The wifi connection occasionally breaks the internet connection
Mateusz7LT 7176 3
  • #1 16403259
    Mateusz7LT
    The laptop is connected to the wi-fi router and periodically breaks the connection to the internet. After reconnecting, the Wi-Fi reboot on the laptop reconnects to the internet. on another laptop is the same ... is it the router's fault?
  • Router firmware, channel interference, and mixed Wi‑Fi modes cause drops
    #2 16403361
    safbot1st
    Help: 2719
    Rate: 1585
    As the logic indicates - initially the router's fault.
    Start by checking if it has the current firmware.
    There can be many reasons, including interference on the channel. Try switching to a different channel.
    If the above does not help, try encrypting.
    In my experience, it also shows that sometimes wi-fi disconnects when using mixed devices on a network - g / b and n.
    The rest of the advice after completing the data.
  • #3 16403384
    radex324
    Help: 50
    Rate: 206
    Most likely, it's the router's fault, as a colleague wrote, it would be best to reconfigure it or change it for a moment to see if the problem will occur.
  • #4 16404965
    KOCUREK1970
    Help: 3860
    Rate: 5488
    Mateusz7LT wrote:
    is this the router's fault?
    Install InSSIDer v2 / Home on computers and do a network test and insert photos here (all networks should be visible!).
