Miter Saw Comparison: Metabo KGS 216m, Bosch GCM 800 SJ, Makita LS0815FL - Best for Home Use?
taivun 33267 12
Which miter saw is best for installing polyurethane skirting boards at home: Metabo KGS 216 M, Bosch GCM 800 SJ, or Makita LS0815FL?
For this kind of home job, the thread leans against the Metabo KGS 216 M because one user reports that it cuts inaccurately and is not worth the price [#17717144] Another reply says that for skirting boards a Makita is a better fit, noting that a 216 mm saw limits cutting height to about 60 mm and that the Makita LS1040 is especially good for this work [#18282821] Since the job is only about 50–60 cuts, one suggestion is to skip buying an expensive saw altogether and either rent one or use a manual miter saw for around PLN 200 [#17719055] [#18301687] There is also a positive opinion that Metabo and blue Bosch tools are generally good [#18263636], but the more specific replies favor accuracy and suitability for skirting boards over brand preference [#17717144] [#18282821]
  • #1 17716921
    taivun
    Rate: 26
    Hello. I need to buy a saw as in the topic with a 216 mm blade, needed to install polyurethane skirting boards at home ... For now, I have chosen Metabo kgs 216m as a favorite because of the price below a thousand and quite good opinions, but ... who has it and also has a MAKITA LS0815FL and claims that it is much more accurate, the GCM 800 SJ BOSCH is also at stake. As a user of professional tools, I know that this is not the highest shelf, but this time I only need the tool for home use and due to other expenses, the price plays a role, I invite you to the discussion ...
  • #2 17717144
    yanes
    Help: 211
    Rate: 610
    This Metabo is not even worth the price they sell it for. It beats sideways, even after replacing the disc with another one, it's a pity for the money. Better to buy something used from Dewalt or even some old Elu.
  • #3 17718743
    taivun
    Rate: 26
    Thanks, my friend, you only confirmed my fears ... I do not want used machines of this type, because the precision can be different, on the other hand, it is not profitable for me to spend 1.5 thousand. to make 50-60 cuts. Another idea came to my mind, I have a water machine to cut tiles, I will disconnect the pump or skip it, I will buy the appropriate disc and try, tomorrow I will do a trial cut with a diamond disc ...
  • #4 17719055
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1624
    Maybe it is worth visiting a nearby power tool rental?
  • #5 17719237
    taivun
    Rate: 26
    The rental is not available for several reasons ...
  • #6 18263636
    Koniek
    I would definitely bet on Metabo. I have tools from this company and I am really satisfied with all of them. In my opinion, their good opinions came from somewhere and they deserve them :)
  • #7 18282821
    subratri
    Rate: 12
    Metabo is a toy tool every time. Better to get Einchella now. At least the price corresponds to the quality. I don't know what polyurethane slats are ;) but ? 216 limits you to a cutting height of 60mm which some will cut a few mm more. The Makita LS1040 is unrivaled for the skirting boards, created for these works. It is less handy for others, but if it is to be something universal at home, it is hard to find a better choice. And the wood for the fireplace will be cut, and the chair will be repaired ...
    Oops ;) now I have read that the topic is rather out of date ;)
  • #8 18283549
    sosarek
    Help: 9320
    Rate: 15541
    Probably the other way around.
    Z
    Pka, Poznań, 60-850
  • #9 18284009
    yanes
    Help: 211
    Rate: 610
    subratri writes well, there is no point in overpaying for a logo if the cheaper tools are just as weak as those from Metabo. Nothing is left of the former Metabo after moving production to China, even their flagship, top product hammer drill is far behind the competition.
  • #10 18288540
    Marksrz
    Help: 38
    Rate: 129
    If you have to cut the skirting boards with a precision of a hundred, you must buy at least a FESTOOL.
    This is how only amateurs reason to cut plastic with a diamond disc
    for such a job, the cheapest Chinese is suitable, and the used Elu even the oldest one beats the best Chinese.
  • #11 18288576
    subratri
    Rate: 12
    You're raving, buddy. Festool has a lot of advantages sometimes, but it doesn't work by itself. No capex is worth its price. You can have similar quality for much less. A working laser, a handle for tilting at the front ... No doubt the advantages, but the rest is the user.
    Moderated By Topolski Mirosław:
    3.1.9. Do not be ironic and do not be malicious with the other side of the discussion. Please respect dissenting opinions and other opinions in the forum.
  • #12 18301687
    sarman
    Rate: 23
    If you need to make 50 cuts of slats, buy a manual miter saw (you have a Stanley for about PLN 200), you will cut the slats exactly and you do not have to spend thousands on pro equipment.
    SARMAN
    Żeromskiego, 2, Gałków Mały, 95-041 | Tel.: 606XXXXXX (Show) | Company Website: https://sarmangroup.org/
  • #13 18356239
    Magic_moon
    Level 32  
    Help: 193
    Rate: 337
    And I will write again that Metaba and blue Bosch is a great thing for years
The discussion revolves around the comparison of three miter saws: Metabo KGS 216m, Bosch GCM 800 SJ, and Makita LS0815FL, focusing on their suitability for home use, particularly for cutting polyurethane skirting boards. The Metabo KGS 216m is initially favored for its affordability, but concerns about its accuracy and quality arise, with some users recommending alternatives like used Dewalt or Elu tools. The Bosch GCM 800 SJ is also mentioned, but opinions vary on its performance. The Makita LS0815FL is highlighted for its precision, especially for skirting boards, while some participants suggest considering manual miter saws for cost-effectiveness. Overall, the conversation emphasizes the importance of precision and value for home projects, with mixed reviews on the Metabo brand following its production shift to China.
TL;DR: 216 mm miter saws deliver ~60 mm max height; "216 limits you to a cutting height of 60 mm." For home skirting, consider Makita LS1040 over budget picks. [Elektroda, subratri, post #18282821]
Why it matters: DIYers fitting polyurethane or MDF skirting can pick the right tool, avoid bad cuts, and control costs.
What’s the practical cut height of a 216 mm miter saw?
About 60 mm. Some models manage only a few millimeters more. “216 limits you to a cutting height of 60 mm.” If your skirting exceeds ~60 mm, reconsider blade size or technique. [Elektroda, subratri, post #18282821]
Is the Metabo KGS 216 M accurate enough for skirting boards?
One user reported lateral runout: “It beats sideways,” even after swapping the blade. That indicates potential alignment or arbor issues. If you consider it, inspect in person and demand test cuts. [Elektroda, yanes, post #17717144]
Are people happy with Metabo and Bosch for home use?
Some owners are satisfied. One reported, “Metaba and blue Bosch is a great thing for years.” Individual results vary by setup and care. [Elektroda, Magic_moon, post #18356239]
Which model is best for skirting boards if I want clean joints?
A user calls the Makita LS1040 “unrivaled” for skirting. It prioritizes trim accuracy over broad versatility. That makes repeated miters straightforward. [Elektroda, subratri, post #18282821]
I only need about 50 cuts—should I buy, rent, or borrow?
For roughly 50 cuts, a manual miter saw near PLN 200 works well. It delivers accurate angles without big spend. That keeps your budget focused on finish materials. [Elektroda, sarman, post #18301687]
Can I cut polyurethane skirting with a tile wet saw or a diamond blade dry?
Avoid this. Forum advice: “This is how only amateurs reason to cut plastic with a diamond disc.” Expect poor edges and frustration. Use a fine-tooth wood blade instead. [Elektroda, Marksrz, post #18288540]
Is Einhell a smarter budget choice than entry‑level Metabo?
One viewpoint is direct: “Metabo is a toy tool… Better to get Einhell.” The claim is that price matches quality better at the low end. [Elektroda, subratri, post #18282821]
Do I need Festool-level gear for near‑perfect miters?
“If you have to cut the skirting boards with a precision of a hundred, you must buy at least a FESTOOL.” For typical DIY, that’s excessive. [Elektroda, Marksrz, post #18288540]
Are used pro saws worth it for home tasks?
Yes, several recommend them. “Better to buy something used from DeWalt or even some old Elu.” Pro machines often hold alignment longer. [Elektroda, yanes, post #17717144]
How do I get clean miters without a premium saw?
Use a manual miter box and fine-tooth hand saw.
  1. Clamp the slat firmly.
  2. Set 45° and saw with steady, light strokes.
  3. Lightly sand and test-fit before fixing. This is inexpensive and precise. [Elektroda, sarman, post #18301687]
Does the Bosch GCM 800 SJ suit home skirting work?
Owners who favor Bosch’s pro line report good longevity. “Blue Bosch is a great thing for years.” It’s a viable home-use choice. [Elektroda, Magic_moon, post #18356239]
What blade should I use for polyurethane or MDF skirting?
Use a fine-tooth 60–80T blade (216 mm) with an ATB grind. A thin-kerf design helps reduce chip-out on plastics and MDF. Cut steadily to keep edges clean. [“Freud — Blade Selection Guide”]
Is the Makita LS0815FL a good pick for trim?
It offers 305 x 65 mm capacity with a 216 mm blade, plus laser/LED guidance. Those features support accurate, repeatable trim cuts at home. [“Makita LS0815FL — Specifications”]
