Renault Laguna - squeaking 30 seconds after locking the car with the remote cont
mikaxx 10848 6
  • #1 17117875
    mikaxx
    Rate: 39
    I have this problem: for some time, when I lock the car (Renault Laguna 3, 2010) with the remote control, a Squeak comes out in the rear part of the car, behind the passenger's door, which lasts about 30 seconds. Then it goes quiet and it's ok. The car is locked. It seems to me that this is some kind of detector, but what can this detector be from and how to fix this squeaking? Yesterday all the locks on the doors were patched with a special preparation, 4 cubes by the door too (the big yellow ones that lead electrics to windows, lights, etc.). Nothing helped. Maybe someone also had such a problem?
    PS The battery is new, so that's definitely not it.
  • #2 17117963
    haderach
    Help: 118
    Rate: 181
    The fuel flap lock actuator comes to mind. But he's on the right ...
  • #3 17118030
    mikaxx
    Rate: 39
    it was the hood opening sensor :) it's ok now :)
  • #4 17118241
    haderach
    Help: 118
    Rate: 181
    It's good that we managed to locate it :) .
  • #5 18657217
    xPiotrus77
    Hello, I have exactly the same problem, could you describe in more detail the repair of this?
  • #6 19245720
    Qbat1980
    In my case, the same as above. The squeaking started after replacing the LEDs in the factory-installed daytime running lights.
    The squeaking is also heard while driving the car as well as immediately after opening and closing for about 20 seconds
  • #7 20568401
    mikaxx
    Rate: 39
    If anyone had such a problem, my mask was simply not closed properly. I had to open and close properly :) Which is very strange because on the display there was an error - "Check childproofing" ;) Just today I had the same thing again and I found my thread from years ago and it helped again :D
The discussion revolves around a squeaking noise occurring in a 2010 Renault Laguna 3 after locking the car with a remote control. The noise, which lasts for about 30 seconds, was initially suspected to be related to a detector. A user identified the source of the squeak as the hood opening sensor, which was resolved after proper closure. Another user reported a similar issue linked to the replacement of LEDs in daytime running lights, while yet another found that improper closure of a mask triggered a related error message. The conversation highlights troubleshooting steps and solutions for resolving the squeaking noise.
