IP Video Intercoms from Aliexpress: YobangSecurity 7 & 1.0MP 720P AHD HD TCP/IP SIP 7 Touch Screen
JarekPrzybyl 9636 17
Are the YobangSecurity/Aliexpress IP video intercom sets reliable, or are they unstable lottery devices?
These Aliexpress IP video intercoms are generally described as a lottery: the bell, conversation, image, and door release can work only sporadically, and the phone app may miss calls, blank the screen, or flicker on and off [#17114265][#17114879] Do not expect real waterproofing from them either; the enclosure may look OK, but rain can get in through the pinhole camera, button, and speaker openings, and poor installation makes it worse [#17118570][#17119016][#17119071] If reliability matters, one poster recommended spending more on a Commax CDV-70UX with DRC-40KPT instead [#17115601] That set reportedly had some early issues but now works without problems [#17115661] Its camera resolution was estimated at about 500 lines, which was considered enough to recognize a person up to roughly 1 m away [#17115661]
  • #1 17113555
    JarekPrzybyl
    Rate: 218
    Did any of you have to deal with IP video intercoms from China and can say something more about them? Whenever possible, I would like to ask for specific comments from someone who has seen these (or other similar) intercoms, not a question of what Chinese electronics are worth.
    I am thinking about these two sets:
    https://www.aliexpress.com/item/YobangSecurit...ID-Password-APP-Control-Door/32835911750.html
    and
    https://www.aliexpress.com/item/Free-Shipping...-Touch-Screen-Video-Intercom/32844228283.html
    the first with two monitors, an RFID reader, the second gives a more solid impression. The weak point of both are phone applications, in both cases they are applications with a low Google Play rating, for the first of these is also the opinion that whether the "conversation" will come or not is a pure lottery. The second has only two ratings, one for four stars, the other for one, which is also meaningful.
  • #2 17114265
    Ircys
    Intercoms specialist
    Help: 1343
    Rate: 2090
    With the second set we had (un-) pleasure to meet at the assembly and I confirm the opinion that someone gave to the first - LOTTERY !. Don't expect anything else from these tinsel. Each of the functions (bell, conversation, image, opening) works whenever it wants and how it wants and when it happens by accident that all these functions work at once, we are happy as little Jasio from the queue under the Christmas tree and we cherish those moments because they can quickly don't come back anymore :)
    best regards
    PS
    I wonder what you will do when you want to advertise it ...
  • #3 17114639
    JarekPrzybyl
    Rate: 218
    But does this lottery concern the app on the phone, or does the outdoor-monitor set also work randomly?
  • #4 17114879
    Ircys
    Help: 1343
    Rate: 2090
    Yes, this also applies to the app. It happened that it did not respond to the call at all, other times it behaved so that after the call it blanked the smartphone screen (and the phone rang all the time) or flickered turning on and off itself.
    The set itself behaved a little better, but also unstable.
    best regards
  • #6 17114968
    Ircys
    Help: 1343
    Rate: 2090
    suworow wrote:
    And by the way, colleague Ircys, you didn't deign to answer it to me ;)
    ... because exactly with this Orno I had no (un-) pleasure and I regard it as an advantage :) I know, I know, it's all from "one ax", but you still asked about the concrete.
    best regards
    Added after 5 [minutes]:
    suworow wrote:
    Monitor for this: http://vidos.pl/wideodomofony/vidos-analogowe...o-wideodomofonow/m903s-monitor-videodomofonu/
  • #7 17115049
    suworow
    Help: 650
    Rate: 1278
    I will try to ask less specifically next time :)
    best regards
  • #8 17115556
    JarekPrzybyl
    Rate: 218
    Gentlemen, I have read a bit in the meantime and now I have the impression that the cooperation of IP video intercoms with apps is generally a heavy topic. The Chinese from Aliexpress are Chinese from Aliexpress, but e.g. popular with us and even recommended as a very good Dahua, as I found out, uses the gDMSS Lite app. This is an app with more than THREE THOUSAND negative comments, mainly opinions about its instability or incompatibility.
    In the thread I see people dealing with intercoms professionally - and what would you recommend in the dark as a reliable and trouble-free device? My needs:
    - video intercom for a single-family house
    - external part necessarily with real IP65 (exposed to driving rain), preferably narrow (
  • #9 17115601
    suworow
    Help: 650
    Rate: 1278
    And what would you say for spending a minimum of PLN 3,000 for a commax cdv 70ux with a drc 40kpt camera? It's not like 720p, which in my opinion doesn't bother you at all. For this reader a combination lock as a separate device. best regards
  • #10 17115651
    JarekPrzybyl
    Rate: 218
    And what's the actual resolution? Because I didn't find anywhere quickly searching, the angle of view is only given. I can actually earn some extra RFID reader as a separate device, controlling the bolt independently.
    At this time, according to prices from the website videoodomofony.pl, I would have less than 2500 PLN to spend for the basic set. Plus still from PLN 800, if I wanted to add a second monitor ... This is very expensive compared to the Chinese (where I can have a set with two monitors for 1/3 of this price), but if these commaxes actually work reliably, then maybe worth thinking In particular, if their app is stable and reliable, maybe a second monitor would be superfluous? Then the PLN 2,500 sounds like something acceptable ...
  • #11 17115661
    suworow
    Help: 650
    Rate: 1278
    At the beginning there were minor problems, but now it works without any problems. The camera resolution itself thinks it does not exceed 500 lines, but it is quite enough to recognize a person up to 1m away, because this is what the intercom is for. The downside is the lack of the ability to call the image yourself, but it can be "deceived" by the gsm transmitter, e.g. alarm system.
  • #12 17115671
    JarekPrzybyl
    Rate: 218
    No possibility to call the image yourself, but from the app? Is the monitor also ???
  • #13 17115847
    suworow
    Help: 650
    Rate: 1278
    From the app. Add a roof to the camera and a hitch power supply
  • #14 17116766
    JarekPrzybyl
    Rate: 218
    Another question for Ircys about this Chinese intercom - how did its exterior look in practice in terms of water resistance? In the advertisements, individual sellers describe it as waterproof, some even as IP64, but to be honest it does not look and I have some concerns here. Especially since I have already unpleasantly cut the camera's water resistance in my current orno: pinhole camera, vandalproof, armored - and unfortunately, zero water resistance, water entered inside as it wanted, the camera after three seasons simply rotted.
  • #15 17118570
    Ircys
    Help: 1343
    Rate: 2090
    This Chinese (like any Chinese!) Looked OK, but nothing other than what happened to you with Orno, I would not expect from this equipment.
    best regards
  • #16 17119016
    suworow
    Help: 650
    Rate: 1278
    The whole pic is not about water resistance, but about the fact that the water that gets even through the loudspeaker blinds can also get out freely. The life of the panels is also affected by assembly errors such as silicone sealing, placing the cassette at an upward angle, running the connecting cables so that water flows down them into the cassette. Unfortunately, cheap equipment often goes hand in hand with cheap assembly by all kinds of "magicians" from all kinds of installations.
    best regards
  • #17 17119071
    JarekPrzybyl
    Rate: 218
    The assembly was just ok (plug-in cassette, in the original "frame" embedded in the wall, the cable entering the cassette straight from the wall), but:
    - "pinhole" is simply a hole. The water from the driving rain seeps inside through it,
    - bell button - the same, zero seal
    - the loudspeaker holes seem to be profiled so that each of them has a "roof", but the cutting rain easily gets inside.
    The effect was that in wet rainy weather, the camera image was blurry, blurry spots, sometimes it got wet and the speaker and then nothing could be heard. After two or three years of such exploitation, in the last frosty weeks the whole damn finally hit completely.
  • #18 17119156
    suworow
    Help: 650
    Rate: 1278
    The commax recommended for you is not much better. It is also not tight and usually it lasts much longer than 3 years :)
The discussion revolves around the reliability and performance of IP video intercoms from Aliexpress, specifically the YobangSecurity 7-inch model and a 1.0MP 720P AHD HD TCP/IP SIP model. Users report significant issues with both devices, describing their functionality as erratic, with features like calling, image transmission, and app connectivity working inconsistently. Concerns are raised about the quality of the associated mobile applications, which have low ratings and are prone to failures. Comparisons are made to other brands, such as Dahua and Commax, with suggestions for more reliable alternatives. Users express skepticism about the waterproof claims of the Chinese models, citing past experiences with similar products that failed under wet conditions. Overall, the consensus is that while the Chinese intercoms are cheaper, their reliability and performance may not justify the cost savings.
TL;DR: For budget IP video intercoms, app reliability is risky—one app had 2 ratings (4★ and 1★), and "pure lottery" behavior was reported. Expect unpredictable ringing, talk, video, and unlocking; consider proven kits instead. [Elektroda, JarekPrzybyl, post #17113555]
Why it matters: This FAQ helps homeowners and installers pick an IP video intercom for a single‑family house without gambling on apps or weatherproofing.
Are Aliexpress IP video intercoms reliable in daily use?
Reports show inconsistent behavior. Ringing, talk, video, and unlocking may work at random. One installer summed it up: “LOTTERY!”. That unpredictability frustrates users and complicates support. If everything works at once, it may be brief. Consider this before choosing a low‑cost kit for a main entrance. [Elektroda, Ircys, post #17114265]
Does the “lottery” affect the phone app or the indoor monitor?
Both. The app sometimes ignored calls. It also blanked the screen while the phone kept ringing. It could flicker, turning on and off by itself. The hardware set behaved a bit better, yet remained unstable. [Elektroda, Ircys, post #17114879]
How reliable is Dahua with the gDMSS Lite app?
The app attracted over 3,000 negative comments about instability and incompatibility. That volume suggests issues if you rely on mobile control. Dahua hardware may be solid, but test the app early. Use return windows if it misbehaves. [Elektroda, JarekPrzybyl, post #17115556]
What should I do to improve water resistance on outdoor panels?
Prioritize drainage. Let water entering speaker grills drain freely. Avoid silicone sealing that traps moisture inside. Don’t mount the cassette tilted upward. Route cables with drip loops so water cannot wick into the housing. [Elektroda, suworow, post #17119016]
How did that specific Chinese panel hold up to rain over time?
It looked OK at first. Performance mirrored low‑cost Orno units under weather. Do not expect true sealing or endurance in driving rain. Water ingress remained a concern long‑term. [Elektroda, Ircys, post #17118570]
What’s a more reliable alternative if I just need it to work?
Consider Commax CDV‑70UX with a DRC‑40KPT camera. Budget at least PLN 3,000 for the base kit. Add a separate RFID reader or keypad for entry. It isn’t 720p, but it fulfills door‑intercom needs well. [Elektroda, suworow, post #17115601]
What image quality should I expect from that Commax setup?
Resolution is about 500 TV lines. That is enough to recognize a person at roughly one meter. It targets door identification rather than surveillance detail. Many entrances find this adequate. [Elektroda, suworow, post #17115661]
Can I call live video from the monitor, or only through the app?
Use the mobile app to initiate live view. In this setup, image calling is app‑based rather than from the monitor. Plan workflows around the app. [Elektroda, suworow, post #17115847]
What odd app failures should I be ready for on cheap IP intercoms?
Expect call misses. The app sometimes blanked the phone screen while the phone kept ringing. It also flickered on and off by itself. These failures undermine remote answering reliability. [Elektroda, Ircys, post #17114879]
How do I mount an outdoor intercom to survive driving rain?
Use this quick setup:
  1. Mount vertical or slightly downward; never upward. Let water drain through speaker grills.
  2. Do not silicone‑seal edges; keep drainage paths open.
  3. Create a drip loop and route cables so water cannot flow into the cassette. [Elektroda, suworow, post #17119016]
How hard is warranty or returns for these imports?
Plan for challenges. One installer quipped, “I wonder what you will do when you want to advertise it ...”. Support and returns can be difficult. Factor that risk into purchase decisions and deployment timelines. [Elektroda, Ircys, post #17114265]
I already bought a budget set. Any quick stabilizing tweaks?
Add a small roof or hood over the camera to cut exposure. Use a solid, appropriate power supply. These are straightforward installer tips that improve day‑to‑day usability. [Elektroda, suworow, post #17115847]
Can I pair that Orno IP set with a Vidos monitor?
An installer referenced the Vidos M903S as the monitor for that Orno‑style unit. That indicates a known pairing used in the field. Verify compatibility before purchase. [Elektroda, Ircys, post #17114968]
Can I get two indoor monitors and RFID from a cheap kit?
Yes. One cited Aliexpress set included two indoor monitors and an RFID reader. These bundles look attractive but weigh app stability and weatherproofing first. [Elektroda, JarekPrzybyl, post #17113555]
