Audi A4 B5: Optimal Air Pressure for Goodyear 195/65R15 Tires? (Inflating Rounded Tires)
misterbociek 28464 5
  • Recommended 2.2 bar despite rounded tire profile
    #1 17205430
    misterbociek
    Help: 40
    Rate: 120
    Hello!
    I bought new goodyear 195 / 65r15 tires for the audi a4 b5 and the problem is that they do not have a flat face just round as in the picture. Well, I just do not know how to inflate them ... Dude what I mentioned tires gave the standard 2.2 bar and rather nothing will not be because the tires lag behind a very small surface (red line) and in the front I think it is OK (green line).
    Does anyone know how to inflate such a tire?
  • #2 17205591
    Jagkart
    2.2 bar is the safest pressure, generally the recommendation for your car should be on fuel infusion.
    By the way, MAX LOAD (pressure) and MAX PRESS (pressure in HPa) should also be written on the tires.
  • #3 17205603
    Gmitrij 17
    Help: 5
    Rate: 24
    It should be 2.2 bar by default, unless it is written differently.
  • #4 17205608
    RADU23
    Help: 2428
    Rate: 1732
    He did not give a colleague what the engine has in the car.
    Generally, it is separated. A4 B5 is practically the same as Passat B5.
    I have such a pressure distribution. Maybe my friend will use =>
    • Passat Ci_nienie opon.txt (7.21 KB) You must be logged in to download this attachment.
  • #5 17206641
    misterbociek
    Help: 40
    Rate: 120
    Thank you very much for the passport.
    1.8 apt 125koni
  • #6 17208562
    RADU23
    Help: 2428
    Rate: 1732
    1.8/92kW
    Tire sizes 195/65 R 15
    half load:
    - front (bar) 2.0
    - rear (bar) 2.0
    full load:
    - front (bar) 2.2
    - rear (bar) 2.7
