Connecting a 12-PIN Display to a 6-PIN System in a 2004 Peugeot 307: Wiring Guide
lukasz726 11472 4
  • #1 17371972
    lukasz726
    Help: 61
    Rate: 59
    I have a display in a peugeot 307 from 2004. for 6 PIN. Unfortunately fired. I can't find one anywhere. All that is 12 PIN. Is there an option to connect this to 12 pins. If so, where to connect to the 12 PIN cube with the wires. A photo of my display is attached.
    • Connecting a 12-PIN Display to a 6-PIN System in a 2004 Peugeot 307: Wiring Guide IMG_20180806_184524.jpg (420.26 KB) You must be logged in to download this attachment.
    • Connecting a 12-PIN Display to a 6-PIN System in a 2004 Peugeot 307: Wiring Guide IMG_20180806_184539.jpg (390.14 KB) You must be logged in to download this attachment.
    • Connecting a 12-PIN Display to a 6-PIN System in a 2004 Peugeot 307: Wiring Guide IMG_20180806_184550.jpg (424.58 KB) You must be logged in to download this attachment.
  • #2 17372115
  • #3 17372136
    lukasz726
    Help: 61
    Rate: 59
    Is it enough to replace the radio with display from another car with a 12 PIN connection and it should work?
  • #4 17372161
  • #5 17372195
    lukasz726
    Help: 61
    Rate: 59
    One more question. I found a 12 pin display with different markings. Namely 9662385980. It looks from the outside that it has the same two straps as mine. I have two 60 PINs soldered to the board. Can anyone check if the displays are the same? Then I solder myself to my electronics and the problem is solved. My display is Magneti Marelli for two 60-pin tapes each.
