Power Supply for Gigabyte GTX 1050, i5-2400, 8GB RAM, Asus P8H61, Toshiba P300: Is 350W Enough?
Rpossxd 4323 9
Can I power an Asus P8H61 system with a GTX 1050, i5-2400, 8 GB RAM and Toshiba P300 drive using a 350W PSU?
No, the 350W Akyga/Modecom Feel II unit is not a safe choice for this PC; both models were described as blacklist power supplies, and one reply says it would be afraid to connect it at all [#17120894] [#17120930] The advice in the thread is to replace it with the Corsair 450W you mentioned instead [#17120956]
  • #1 17120795
    Rpossxd
    Hello friend, I have a question about the power supply and I do not know what power to have for these components
    I have
    Asus p8h61
    GTX 1050
    I5 2400
    Sparta 3
    Toshiba p300
    8gb ram 1600
    And I have a 350w power supply and I don't know if it's enough
  • #2 17120809
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. What brand? As a company one, that's enough.
  • #3 17120817
    Rpossxd
    I do not know if it is a brand but the company is Akyga but it will only be for about 1 month because I will be changing it to the company 450w. With Corsair
  • #4 17120837
    Pedros050
    Help: 2471
    Rate: 3926
    "a proprietary 450w. With Corsair" That's how it can be.
  • #5 17120862
    Rpossxd
    So the temporary Akyga 350 is enough?
  • #6 17120889
    Pedros050
    Help: 2471
    Rate: 3926
    Ten? Power Supply for Gigabyte GTX 1050, i5-2400, 8GB RAM, Asus P8H61, Toshiba P300: Is 350W Enough?
  • #7 17120894
    Robert B
    Help: 2027
    Rate: 1412
    One of the blackest lists. Surely enough to send the computer back to the land of the eternal hunting.
    I would be afraid to connect it at all.
  • #8 17120925
    Rpossxd
    Modecom feel ii 350w will be branded
  • #10 17120956
    Pedros050
    Help: 2471
    Rate: 3926
    And buy the Corsair you wrote about him. @Rpossxd
The discussion revolves around the adequacy of a 350W power supply for a system comprising an Asus P8H61 motherboard, a Gigabyte GTX 1050 graphics card, an Intel i5-2400 processor, 8GB of RAM, and a Toshiba P300 hard drive. Initial responses suggest that while a 350W power supply may be sufficient, concerns are raised regarding the quality of the Akyga brand. Users recommend upgrading to a more reliable 450W power supply from Corsair for better stability and performance. The conversation highlights the importance of using reputable brands to avoid potential hardware failures.
