image problems. Users report that replacing the LED strips may not resolve the issue due to an error buffer that can fill up, leading to persistent error codes. One user mentions that after replacing the LED strips, the TV worked but still showed an error count. Another user seeks methods to clear the error buffer, with a solution provided to access service mode and reset errors using specific remote control commands. Overall, the consensus is that simply replacing the LED strips may not be sufficient if the error buffer is full.
