[Solved] Netia Player Decoder Netia Player Decoders N7800-4-AB2 - configuration
arteko 12009 5
  • #1 17123903
    arteko
    Rate: 115
    I have a modem (router) from Netia on the telephone line and Netia Player N7800-4-AB2 Decoders on which I receive television programs.
    One of the set-top boxes connected another operator to the internet and I have applications but I don't have TV channels.
    In the decoder settings you can enter DNS proxy etc.
    Can you configure the decoder to receive TV programs on another network without working with a Netia router?
    arigato
    Help: 81
    Rate: 85
    I'm afraid my colleague won't overcome this problem.
    I would compare it to the situation when we try to receive OIRT frequencies using a radio tuner with CCIR band. One excludes the other.
    Without settings for an internet connection, a colleague already receives what the tuner allows. Had to bite into the so-called software (replacing "BIOS" ;) this device would probably do the trick. I don't even want to try again ...
    Too much of it, and the game is probably not worth the candle.
    I suspect that even after a successful upgrade it would turn out that without any plug-in there programs will be displayed as a "small picture", or the sound will be available only then ...
  • #3 17124022
    arteko
    Rate: 115
    I asked because a colleague told me that he had called the Netia hotline and was told that it was possible but they were not allowed to provide such information. Perhaps it was a friend's bluff or a hotline.
    Apparently, this would involve manual configuration by entering the appropriate Proxy server address.
  • #4 17124172
    seb235
    Help: 98
    Rate: 73
    Just remember that these devices, i.e. both netia spot and netia player are netia devices, if you do not return them you will have to pay for them and it is not too low, because netia spot is PLN 300 and PLN 500 for player also comes to PLN 1300.
    KOCUREK1970
    Help: 3786
    Rate: 5326
    If the tv signal is provided by Netia via IPTV - then only on their internet it will work.
  • #6 17903068
    arteko
    Rate: 115
    no solution
