Best Power Supply for RTX 2070 + Ryzen 2700x Setup: 600W Enough? MSI, Gigabyte, Kingston, Samsung
vomgd 10209 6
  • #1 17601461
    vomgd
    Hello, like in the subject. Which power supply (how many WATs) should you choose for this configuration? Is 600W enough or is it safer to take a bigger one?
    Graphics card: MSI GeForce RTX 2070 ARMOR 8GB GDDR6
    Processor: AMD Ryzen 7 2700X + Box fan
    Motherboard: Gigabyte X470 Aorus Ultra Gaming
    Memory: DDR4 16GB 3200MHz Kingston HyperX Predator (2x8GB, CL16)
    Hard disk: Samsung SSD 970 Evo 500GB NVMe M.2 PCIe 3.0 3400/2300 Mb / s
    2 Hard disk: SSD 128 MB ADATA
    3 Hard disk: SSD 1TB
    Fans in the housing x 3 pcs.
  • #2 17601524
    badboy84
    Help: 1197
    Rate: 1485
    This computer in this configuration can download some 350W with a slight margin. Pay attention to the quality of the power supply, not just the amount of W on the label.
    Budget not limited? Are there any spreads?
  • #3 17601528
    kiss39
    Help: 397
    Rate: 636
    Ryzen 7 2700X - gets 105 Watt
    RTX 2070 gets 175 Watt
  • #4 17601577
    vomgd
    I care about a good power supply, but not too expensive. Let's say up to PLN 400 can be.
    Ps. I initially chose the ATX 600W be quiet! Pure Power 10 (80PLUS Silver)
  • #5 17601610
    badboy84
    Help: 1197
    Rate: 1485
    I think it's a good choice, I have it myself in CM version ;)
    If you have a housing with a window and the order in the wiring is important, it's probably worth considering such a purchase.
  • #6 17601627
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8290
    I will add PLN 400 to something like this: https://www.morele.net/zasilacz-seasonic-focus-plus-gold-550w-ssr-550fx-1483167/ - it has a 10-year warranty (BQT probably 3 years), certificate 80+ GOLD and similar price.
    vomgd wrote:
    Processor: AMD Ryzen 7 2700X + Boxing fan
    I would consider buying something that is more suitable for cooling this processor.
    / edit: even cheaper this power supply is here: https://proline.pl/zasilacz-seasonic-focus-plus-gold-550-ssr-550fx-80plus-gold-550w-p1106862
The discussion centers around the appropriate power supply for a PC configuration featuring an MSI GeForce RTX 2070 graphics card and an AMD Ryzen 7 2700X processor. Users estimate the total power consumption to be around 350W, suggesting that a 600W power supply would be sufficient. However, they emphasize the importance of power supply quality over wattage alone. Recommendations include the be quiet! Pure Power 10 (80PLUS Silver) and the Seasonic Focus Plus Gold 550W, which offers a 10-year warranty and higher efficiency ratings. The budget for the power supply is noted to be up to PLN 400.
