Seat Ibiza 6L: Passenger Front Door Blocked - Central Locking & Outer Handle Issues (Endriu)
AndM 45699 7
  • #1 16236602
    AndM
    Rate: 93
    The right front door can not be opened in any way after closing. The car is equipped with a factory central locking. The outer handle has no key insert, but the thread does not give the handle a handle from the center of the vehicle. The door panels can not be removed because the screws are only accessible after opening.
    Regards, I am asking for advice.
    Endriu.
  • #2 16236676
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Can you indicate where the screws are available after opening the door?
    Seat Ibiza 6L: Passenger Front Door Blocked - Central Locking & Outer Handle Issues (Endriu) Seat Ibiza 6L: Passenger Front Door Blocked - Central Locking & Outer Handle Issues (Endriu)
    You have to dismount the chair and no problem.
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
  • #3 16236827
    AndM
    Rate: 93
    Welcome back.
    The screws are at the bottom and hidden door at the door.
    Added after 10 [minutes]:
    Hello. Seat Ibiza 6L: Passenger Front Door Blocked - Central Locking & Outer Handle Issues (Endriu)
  • #4 16236859
    CameR
    Help: 1139
    Rate: 3272
    After dismounting the chair is access.
    You can always break free.
    Used upholstery is about 50 PLN, so no loss.
    It did not block "suddenly", there were problems with this castle before?
    ABC KOM
  • Door lock microswitch previously caused locking and interior light faults
    #5 16236966
    AndM
    Rate: 93
    Yes, there were such problems before that the right door did not close with the remote control and only I could close it with the general button, which is located on the driver's door. At the moment the driver's door closes with a remote control, but sometimes I have to open it with a key because they do not react to the remote control. A year earlier, when I acquired this car on the driver's door there is a LED, which should blink after closing and there was a problem with it that it did not flash after closing the door, and the lamp in the cabin did not light when opened. I undressed the castle and it turned out that it was the fault of the microstructure that is in the castle. After repair everything worked, until now.
    Greetings.
    Endriu
  • Faulty door-lock microswitch makes repairs unreliable
    #6 16237301
    CameR
    Help: 1139
    Rate: 3272
    ... and that's why I always suggest replacing the lock with a new one.
    Fun with repair a lot and a new replacement of good quality is less than PLN 150.
    The cost of replacing is the same as when repairing the lock.
    Unfortunately, very often the repair is ineffective or lasts for several months.
    ABC KOM
  • #7 18861008
    pavel57
    Rate: 9
    It's been a long time and probably fixed.
    But how did you manage to do it? You had to destroy the bacon and get to the lock?
  • Remote locking failure after lock replacement
    #8 19721476
    AndM
    Rate: 93
    Yes, the castle had to be destroyed. After replacing the lock, everything returned to normal.
    And now there's another problem with these locks. Right now, you cannot open any doors or the trunk from the remote control and only with the key I opened the driver's door. Also, the opening / closing on the left door switch does not work. I checked the fuses and did not find a damaged one. Maybe someone will advise you on how to get into the trunk?
    Regards.
The discussion revolves around a Seat Ibiza 6L with a malfunctioning right front door that cannot be opened due to issues with the central locking system and the outer handle. The user, Endriu, describes previous problems with the door not responding to the remote control and having to use the key for access. Responses suggest that the screws for the door panel are only accessible after opening the door, and some recommend replacing the lock entirely due to the ineffectiveness of repairs. Endriu later confirms that the lock was destroyed for access, and after replacement, the door functioned normally until new issues arose with the central locking system affecting all doors and the trunk. The user seeks further advice on accessing the trunk.
