Passat B7 2.0TDI 2012: ABS 3AA 614 109 AQ & Parking Brake 3AA 907 801 H Coding, Error 1042 & 1044
Raywood 15075 7
  • #1 17053393
    Raywood
    Help: 5
    Rate: 16
    Needs coding for ABS and parking brake. Error 1044 and brake 1042 incorrectly coded.
    ABS no.
    3AA 614 109 AQ
    Parking brake no.
    3aa 907 801 H.
    Car
    Passat b7 2.0tdi 2012
    Manual gearbox
  • #2 17056266
  • #3 17113446
    Raywood
    Help: 5
    Rate: 16
    Hello, coding is still for me.
    Maybe I can present my problem.
    The Passat got the second dose with the kessy system so everything changed.
    Ie. :
    -Engine ECU
    -Counter
    -Steering wheel lock
    -Kessy module
    And now I'm getting tired of coding this contraption.
    The donor was in the machine.
    I am asking for advice on how to deal with it. It is mainly about coding with errors and bundles for door handles.
    It is interesting that the abs and parking brake had no coding after replacing the rest of the stuff. And those two were not touched.
    I leave the VCP autoscan:
    Spoiler:
    VCP + K v8.2.0 04/24/2017 Green Worm Protokol autoscan
    Adressword: 01 (Engine electronics} - J 623 R4 2.0L EDC
    VAG number: SW: 03L906018RE HW: 03L907309AE
    SW version: 4780
    # Coding: 001D0012043601080000
    ASAM: UDS, EV_ECM20TDI01103L906018RE 003003
    DATASET:
    >>> Errors found
    00126E (U010100) Transmission Control Unit No Communication (Lost Communication with TCM)
    Adressword: 03 (Brake electronics} - J104 C2 450M VD6A
    VAG Number: SW: 3AA614109AQ HW: 3AA614109AQ K03 ----
    SW version: 0030
    # Coding: 0003504
    ASAM: TP2.0, CANT = 300 CANE = 790
    DATASET:
    >>> Errors found
    0414 Controller not properly coded
    0C81 Overboost adjustment
    0522 Engine control unit
    Adressword: 53 (Parking brake} - J540 EPB4 VW-86594
    VAG Number: SW: 3AA907801H HW: 3AA907801H
    SW version: 0010
    # Coding: 0022167
    ASAM: TP2.0, CANT = 300 CANE = 794
    DATASET:
    >>> Errors found
    0523 Gearbox control unit
    04FF Longitudinal acceleration sensor
    Adressword: 04 (Steering angle sensor} -
    VAG Number: SW: HW:
    SW version:
    # Coding:
    ASAM: No communication.
    DATASET:
    >>> Errors found
    Adressword: 44 (Power steering system} - J500__APA-BS KL.313
    VAG Number: SW: 5N1909144P HW: 5N1909148J * H040000
    SW version: 1202
    # Coding: 0000258
    ASAM: TP2.0, CANT = 300 CANE = 7A8
    DATASET:
    >>> Errors found
    0236 Operating mode of the power steering
    09F2 Steering end position
    030A Steering angle sensor
    0524 Control unit for the brake system
    Adressword: 15 (Airbag} - J234__107 VW10 HI
    VAG Number: SW: 5N0959655AA HW: 5N0959655AA 00300L7
    SW version: 2118
    # Coding: 0012343
    ASAM: TP2.0, CANT = 300 CANE = 768
    DATASET:
    >>> No faults found.
    Adressword: 10 (Parking signal 2} - J446 PARKHILFE 8K
    VAG Number: SW: 3AE919475C HW: 7N0919475
    SW version: 0018
    # Coding: 108002
    ASAM: UDS, EV_EPHVA18VW47X0000 001006
    DATASET:
    >>> Errors found
    C21200 (U112100) Data bus, no information (Steuergerät für Lenksäulenelektronik-J527 / BCM - mZAS_1 - kein Signal / keine Kommunikation)
    C14620 (U112100) Data bus, no information (Diagnose-Interface für Datenbus-J533 - mGate_Komf_1 - kein Signal / keine Kommunikation)
    Adressword: 17 (Instrument cluster} - J285 KOMBI
    VAG Number: SW: 3AA920881A HW: 3AA920881A
    SW version: 0705
    # Coding: 121F00
    ASAM: UDS, EV_Kombi_UDS_VDD_RM09 A04727
    DATASET: -----------
    >>> No faults found.
    Adressword: 25 (Immobilizer} - IMMO 090
    VAG number: SW: 3AA959799E HW: 3AA959799E 0080000
    SW version: 0409
    # Coding: 0000000
    ASAM: TP2.0, CANT = 300 CANE = 781
    DATASET:
    SLAVE [1] Part number: 3C0905861J
    ELV 029 SW: 0380 HW:
    Coding: 0000000
    >>> Errors found
    0AFC Electronic steering column lock Terminal 30 supply voltage
    Adressword: 09 (Central Electronics} - J519 BCM PQ47 M
    VAG Number: SW: 3AA937087F HW: 3AA937087F
    SW version: 0465
    # Coding: 0008000000000000009800805400006403510088426D85606480C7200041
    ASAM: TP2.0, CANT = 300 CANE = 338
    DATASET:
    SLAVE [1] Part number: 3AB955419
    Wischer 05021 SW: 0603 HW: 3AB955419
    Coding: 00B795
    SLAVE [2] Part number: 1K0955559AH
    RLS 070 313 05 SW: 0403 HW:
    Coding: 02302A
    >>> Errors found
    003B Terminal 30 interior lighting
    0099 Driver Side Wiper Motor
    00B9 Control of terminal 15 voltage supply relay
    013D Rear cover control unit
    0342 Signal, rear window heater control
    039F Terminal 30 right side
    0513 Diagnostic Data Bus Interface
    051D Power steering control unit
    0538 Comfort System Data Bus
    05ED Trailer recognition controller
    05EE Left reversing light bulb
    05F0 Rain and light recognition sensor
    0708 Light switch
    082C Electronic seat heating unlocking
    0893 Lighting control for switches and indicators
    0CC2 Control of the horn relay
    Adressword: 46 (Central module of the Comfort system} - 02 KESSY PQ47 090
    SW version: 0375
    # Coding: 01900A00D2C30E76340494157E004F0E005800100427BC
    ASAM: TP2.0, CANT = 300 CANE = 329
    DATASET:
    Sounder n.mounted SW: HW:
    Coding: 0000000
    NGS n.mounted SW: HW:
    Coding: 0000000
    SLAVE [3] Part number:
    IRUE n.mounted SW: HW:
    Coding: 0000000
    SLAVE [4] Part number:
    ViP No Answer SW: HW:
    Coding: 0000000
    >>> Errors found
    00BE Contact sensor for outside driver's door handle
    00BF Front passenger door exterior handle sensor
    00C0 Contact sensor outside rear left door handle
    00C1 Contact sensor outside rear right door handle
    0529 Airbag control unit
    01C9 Vehicle electrical system control unit
    00EC Antenna 2 entry permit and start inside the car
    0214 Supply voltage
    0B34 Antenna in luggage compartment, left Entry and start authorization system
    Adressword: 42 (Driver door electronics} - J386 TUER-SG FT
    VAG Number: SW: 3AA959701A HW: 3C0959793C
    SW version: 0533
    # Coding: 0200B7
    ASAM: UDS, EV_TSGFPQ35BRFVW46X A04001
    SLAVE [1] Part number: 3AA959703A
    J388__TSG-HL SW: 0503 HW: 3AA959795
    Coding: 010090
    >>> Errors found
    010A02 (U111100) Operation restriction due to lack of information (Front CAN KSG)
    010A04 (U111100) Operation restriction due to lack of information (Front CAN BSG)
    010A06 (U111100) Operation restriction due to lack of information (Front CAN Kombi)
    010A07 (U111100) Operation limited due to lack of information (Front CAN gateway)
    010A0B (U111100) Operation restriction due to lack of information (Front CAN AirBag)
    010A0C (U111100) Operation restriction due to lack of information (Front CAN MSG)
    Adressword: 52 (Front passenger door electronics} - J387 TUER-SG BT
    VAG Number: SW: 3AA959702A HW: 3C0959792C
    SW version: 0533
    # Coding: 0200B6
    ASAM: UDS, EV_TSGBPQ35BRFVW46X A04001
    SLAVE [1] Part number: 3AA959704A
    J389__TSG-HR SW: 0503 HW: 3AA959794
    Coding: 010090
    >>> Errors found
    Adressword: 62 (Rear Left Door Electronics} -
    VAG Number: SW: HW:
    SW version:
    # Coding:
    DATASET:
    >>> Errors found
    Adressword: 72 (Rear Right Door Electronics} -
    VAG Number: SW: HW:
    SW version:
    # Coding:
    DATASET:
    >>> Errors found
    Adressword: 16 (Steering column electronics} - J527 LENKS.MODUL
    VAG Number: SW: 3C9953501BN HW: 5K0953569AB
    SW version: 0140
    # Coding: 118A250000
    ASAM: UDS, EV_VW360SteerWheelUDS A03004
    SLAVE [1] Part number: 3C8959537D
    E221__MFL-TK6 SW: 0022 HW: 3C8959537D
    Coding: E20000
    >>> Errors found
    051364 (U112100) Data bus, no info (Datenbus fehlende Botschaft)
    116802 (B116854) Steering angle sensor None Basic settings (Geber für Lenkwinkel keine Grundeinstellung)
    Adressword: 08 (Air conditioning / heating electronics} - J255 Climatronic
    VAG Number: SW: 3AA907044AG HW: 3AA907044AG
    SW version: 0303
    # Coding: 0014004803
    ASAM: UDS, EV_Climatronic A01010
    DATASET:
    >>> Errors found
    D11100 (U111100) Operation restriction due to lack of information (Motorsteuergerät - kein Signal / Kommunikation)
    D11120 (U111100) Operation restriction due to lack of information (Diagnoseinterface für Datenbus - kein Signal / Kommunikation)
    D11330 (U111300) Operation limitation due to incorrect value received (Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen)
    D11150 (U111100) Operation restriction due to lack of information (Steuergerät im Schalttafeleinsatz - kein Signal / Kommunikation)
    Adressword: 37 (Navigation System} - J794 RNS315-EU
    VAG Number: SW: 3C8035279R HW: 3C8035279R
    SW version: 0500
    # Coding: 000004110400110000019002
    ASAM: UDS, EV_RNS315EUV2UDS 001705
    DATASET:
    SLAVE [1] Part number: 3AA919866
    EUR_W_V6 SW: 0062 HW:
    Coding:
    >>> Errors found
    100050 (U111100) Operation limited due to lack of information (CAN TO BSG)
    100055 (U111100) Operation restriction due to lack of information (CAN TO park distance control)
    10004C (B104813) Phone microphone Break (microphone for phone open load)
    100041 (U101400) Driver incorrectly coded (ECU wrong coded)
    Adressword: 56 (Radio} -
    VAG Number: SW: HW:
    SW version:
    # Coding:
    DATASET:
    >>> Errors found
    Adressword: 77 (Phone} - J412 Phone
    VAG Number: SW: 3C8035730C HW: 3C8035730C
    SW version: 0822
    # Coding: 020000000000000000000000
    ASAM: UDS, EV_UHVPremi A02705
    DATASET:
    >>> Errors found
    D40000 (U140000) Operation limitation Due to undervoltage (Funktionseinschränkung durch Unterspannung)
    D01200 (U101200) Supply voltage Voltage too high (Versorgungsspannung Spannung zu hoch)
    D40100 (U140100) Operation limitation Due to overvoltage (Funktionseinschränkung durch Überspannung)
    C14000 (U014000) Computer 1 / car EC / ECU No communication (Bodycomputer 1 / Bordnetzsteuergerät / el. ZE keine Kommunikation)
    C21200 (U021200) Steering column electronics control unit No communication (Steuergerät für Lenksäulenelektronik keine Kommunikation)
    D00900 (U014600) Diagnostic Interface Driver No Communication (Diagnose Interface-SG Keine Kommunikation)
    Adressword: 4F (Central Electronics 2} - J520 EZE_2
    VAG Number: SW: 7N0907532 HW: 7N0907530AH
    SW version: 1634
    # Coding: 00000008
    ASAM: TP2.0, CANT = 300 CANE = 32E
    DATASET:
    SW: HW:
    Coding:
    >>> No faults found.
    Adressword: 19 (Data Bus Diagnostic Interface} - J533 J533 Gateway
    VAG Number: SW: 7N0907530AH HW: 7N0907530AH
    SW version: 1634
    # Coding: 462006
    DATASET: 360067v____
    >>> Errors found
    017D Instrument cluster data bus
    01DA Immobilizer control unit
    0532 Central Comfort System Controller
    Adressword: 2E (Media Player 3} - J650 SG EXT.PLAYER
    VAG Number: SW: 5N0035342F HW: 5N0035342F
    SW version: 0550
    # Coding: 020100
    ASAM: TP2.0, CANT = 300 CANE = 4EC
    DATASET:
    >>> Errors found
    Adressword: 61 (Battery regulation system} - J840 Batt.regelung
    VAG Number: SW: 7N0907534 HW: 7N0907530AH
    SW version: 1634
    # Coding: 030F1859
    ASAM: TP2.0, CANT = 300 CANE = 32D
    DATASET:
    SLAVE [1] Part number: 1K0915181H
    J367-BDM SW: 0180 HW: 1K0915181A
    Coding:
    >>> Errors found
    08D0 Quiescent current
  • #4 17113921
  • #5 17116218
    Raywood
    Help: 5
    Rate: 16
    Post brake. takes your encoding.
    ABS further throws:
    SW version: 0030
    # Coding: 0003504
    DATASET:
    >>> Errors found
  • Manual gearbox ECU coding and software compatibility question
    #7 17425179
    RaywoodPL
    Help: 10
    Rate: 82
    Hello, after a long break.
    At the moment I am struggling with ecu passata. It displays a connection error with the gearbox. The ecu donor was in the machine and mine is the manual.
    The encoding doesn't go through vcp and I get a request message out of range.
    From what I have learned so far, the driver does not support the manual version because there is no map.
    And now it is enough to upload the appropriate software or replace the ecu and problems with immo?
    I am asking for help what to do next.
    Additional info:
    Driver No:
    03L906018RE
    EDC17C46
    I can get the ecu number 03L907309AE which is in the car with a manual gearbox for possible tests.
  • #8 17426066
    CAR pass
    Help: 41
    Rate: 240
    How can you try it from autopsy VCP sometimes doesn't code
    VCDS ver. 17.8 without problems
    If you have something to read EDC17 from this manual, read it and upload a dump. I will try to help
The discussion revolves around coding issues for the ABS (3AA 614 109 AQ) and parking brake (3AA 907 801 H) of a 2012 Volkswagen Passat B7 2.0TDI. The user reports errors 1042 and 1044, indicating incorrect coding. Responses include detailed coding information, error messages, and troubleshooting steps. Users suggest checking the coding against the provided hardware and software versions, and mention issues related to the Kessy system and ECU compatibility. Recommendations include using VCDS for coding and reading the EDC17 ECU for further diagnostics.
