VCDS Clone Hex V2 Not Supporting ABS Module on 2019 Audi Q3 MQB Platform
andre_23 1788 2
  • ABS adaptations rejected on 2019 Audi Q3 MQB
    #1 21480150
    andre_23
    I would like to ask the VCDS clone experts what I can do about my problem with the VCDS real hex v2 clone not supporting all modules? The ST32F ARM plug-in chip, supposedly was supposed to support all new VAG group cars. I have a 2019 Audi Q3 car with MQB platform. Generally VCDS in the English version 24.7.0, (seems to me the most reliable, and certainly more reliable than the Polish version) runs via the V2PP loader and works fine. I have a problem with the ABS controller, I can't code and adapt, even though of course the security access I enter is required by the controller. The security codes are accepted and the coding and adaptation are rejected. It rejects correctly entered encodings and adaptations. At the moment I want to activate the retrofitted auto hold button. Generally in other controllers encodings and adaptations are accepted, the problem I have noticed is in the ABS controller. I can enter the coding in the ABS without any problem with Car Scanner Pro with V gate interface after Bluetooth, but any adaptations in the ABS unfortunately I cannot do with this application. Is it possible to do something about this so that this VCDS program with a cable on this chipset will also fully handle this ABS controller? Alternatively, do you know of any free or inexpensive phone app that will embrace any adaptations in the VAG after the V gate interface? I would like to get this auto hold working, and when I enter the coding alone, without adaptations it throws errors. Thanks in advance for any help or suggestions.
  • #2 21905835
    koszmarnygames
    I also have the same cable 24.7 English version and I had a problem coding the abs pump in a4 b6 after changing from automatic to manual, obd eleven handled it without a problem.
  • #3 21905857
    danielzy
    Help: 167
    Rate: 319
    You won't do everything with a rice clone and that's the reason. Only the original.
