[Solved] Seat ALTEA XL - Tailgate Boot Lock Issue: Doesn't Open, Handle Clicks, Bolt Doesn't React
bioton1987 11175 1
  • #1 17100814
    bioton1987
    Rate: 19
    I have a problem with the boot lid lock in the Altea seat. First, the problem was that after pressing the trunk handle, you had to quickly and vigorously lift the hatch to open it. Otherwise, it was jammed and you had to push it downwards to make it jump into place and open again. Today I got to the lock and when I press it, I hear such clicks, rather everything is fine there. But now, after pressing the trunk handle, the lock bolt does not react at all. When dry, the lock works, the bolt bounces but after connecting everything, pressing the handle does not react to the bolt. Where could the problem be?
  • #2 17107277
    bioton1987
    Rate: 19
    Problem solved. The lower lock was out of order. After replacement, everything works as it should :)
