Bosch WAQ 24461PL / 01 Avantixx 8 washing machine - the key flashes, it does not
niktto 33198 3
  • #1 16841581
    niktto
    Rate: 16
    Bosch Avantixx 8 WAQ 24461 en / 01 the key flashes, it does not react to anything. When I set it for a quick wash, the key stops flashing, but holding the start does not react either. I think the electronics have died, but Bosch's service refused to say which module to replace, and there are two control panels and electronics. I am asking for a hint, maybe it can be repaired without replacing the entire module.
  • #3 16841894
    niktto
    Rate: 16
    :) I can read instructions .......... you know what the key is for :)
  • #4 16845303
    Trull
    Help: 138
    Rate: 600
    In some models, it is possible to disable the lock only on the program on which it was activated. So let's go, you turn the program selector one step and press the key and hold for 3-7 seconds. START / PAUSE - until effective. Probably the program has a bug which causes this behavior of the software.
