Connecting a 600W Power Supply to Equipment Requiring 300-350W: Potential Issues?
tadziq88 37662 17
Can I use a 600W power supply for equipment that only needs 300–350W?
Yes—there are no contraindications to using a 600W PSU with a 300–350W load, and the extra reserve can be useful for future upgrades [#12290772][#12306174] A power supply draws only as much power as the system needs, so it does not cost as if it were constantly delivering 600W [#12290777] ATX supplies do not need to run at 90–100% load to work properly; they can operate with much smaller loads, and even modest load is often enough for startup [#12290790][#12290896] The only real downside mentioned is efficiency: a higher-rated PSU running lightly loaded will usually be less efficient and may draw a bit more from the mains than one operating closer to its rated range [#12291122]
  • #1 12290766
    tadziq88
    Maybe that's a stupid question as well :)
    but are there any contraindications for connecting 600W to equipment that needs a power supply of 300-350W at most.
    Because I want to pay for new equipment in installments and the power supply is crucial because the old one has failed.
  • #2 12290772
    goldi74
    Help: 1367
    Rate: 1539
    There are no contraindications. The power reserve may come in handy in the future.
  • #3 12290777
    Lzep
    Help: 486
    Rate: 133
    And I would like to add that the power supply takes only as much as it needs from the network, so you don't have to worry about paying for 600W :D .
  • #4 12290781
    tadziq88
    I thought so, but my expert neighbor gives himself a cut and denies that the power supply must work under load. I'm going for the ax.
  • #5 12290790
    Lzep
    Help: 486
    Rate: 133
    After all, it will work under a load of 300-350W! Nowhere is it required that the load must be 90 or 100%?
    For the proper operation of the switching power supply, a much smaller load is enough - often when measuring the power supplies (for a PC), I connect 2-3 old CDs and it is enough!
  • #6 12290794
    tadziq88
    Sorry, I meant close to the maximum.
  • #7 12290803
    Lzep
    Help: 486
    Rate: 133
    It's not true, look for that ax :D
  • #8 12290842
    goldi74
    Help: 1367
    Rate: 1539
    tadziq88 wrote:
    forgive me, I meant close to the maximum
    No computer ever draws constant power. It changes depending on the activities currently performed. Following the neighbor's line of thinking, the computer would have to be replaced with another power supply every now and then, depending on whether we are just making a note in a notebook, browsing the internet or launching the latest game with 8D effects.
  • #9 12290896
    helmud7543
    Help: 1216
    Rate: 1564
    tadziq88 wrote:
    but my expert neighbor, I give myself a hand and denies that it must work with the power supply under load.
    Maybe he meant that he must have some load (in most power supplies, a residual, at least one hard drive is enough - unless it's about 1000W or more).
    Probably all ATX power supplies have resistors enabling operation with zero load - possibly the protections may not allow it to start in such a situation or they will turn it off after a few seconds. Possibly, it will not be able to control the voltages and it will also turn off due to the activation of protections.
    On the other hand, buying a "too strong" power supply and using a computer that uses a fraction of its power does not involve anything other than paying in the store more than necessary.
  • #10 12291122
    korrus666
    Level 40  
    Help: 584
    Rate: 476
    There seems to be one more issue, namely the efficiency of the power supply. At low load, a power supply with higher maximum power will certainly have lower efficiency and will draw more current than a power supply that works at, say, 70% of its maximum power.
  • #11 12291430
    BILGO
    Help: 393
    Rate: 725
    Colleague korrus666 I write well. The ATX power supply has the best efficiency if it is loaded from 60% to 70% of the rated power of the power supply. So if the author of the topic is thinking about expanding the computer, he can buy this 600W ... And if not, I would advise against buying this 600W power supply because it is a waste of money.
    The question remains, what brand is this power supply? If it is "Chinese" then 600W is definitely not ... so it should be loaded in about 65% of its real power :D
  • #12 12292445
    tadziq88
    The question is, what brand is this power supply? If it is "Chinese" then 600W is definitely not ... so it should be loaded in about 65% of its real power :D
    SilentiumPc Deus G1 80Plus Bronze 600W
  • #13 12292496
    BILGO
    Help: 393
    Rate: 725
    In my opinion, it makes no sense to spend money down the drain ... Anyway, the brand is also so bland ...
    Specify exactly what is in the computer casing? and we will tell you which power supply to buy for this set.
  • #14 12292778
    tadziq88
    There is
    Drive
    WD Blue WD5000AAKX
    AMD HD 6670
    AMD X2 +5600
    MOBA
    and framework
    It will probably replace with
    I postponed the Intel Core i5 processor because the prices will be different after the payment
    MOBA for it
    Ram
    + SDD
    + new graphics at the end
  • #15 12292813
    swiercm
    Moderator on vacation ...
    Help: 1216
    Rate: 552
    You can see that you have little idea about power supplies. As for you, SilentiumPC with 80+ is "unremarkable", I have no more questions.
    Please read the tests and opinions about branded PSUs, for example in the pages of the electrode, This brand is one of the FEW brands that produce power supplies at a reasonable price, to which no one has complained about a malfunction.
    tadziq88 wrote:
    There is
    Drive
    WD Blue WD5000AAKX
    AMD HD 6670
    AMD X2 +5600
    MOBA
    and framework
    MOBA for it
    Ram
    + SDD
    + GPU
    For this set, the younger brother, the SilentiumPC 300W DEUS, will be perfect. You can also target other brands, e.g. XFX450W or Corsair450-500W. It all depends on your budget.
  • #16 12300587
  • #17 12306149
    tadziq88
    Thanks for the help :) I already know that I can connect a more powerful power supply without scruples.
  • #18 12306174
    swiercm
    Help: 1216
    Rate: 552
    Of course you can. Let me put it this way - it is even very advisable that the power supply has a power reserve. There are several reasons that you already know about, and I will also write that the operation of the power supply at 100% does not bode too long for it. Very often, when the power supply is too weak, its capacitors are damaged.
Connecting a 600W power supply to equipment requiring 300-350W is generally safe and poses no contraindications. Power supplies draw only the amount of power needed, so using a higher wattage supply will not lead to excessive energy costs. However, it is important to ensure that the power supply operates under a sufficient load, as some models may require a minimum load to function properly. Efficiency can be lower at low loads, and it is recommended to operate power supplies at 60-70% of their rated capacity for optimal performance. The SilentiumPC Deus G1 80Plus Bronze 600W was mentioned as a potential choice, but users were advised to consider their future upgrade plans and the overall efficiency of the power supply.
