Raspberry Pi Time Setting: Retaining Date after Reboot with Pixtend RTC & Disconnected from Network
ienecode 10971 4
  • #1 17129644
    ienecode
    Rate: 96
    Problem setting time in RPI.
    If I connect to the internet and update the system, then RPI is the current date.
    When I change the date with the command: sudo date -s .... then the date changes but until the next restart ...
    How can I keep the date after rebooting?
    I say when RPi disconnected from the network. I'm using RTC with a Pixtend base.
  • #2 17129766
    ircmaniak
    Help: 7
    Rate: 9
    1. sudo raspi-config
    2. Internationalization options
    3. Change Time Zone
    4. Select geographical area
    5. Select city or region.
    6. Reboot your pi.
  • #3 17130447
    ienecode
    Rate: 96
    I have already done so.
  • #4 17132443
    ircmaniak
    Help: 7
    Rate: 9
    One of the most frequently mentioned disadvantages of the Raspberry Pi set is the lack of RTC hardware that would allow correct reproduction of system time in the event that no other synchronization sources (such as NTP server) are currently available.
    Read here you have the solution => link
  • #5 17143127
    ienecode
    Rate: 96
    Unfortunately, you cannot disable NTP, throws out warnings:
    warning: current stop runlevel (s) (2 3 4 5) of script `ntp 'overrides LSB defaults (empty).
