Peugeot 206 2.0 HDI Engine - Fluctuating Temperature Gauge and Fan Activation Issues
korndddd 18015 5
  • #1 17145108
    korndddd
    I fire up without a problem, but after a longer route of about 15 minutes, when the temperature is about 85 degrees, the temperature indicator reaches the maximum, and then the fan turns on, then the pointer drops, then the indicator goes to the maximum again, etc.
    Could this mean damage to the engine temperature sensor? 2.0 HDI engine
    It looks more or less like here
    https://www.youtube.com/watch?v=Mo6wJYejW4I
    piotrekwoj1
    Help: 947
    Rate: 3433
    Yes, it will be a damaged sensor, but the preview of the actual parameters or even the measurement of the resistance of this sensor will confirm it.
  • #3 17145133
    korndddd
    Ok. But is it an engine temperature sensor or a coolant temperature sensor? But when the mechanic checks me, I will be 100% sure?
    piotrekwoj1
    Help: 947
    Rate: 3433
    Fluid temperature sensor.
  • #5 17145371
    Aleksander_01
    Help: 1167
    Rate: 3435
    The defect is as old as the Peugeot 206, it is surprising that so many readers do not know the correct answer, and it is - a damaged relay (more often green) of the first gear of the radiator fan.
  • #6 17218321
    korndddd
    Yes, it's a coolant temperature sensor, not a first gear radiator fan. The entire repair took several minutes, the problem was solved.
