[Solved] Astra H z16xep Radiator Fan Failure: New Factory Fan Not Activating Despite OP-Com Test
Diakon 1 32868 9
Why does the radiator fan on an Astra H 1.6 Z16XEP not switch on even at 115°C or with the air conditioning on, despite OP-COM relay tests and a new factory fan?
The fan was not switching on because the ground connection at the left wheel arch was missing; after checking it with a multimeter and control, everything worked again [#17114454] Fuses and relays had already been considered OK, but an OP-COM click test does not prove that the fan actually receives power and ground under load [#17102226][#17102700] The advice from the thread was to use a meter, not just diagnostics, and verify the actual supply and control circuit [#17102241]
  • #1 17102204
    Diakon 1
    Rate: 30
    Good morning everyone. Dear portal users do not want to duplicate the subject but my ideas have run out. I have a problem with a radiator fan, it is a system with one fan responsible for engine cooling and air-conditioning. Namely, I do not turn on the fan even at 115 c. I went to an electrician who connected OP-Com and said that the relays work well because they click on the execution test and the valves are standing. so the fan is blurred. Following his advice, I bought a new factory fan by serial numbers and gave it to the mechanic to put on. The mechanic called me, he founded but he checked this old man for a short time and works. The new one does not turn on anyway and I'm in a dot, op-com does not show any error. Please help. And tell us if it is possible to mix something with an op-com so that the vents do not attach. Thank you and best regards.
  • #2 17102217
    andrzej20001
    Help: 1578
    Rate: 6669
    Diakon 1 wrote:
    ai said that the relays work well because they click on the executive test and the valves are standing.
    and jk click on the power supply? Bepiecznik ok?
  • #3 17102226
    Diakon 1
    Rate: 30
    Fuses and relays ok. At least that's what an electrician said.
  • #4 17102241
    ak44
    Help: 106
    Rate: 207
    You need an electrician who can use the meter, not just the computer.
  • #5 17102249
    Diakon 1
    Rate: 30
    And how to check if the power goes.
    I would like to add that the vents do not turn on with the climate.
  • #6 17102287
    andrzej20001
    Help: 1578
    Rate: 6669
    No language can be. And seriously it's a control.
  • #7 17102700
    Diakon 1
    Rate: 30
    So yes, I played with the meter and fuses ok. Reliable relays. I checked on the current contacts whether the fan turns on and does not turn on. Any suggestions.
  • #8 17103654
    andrzej20001
    Help: 1578
    Rate: 6669
    What you checked
  • #9 17114454
    Diakon 1
    Rate: 30
    Hello everyone again. Thanks for your help, but the matter resolved. I checked with the multimeter and control and it turned out that there was no mass at the left wheel arch. Everything works now. I close the subject.
  • #10 17114457
    Diakon 1
    Rate: 30
    Added after 41 [seconds]:
    Thanks again.
The discussion revolves around a radiator fan failure in an Astra H Z16XEP vehicle. The user reports that the new factory fan does not activate even at high temperatures (115°C), despite successful relay tests using OP-Com diagnostics. An electrician confirmed that fuses and relays are functioning correctly, but the fan remains inactive. The user seeks advice on further troubleshooting, particularly regarding power supply issues. After further investigation with a multimeter, it was discovered that a lack of ground connection at the left wheel arch was the root cause of the problem, and once rectified, the fan operated normally.
