Decoding ABS Pump MK60 EC1 MK60EC1 J104 Hardware for Audi A3 8P with OBDeleven Pro Interface
hakerrlz 12366 2
  • #1 17136085
    hakerrlz
    Hello, I need help coding the ABS pump mk60 ec1 MK60EC1 J104 hardware 1K0907379AJ H30 version 0107 VIN WAUZZZ8PAA131527 audi a3 8p English rhd after connecting the clocks from another audi to check if the ABS driver lost the coding. I have an obdeleven pro interface which I can enter coding after entering the login. Can someone help decode the code?
  • #3 17156246
    hakerrlz
    witam, wciaż nie rozwiazalem problemu, po generowaniu kodu kalkulatorem sterownik wciaz nie przyjmuje. wyskakuje kod 31.
    ponizej wklejam log, moze ktos pomoc wygenerowc kod?
    Saturday,07,April,2018,19:55:04:16946
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.8.1.0 (x64)
    Data version: 20171130 DS276.6
    www.Ross-Tech.com
    VIN: WAUZZZ8P8AA131527 License Plate: PE10XHH
    Mileage: 160060km-99456mi Repair Order: 1
    Chassis Type: 8P-AU35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72
    VIN: WAUZZZ8P8AA131527 Mileage: 160060km-99456miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
    Part No SW: 03L 906 023 M HW: 03L 906 023 L
    Component: R4 1.6l TDI H23 9979
    Revision: --H23--- Serial number: AUX7Z0J0FNT0J9
    Coding: 00114014030501080000
    Shop #: WSC 00562 562 91545
    ASAM Dataset: EV_ECM16TDI02103L906023M 003017
    ROD: EV_ECM16TDI02103L906023FL.rod
    VCID: 306F76F66B6161C621-8064
    1 Fault Found:
    7196 - Function Restriction due to Faults in Other Modules
    U1113 00 [101] - -
    Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 15
    Mileage: 160064 km
    Date: 2018.03.26
    Time: 22:14:52
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 30 °C
    Intake air temperature: 12 °C
    Ambient air pressure: 970 mbar
    Voltage terminal 30: 12.198 V
    Unlearning counter according OBD: 40
    Engine speed: 0 /min
    Accelerator position: normalized-Accelerator position: 0.00 %
    Battery voltage: 11.2 V
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AJ HW: 1K0 907 379 AJ
    Component: ESP MK60EC1 H30 0107
    Revision: 00H30001
    Coding: 00000000000000000000000000000000000000
    Shop #: WSC 06314 000 00000
    VCID: 7AFB94DEF59D6B96DF-802E
    4 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 80
    Time Indication: 0
    Date: 2018.03.26
    Time: 22:14:56
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 20992
    Count: 195
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 80
    Mileage: 160064 km
    Time Indication: 0
    Date: 2018.03.26
    Time: 22:14:55
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 20992
    Count: 279
    Count: 43776
    Count: 0
    Count: 1024
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 80
    Mileage: 160064 km
    Time Indication: 0
    Date: 2018.03.26
    Time: 22:14:55
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 20992
    Count: 295
    Count: 43776
    Count: 0
    Count: 1024
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 80
    Mileage: 160064 km
    Time Indication: 0
    Date: 2018.03.26
    Time: 22:14:55
    Freeze Frame:
    Count: 3
    Count: 0
    Count: 20992
    Count: 270
    Count: 43776
    Count: 0
    Count: 1024
    Count: 0
    Address 08: Auto HVAC Labels: None
    Part No SW: 8P0 820 047 D HW: 8P0 820 047 D
    Component: J255 Klima Man H08 0060
    Revision: 00H08004 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 316973F2A86B68CE2E-8064
    No fault code found.
    Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
    Part No SW: 8P0 907 063 HW: 8P0 907 063
    Component: BCM PQ35 B 105 0575
    Revision: 00105 AK
    Coding: 0E000A2FB005F0C0202041E00000005C431229AA004DC122E4008F800041
    VCID: 71E9B3F2A8EB28CE6E-8024
    Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
    Component: Wischer AU350 H10 0040
    Coding: 00DD13
    Subsystem 2 - Part No: 8P0 951 177
    Component: Innenraumuebe H04 0020
    Subsystem 3 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 4 - Part No: 1K0 907 719 C
    Component: Neigungssenso 005 0003
    Address 15: Airbags (J234) Labels:| 8P0-959-655-10.clb
    Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
    Component: Airbag AU1042 H06 0160
    Revision: -------- Serial number: 003FB005JSLG
    Coding: 30314238303830303037554A305238503053
    ASAM Dataset: EV_Airba10AURB4 001001
    ROD: EV_Airba10AURB4.rod
    VCID: 4FAD150A169F1E3E58-801A
    Crash sensor for side airbag: driver side:
    Serial number: 3572DRB40000AAD5121S
    Crash sensor for side airbag: front passenger side:
    Serial number: 3582DRB40000AAA53A3
    Crash sensor for side airbag: rear: driver side:
    Serial number: 35128RB4000055CAA29S
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 35228RB4000054FBBE1.
    Crash sensor for front airbag: driver side:
    Serial number: 35547RB400005602DD8R
    Crash sensor for front airbag: front passenger side:
    Serial number: 35647RB400005602DD7R
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 DB HW: 1K0 953 549 DB
    Component: J0527 037 0070
    Coding: 0000002
    VCID: 75E187E21C8304EEB2-8020
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
    Part No SW: 8P0 920 952 A HW: 8P0 920 952 A
    Component: KOMBIINSTR. VDO H03 0980
    Revision: D0H03005 Serial number: 1240J005000877
    Coding: 0004428
    Shop #: WSC 12345 111 45725
    VCID: 34677AE657795DE645-8060
    Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
    Part No SW: 1K0 907 530 AF HW: 1K0 907 951
    Component: J533 Gateway H17 0233
    Revision: H17 Serial number: 1521J10204032F
    Coding: E9807F06000202042103
    VCID: 6BD5A19A4AC7C21E54-803E
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Revision: D0H03005 Serial number: AUX7Z0J0FNT0J9
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
    Part No SW: 8P0 959 801 N HW: 8P0 959 801 N
    Component: Tuer-SG H04 0100
    Coding: 0131764
    VCID: 4683302E31E5DF76EB-8012
    1 Fault Found:
    00943 - Heated Exterior Mirror; Driver Side (Z4)
    012 - Electrical Fault in Circuit
    Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
    Part No: 1K0 909 144 J
    Component: EPS_ZFLS Kl. 232 3001
    Revision: 00H17000
    Shop #: WSC 02069 000 90108
    1 Fault Found:
    03803 - Steering Angle Sensor for Steering Aid
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 160064 km
    Time Indication: 0
    Date: 2018.03.26
    Time: 22:14:58
    Freeze Frame:
    Battery Volts: 12.3 V
    DD
    Temperature: 13.0°C
    Count: 3
    Steering Angle: 0.00°
    Count: 1
    SteerAng n.Init
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 8P0 959 802 N HW: 8P0 959 802 N
    Coding: 0131764
    VCID: 479D3D2A36EFC67E10-8012
    Address 56: Radio Labels: 8J0-035-1xx-56.clb
    Part No SW: 8P0 035 152 E HW: 8P0 035 152 E
    Component: R Chorus2+ H03 0280
    Revision: 00H03000 Serial number: AUZ1Z2K6131409
    Coding: 0000021
    VCID: 2D516F82B4530C2E0A-8078
    Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
    Part No SW: 1K0 907 534 HW: 1K0 907 951
    Component: Batt.regelung H17 0233
    Revision: -------- Serial number: 1521J10204032F
    Coding: 0303085A
    VCID: 68DFDE969B31E90639-803C
    Subsystem 1 - Part No SW: 1K0 915 181 C HW: 1K0 915 181 A
    Component: J367-BDM H07 0125
    Serial number: 00000000002790933362
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
    Component: Tuer-SG H04 0050
    Coding: 0131216
    Shop #: WSC 06314 000 1012544
    VCID: 428B2C3E1DCDE356C7-8016
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
    Coding: 0131216
    VCID: 4385293A02D7EA5ECC-8016
    End-------------------------(Elapsed Time: 02:02)--------------------------
