Max Storage Time for Unused Li-ion Battery: 7-Year-Old Electronics & Operational Chances
piotrd76 21207 6
  • #1 17113561
    piotrd76
    Automation specialist
    Help: 35
    Rate: 68
    What is the maximum storage time of a Li-ion battery (not the cells themselves, but a complete battery with electronics)?
    Is there a chance that e.g. a 7-year-old, never used battery from stock will still be operational?
  • #2 17113579
    Kasek21
    Help: 4981
    Rate: 3547
    What's the difference?
  • #3 17113628
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    I do not know that, but I had such a case with Varta alkaline batteries, but they were normally used after purchase. Batteries bought in 1996 for the flash to take some photos at the wedding of my cousin and used for this purpose. After this "use", they were loaded in a lamp for probably 2 or 3 years (forgotten, not used equipment). Somehow, I just lacked batteries for the remote control and "found" these (R 6 batteries, today's AA) although they were long past the "useful life" date, but still working. They lasted 3 and a half years in the remote control, I was surprised myself that this was the quality and life of these batteries. In my opinion, it all depends on the quality of the batteries, but nowadays we will not find rather super durable ones.
  • #4 17113698
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    Since it was unused, it probably has zero cycles on its account.
    However, lithium-ion cells (like all batteries) self-discharge. If, for this reason, the voltage of a single cell has dropped below 2 V, its degradation is irreversible.
    If the voltages of individual cells are higher - you can try to resuscitate them. You can try to charge them and check their current capacity.
  • Battery cells still test good despite failed charging
    #5 17162076
    tomaszdko
    Help: 6
    Rate: 18
    I have an old 500MHz p3 laptop, the battery is not charging. I have stripped it down and there are nice 3 cells, all of 3.7v. I checked the performance and they are really decent (I need to reset the eeprom in the battery). The laptop was recently turned on on the power supply 3 years ago and for a while, but earlier it was more time aging. Company batteries are definitely worth buying because they are durable (although they are definitely discharged), but not to the same extent as travels because I had them too.
  • #6 17168204
    piotrd76
    Help: 35
    Rate: 68
    Unfortunately, I cannot check the cells. The point is that I want to revive an almost vintage netbook, and the only batteries that still get into it are old ones from stock, and usually from foreign sellers on ebay. Hence the question whether it makes sense to bring such a battery.
  • #7 17169051
    tomaszdko
    Help: 6
    Rate: 18
    "Unfortunately, I cannot check the cells."
    Disassemble the battery and measure each target individually directly with a voltmeter. First, check if they have the appropriate minimum voltage (if so, check if all cells have the same voltage or very close). Even if they have differences (but are not discharged below the minimum) the balancer is equal when charging.
The discussion centers on the maximum storage time for unused Li-ion batteries, particularly focusing on a 7-year-old battery and its operational viability. Key points include that Li-ion batteries self-discharge over time, and if the voltage of any cell drops below 2V, degradation becomes irreversible. Users share experiences with older batteries, noting that while some may still function after years of storage, the quality of the battery significantly influences longevity. Suggestions include checking individual cell voltages and attempting to revive the battery if the cells are above the minimum voltage threshold. The conversation also touches on the challenges of sourcing old batteries for vintage electronics, such as netbooks and laptops.
