Table Drill Comparison: Bass Polska 300W vs Parkside PTBM 500 for Hobby Work in Steel Profiles
gajuss 5031 9
Which bench drill should I choose for hobby drilling of a few 8–10 mm holes in 2–3 mm steel profiles, comparing Bass Polska 300W and Parkside PTBM 500?
At this price level both drills are basically similar Chinese machines, so choose mainly by power, quill travel depth, and total weight — heavier is better — rather than by brand. [#17129558] They are suitable for hobby work, but you should expect to adjust and improve them instead of unpacking and drilling immediately. [#17129558] The main benefit of a bench drill is keeping the drill axis perpendicular to the material; the hole spacing itself depends mostly on accurate marking and layout, not on the drill model. [#17128757][#17128771] A hand-drill attachment can help with vertical drilling, but on narrow profiles its usefulness is uncertain, and for the table a vise or cross vise is recommended because the standard table can flex under pressure. [#17129230][#17129558]
  • #1 17128722
    gajuss
    I have a dilemma which drill to choose from the topic.
    For hobby work. I plan to make a few fi8-10 holes in steel profiles, 2-3 mm thick.
    Maybe someone will comment on quality, accuracy, spare parts, etc.
    The power is known to be great in both cases.
    Please forgive yourself the offer to buy a table drill, e.g. ws15.16. Not this price range.
  • #2 17128732
    stanislaw1954
    Help: 2019
    Rate: 4689
    An ordinary handheld (portable) drill is not enough for several holes ? 8-10 mm?
  • #3 17128735
    zbich70
    Help: 1171
    Rate: 6681
    Down several holes are you going to buy a bench drill?
  • #4 17128738
    gajuss
    I want to drill profiles, e.g. 40x20x3
    They must be reasonably precise as to the distance between them. Later they will be vertical and the other two will be connected to them to form a movable connection.
    I honestly thought about this solution.
  • #5 17128757
    zbich70
    Help: 1171
    Rate: 6681
    I still do not understand. With a table drill you achieve axial precision of the drill guide in relation to the material.
    The accuracy of the distance between the holes depends mainly on the marking and marking, not the type and quality of the drill.
  • #6 17128771
    stanislaw1954
    Help: 2019
    Rate: 4689
    And this is probably the essence of the purchase, because sometimes it is difficult to guide a hand drill exactly vertically or horizontally through the material being drilled.
    If I had to make a few precise holes in several elements, I would either use a stationary drill from a friend (if I don't have mine), or I would be tempted to make a template so that the repeatability of the holes is accurate.
  • #9 17129307
    gajuss
    If we call the first (leading) hole at a different distance than the second (leading) hole in a given place of the closed profile in relation to the previous hole drilled elsewhere in the profile, it will not be axially guided, the drill and the drill will not be perpendicular. That's the main point. Drill attachments? I've been wondering about that. However, on narrow profiles, I don't know if they will work. Back to the topic. Do you have experience with the described models?
  • #10 17129558
    Parowy
    Help: 55
    Rate: 227
    Welcome.
    Everything in this price range is similar Chinese, they differ in clothes, power and price, the quality is similar.
    Take into account the power, the depth of the quill extension, the weight of the entire clipper (the heavier the better), and be mentally prepared for improving the manufacturer :)
    They are suitable for hobby work, you need to learn how to use them, because you will not unpack, put together and drill.
    What will certainly be improved is supporting the table on a vise, under pressure it will bend and the hole will not be perpendicular.
    You can buy a cross vise and put it on the base of the drill, this way you will eliminate the deflection of the table but not the column on which the body is attached :)
    In fact, it should be a separate field of modeling - the use of modern metalworking tools :)
The discussion revolves around the choice between the Bass Polska 300W and Parkside PTBM 500 table drills for hobby work involving drilling precise holes in steel profiles (2-3 mm thick). Users emphasize the importance of axial precision and the challenges of using handheld drills for accurate hole placement. Suggestions include using templates for repeatability and considering the weight and stability of the drill setup. Both models are noted to be similar in quality, primarily sourced from China, with users advised to be prepared for potential modifications to improve performance. A cross vise is recommended to enhance stability during drilling.
