Peugeot 407 SW Display - Replacing the display from orange to yellow none
RADQ 11217 5
  • #1 17099793
    RADQ
    Level 19  
    Help: 7
    I wanted to replace the display, because on the old (orange JCE-EMF-C-ORA_CEMO) it is already very difficult to see.
    I bought an original LCD, but from a younger year - yellow (JCE-EMF-C-AB_CEMO)
    After installation, it turned out that I do not have an air conditioning function. The "CLIM" button on the radio has no reaction. It works normally on the old one.
    Do these displays have a different pinout and can it be changed ?? do I have to look for an orange LCD ??
    best regards:
    Radek
  • #2 17099874
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1710
    Code the klime to the display and after work.
  • #3 17138939
    Majorek85
    Hello. I have a standard problem with the orange display ... now my question is whether it is possible to connect the display from c5 mkI colored (large) code EMFD-VDO-01. Will it not make some short circuit ??
  • #4 17140420
    zi.ko
    Help: 86
    Rate: 337
    The EMFD-VDO-01 screen has never been mounted on the P407. This screen is from RT2 system and not CAN compatible.
  • #5 17141498
    Majorek85
    Thanks a lot. It is from rt2 ... it was left after the old car, and the cube and pins match, that's why I asked. Ok thanks again.
  • #6 17566145
    DejayPablo
    Rate: 82
    How to do it in PP2000? Do I need a code to code the display for the air conditioning to start showing?
    best regards
