Bosch Vario Perfect Maxx 7 - the "washing" light is flashing does not
Paulaa94 28038 3
  • #1 17113759
    Paulaa94
    Hello, I have a problem with the Bosch Maxx 7 Vario Perfect washing machine.
    During normal washing, the "wash" lamp flashes continuously. I would like to add that I use washing capsules and do not put any washing agents into the drawer. With the washing function, it does it correctly, it goes to rinsing and the washing light starts flashing, it consumes water normally, etc. in the next phase spinning, it does not want to completely spin what is inside, it turns off normally, but the laundry remains wet. some water is left in the drum when the laundry is removed. What to do next? earlier this indicator was flashing, but it was spinning normally. When I drained the water from the drum and threw the laundry into the spin cycle, setting the program to rinse / spin was turned on, it spun for a moment, then the washing control came on and it was over. of course the laundry was still wet. I have already read on the forum about the hydrostat, will it be for replacement or something else? Please help. best regards
    stanislaw1954
    Help: 2013
    Rate: 4673
    Rather not a hydrostat, but a completely or partially blocked dirty water outlet. You need to carefully check the entire drainage system, starting from the drain hose, through the pump, to the hydrostat and the connection of the pump to the washing machine drum and, of course, the hydrostatic leg.
  • #3 17205820
    Carrotka
    Rate: 21
    I suspect another reason for this. Much easier ... You load too much of everything in the washing machine at once. The washing machine cannot balance the laundry to the spin evenly and the drum damage protection is working ...
  • #4 19039511
    vitay007
    Rate: 88
    And if the washing machine is working normally and when it switches to "RINSING", rinsing is lit and washing is blinking. What is wrong? The washing machine spins normally.
