Golf 5 - Question about the difference in tire height 195/65 - 195/60 - 195/55
krzysztofferr 17376 6
  • #1 17138640
    krzysztofferr
    Rate: 8
    I would like to ask for information on the difference in tire height (in cm) between the sizes (R15):
  • #3 17138728
    krzysztofferr
    Rate: 8
    Thank you very much.
    To make it easier for posterity, calculations show that the side height decreases by 1 cm (2 cm in diameter). For the second variant by 2 cm (4 cm in diameter).
  • #5 17138858
    krzysztofferr
    Rate: 8
    I counted well:
    In addition, it's worth knowing (as the graphics show) - the smaller the tire circumference, the lower the speed compared to the speedometer.
  • #6 17138891
    dizba
    Help: 239
    Rate: 805
    The height difference is 2 cm and the circumference decreases by about 6 cm.
  • #7 17139004
    Kenworth 18
    Help: 2415
    Rate: 3702
    As for the Golf V, the factory size on models on 15 "rims is 195 / 65-15 and the replacement is 205 / 60-15 and this should be kept.
✨ The discussion revolves around the differences in tire height for sizes 195/65, 195/60, and 195/55 on R15 rims, specifically for the Golf V model. It is noted that the side height decreases by approximately 1 cm for each size reduction, resulting in a total diameter decrease of 2 cm for the first comparison and 4 cm for the second. Additionally, it is mentioned that a smaller tire circumference leads to a lower speed reading on the speedometer. The factory size for the Golf V on 15" rims is confirmed to be 195/65-15, with a recommended replacement size of 205/60-15.
