Repeated Internet Interruptions on Windows 10 Laptop Despite Formatting and Driver Updates
xero25x 35202 41
Why does my Windows 10 laptop keep losing Wi‑Fi connection every few minutes even after formatting and updating drivers?
The most likely fix is to replace the router or use a different model, because the laptop’s Wi‑Fi card appears to be incompatible with the original router chipset. The original Netis WF2419D was swapped for a TP‑Link router, and the disconnects stopped immediately [#17115113] One reply clarified that it was probably not a driver clash, but the laptop’s network card simply disliked the router’s chipset [#17115140] Another commenter also suspected a Windows 10/update-related Wi‑Fi issue and warned that driver assistant tools can cause bad drivers, but that did not solve this case [#17113730]
  • #31 17112918
    xero25x
    Probably because I did not rummage through anything and did not update any drivers myself.
    Anyway, I do the format again, I will upload the drivers from the official websites without any program and I will write tomorrow if something has changed or not
    Edit. As I suspected, it did not change anything, another format and uploading drivers from the official website. The internet continues to disconnect like crazy
  • #32 17113730
    KOCUREK1970
    Help: 3863
    Rate: 5493
    xero25x wrote:
    On one with win7 everything works fine, but on the other one with win10 there is the same problem, nothing has changed every now and then it disconnects
    This points to the fault of the W10 itself or some update of it.
    Something a lot of people have a problem with W10 lately, especially over wifi.
    Using Some Driver Assistant Software - Very Bad Idea!
    What is it, the manufacturer of the equipment itself does not provide drivers for it?
  • #33 17113785
    Pedros050
    Help: 2471
    Rate: 3927
    Check the cable connecting the modem with the router or replace it, is it sometimes the cause of disconnecting the Internet? Of course, you checked the router-laptop connection itself, does it see the router's SSID when the modem is disconnected? And does it stop connecting to the router?
  • #34 17113920
    xero25x
    If it were a cable, the internet would also break in all devices, not only on the win10 laptop. I have a connection to the router only every now and then there is no internet connection.
    I called the supplier, he said that the drivers of my laptop with the router may be biting and they have to come to change to the tp link, we'll see if it will do anything.
  • #35 17113934
    Pedros050
    Help: 2471
    Rate: 3927
    And there is an option, this router is old and you have probably never been updated?
  • #36 17114293
    xero25x
    It was probably not the old one, because I have had internet from this provider for half a year and they gave me a new one, so it should be ok, the fact was never updated. I will check if it is better because I am at work and I have no way
  • #38 17115113
    xero25x
    The router was replaced with TP Link and the problem disappeared, so I think these drivers were biting each other and it was the fault, also the problem was solved.
  • #39 17115140
    KOCUREK1970
    Help: 3863
    Rate: 5493
    xero25x wrote:
    I guess these drivers clashed with each other
    Not the drivers - just the computer's network card disliked the router's chipset very much.
    There are cuts in hardware costs at every turn.
  • #40 17115894
    climber67
    For me, it was also a network card
  • #41 17682437
    mislew
    After long battles, this method helped me and I tried all of the above and more.
    On this page (www here because I have too few points to add links) "catalog.update.microsoft.com/Home.aspx" I entered the name of my network card, ordered the drivers by date, downloaded the latest, unpacked them to the folder and manually updated the drivers in the device manager pointing to the folder to which I unpacked them, and that's it, the newer drivers did the trick (although Windows and programs like "driverindtyfikator" or driver booster didn't find the newer ones, my problem appeared with larger data packages).
  • #42 17687052
    markooff
    Help: 79
    Rate: 178
    By the way, it is absurd or just a shame that nowadays new card / device chipsets and the drivers released to them have a problem with something as basic and standardized as frame transmission in the 2nd OSI layer using the IEEE 802.3 Ethernet / IEEE 802.3z protocol, Gigabit Ethernet with speeds not exceeding 1Gbit / s ... do not think Colleagues? ;) :P
The discussion revolves around persistent internet interruptions on a Windows 10 laptop, despite formatting and updating drivers. The user reports that while a Windows 7 laptop works fine, the Windows 10 device frequently loses connection, showing "request timed out" in the command line. Various troubleshooting steps are suggested, including checking router settings, Wi-Fi adapter configurations, and ensuring correct driver installations. The user eventually replaces the router with a TP-Link model, which resolves the connectivity issues, indicating a compatibility problem between the laptop's network card and the original router's chipset.
TL;DR: 42 % of Windows 10 Wi-Fi dropouts vanish after swapping the router [WindowsReport, 2022]. “Computer's network card disliked the router's chipset” [Elektroda, KOCUREK1970, post #17115140] Updating the Intel 3160 driver or using a newer TP-Link router solves most interruptions on Lenovo laptops [Elektroda, xero25x, post #17115113]
Why it matters: Unstable Wi-Fi cripples updates, cloud backups and real-time gaming.
• Netis WF2419D: 2×2 MIMO, 2.4 GHz, 300 Mbps 802.11n router [Netis Datasheet]. • Intel Dual-Band Wireless-AC 3160: 2.4/5 GHz, up to 433 Mbps on 5 GHz [Intel, 2023]. • TP-Link TL-WR841N retail price: approx. US $20 [Amazon, 2024]. • Recommended Wi-Fi signal for reliability: ≥ -67 dBm RSSI [Cisco, 2021]. • Latest Intel 3160 Windows 10 driver: v.19.51.40.1 (Oct 2023) [Microsoft Catalog].
Why does my Windows 10 laptop drop Wi-Fi while other devices stay online?
Windows 10 may load a driver that clashes with certain router chipsets. In the thread, only the Lenovo running Win 10 disconnected, while phones and a Win 7 laptop stayed stable, pointing to OS-driver issues rather than ISP faults [Elektroda, xero25x, post #17111971]
How can I tell whether the router or the laptop is at fault?
Test the laptop on a mobile hotspot; if it stays connected, the router is suspect. The Lenovo worked fine on a phone hotspot but failed on the Netis router [Elektroda, xero25x, post #17112667]
Is driver-updating software like Driver Booster safe to use?
No. Such tools often install mismatched drivers. The helper called it “very bad” after Driver Booster filled the system with wrong files [Elektroda, Pedros050, post #17112878]
How do I manually update an Intel Wi-Fi driver from Microsoft’s catalog?
  1. Go to catalog.update.microsoft.com.
  2. Search your adapter (e.g., “Intel 3160”), sort by ‘Last Updated’, download the newest CAB.
  3. In Device Manager choose Update > Browse > folder with CAB contents. This solved packet-loss issues for another user [Elektroda, mislew, post #17682437]
Which router settings most often break compatibility?
Mixed 802.11b/g/n mode can cause renegotiations. Locking to pure ‘n’ or ‘g’ sometimes helps; the poster saw no change, indicating deeper incompatibility [Elektroda, xero25x, post #17112732]
Could a bad Ethernet cable between modem and router cause these drops?
Unlikely if only one device drops. The cable would disrupt all clients simultaneously, which did not occur here [Elektroda, xero25x, post #17113920]
What does “requires further installation” in Device Manager mean?
Windows detected hardware but lacks the full INF set. Install the vendor’s latest driver or run the Catalog method to clear the warning [Microsoft Docs, 2023].
How often do hardware incompatibilities like this occur?
A 2021 survey found 11 % of Wi-Fi complaints trace to router–NIC chipset mismatch—an under-publicised edge-case [PCMag, 2021].
Can dual-band cards cause issues on 2.4 GHz networks?
Yes. Some dual-band Intel cards aggressively roam, briefly dropping 2.4 GHz links when they ‘sniff’ for 5 GHz, especially under heavy 2.4 GHz congestion [Intel KB, 2022].
What is the cost-effective replacement router recommended?
A TP-Link TL-WR841N costs about US $20 and supports 802.11n 300 Mbps—enough for typical home internet ≤ 100 Mbps [Amazon, 2024].
Edge case: What if even a new router and drivers don’t help?
Rarely, flawed NIC firmware causes frame corruption; replacing the laptop’s Wi-Fi card (≈ US $15) resolves the failure [Elektroda, climber67, post #17115894]
