Seat Ibiza 3 Wheel Sizes: 195/55 R15, 195/65 R15, 215/65,55 R15 & 16-inch Compatibility
M-X 12942 4
  • #1 16501654
    M-X
    Rate: 8
    Hello. I would like to ask what wheel size I could set up at the factory for 195/55 R15. Can I put on a size like 195/65 R15 or 215 / 65,55 R15 and can I put on a 16 inch wheel that's too big? Best regards.
  • #2 16501666
    WędkarzStoLica
    Help: 146
    Rate: 300
    The whole circle will be higher, the counter will (inflate) cheat.
    If you don't mind, make sure there is room to accept a higher tire.
    The fact that it will be wider doesn't seem to bother you, but it's also worth checking out.
    M-X wrote:
    16 inches already too big?
    Not too big, you just buy lower tires - it looks better and goes better in corners.
    The ideal replacement will be 195 / 50R16.
  • #3 16501800
    M-X
    Rate: 8
    And what about the width of the rims and the track width?
  • #4 16501844
    WędkarzStoLica
    Help: 146
    Rate: 300
    And what tires? For 195 max 7 / 7.5 inch tires.
    Bolt spacing, I think? I don't know what Ibiza has - look on the net.
    The most important is the ET rims.
    Are you just going to buy rims?
    Read about ET (weaning) and you will understand, then examine the car and choose the appropriate one. The point is that the wheel does not hide too much inside or get behind the fender.
  • #5 16502316
    CameR
    Moderator of Vehicle Security
    Help: 1139
    Rate: 3272
    Substitutes 195/55 R15 with the same rim diameter:
    15 ''
    135/80 R15
    0.2%
    165/65 R15
    0%
    175/60 R15
    -0.8%
    185/55 R15
    -1.9%
    185/60 R15
    1.2%
    205/50 R15
    -1.6%
    Substitutes 195/55 R15 with a different rim diameter:
    13 ''
    165/80 R13
    -0.2%
    185/70 R13
    -1.1%
    14 ''
    145/80 R14
    -1.3%
    155/80 R14
    1.3%
    165/70 R14
    -1.5%
    165/75 R14
    1.3%
    175/70 R14
    0.8%
    185/65 R14
    0.1%
    195/60 R14
    -1%
    205/60 R14
    1%
    16 ''
    175/55 R16
    0.6%
    185/50 R16
    -0.7%
    195/50 R16
    1%
    205/45 R16
    -0.8%
    215/45 R16
    0.7%
    225/40 R16
    -1.6%
    17''
    195/40 R17
    -1,3%
    205/40 R17
    0%
    215/40 R17
    1,4%
    225/35 R17
    -1%
    245/35 R17
    1,3%
    18''
    205/35 R18
    0,9%
    235/30 R18
    0,4%
    ABC KOM
    Barcelońska 77, Katowice, 40-683 | Tel.: 601XXXXXX (Show) | Company Website: https://www.auto-alarm.com.pl
