Peugeot 407 2.0 HDI: Oil/Coolant Temperature Range, Air Build-up, Overheating Post-Kapela Drive
phoe 13758 16
Why does my Peugeot 407 2.0 HDi overheat and push coolant out after a long climb, and what coolant temperature should it normally run at?
The most likely fault is a bad thermostat or another cooling-system problem, because this engine’s normal coolant operating temperature is about 82°C, so a reading around 60–65°C is too low [#17198043] [#17198117] Check for trapped air in the cooling system, verify that the radiator fan works in all stages, and do an exhaust-gas test in the coolant to rule out a head-gasket issue [#17198043] [#17198117] [#17198182] The fan may fail on the first stage without showing a dashboard warning, so the ECU should be scanned for errors and an actuator test performed with a diagnostic computer [#17198182] [#17198360] If you want to test the coolant temperature sensor itself, the reported values were about 6.2 kΩ at 20°C and 580 Ω at 80°C [#17203406]
  • #1 17197994
    phoe
    Help: 113
    Rate: 56
    At the outset, what should the temperature of the oil and coolant be while driving?
    Mi shows fluid temperature 60-65 °C (i.e. 1 dash above the minimum) and oil temperature 110-120 °C (half of the range)
    I think the temperature of the liquid is too low and I honestly don't know if it was like that before or if it was around 80-90 °C.
    I have a car for a short time (I did about 2,000 km with it), it is from a steady hand, so nothing was combined with it, etc.
    Returning today from Karpacz, with 2-3 km after driving "Kapela" (a large hill) between Jelenia Góra and Złotoryja, the car stated that it has little coolant (probably?) - the "cooler" control on the display between the clocks + sound signal and after a while the sign "STOP", so I drove from 500 meters and stopped.
    (coolant temperature around 70 °C, oil temperature 120 °C - i.e. normal)
    I opened the hood, as if everything was normal, the radiator fan was 100% off, I also had 100% coolant around the maximum (oil is also controlled by the oil), the expansion tank was not somehow very hot, I waited with the engine turned off around 5 minutes and out of curiosity, I gently and carefully unscrewed the cap from the reservoir, 1 hose as if it was sucking the liquid, the other one was sucking air into the reservoir, the reservoir is like 2-chamber - overflow and the result was about 2.5l of fluid spilling outside the reservoir ...
    ... hmm, okay, my (I think) stupidity, I had 1l of liquid with me, I added it, waited for a good 15 minutes for the car to cool down, there was a petrol station 8 km away, I bought 2 liters there and I added 2.5 liters in total - evenly to the max, so by the "eye" it was because of unscrewing the cork about 2 liters spilled out.
    The house was left with 50 km, after driving 25 km, I made a small stop, after a few minutes I unscrewed something there only hissed a little, so ok, another 25 km and I'm at home, after a few minutes of stopping, I unscrew the cap and the liquid breaks out again, I don't know how much that it crashed because I turned it back, waited another 15 minutes and it did not fire anymore.
    The fluid has not been replaced for a long time (the previous owner had a car for 3 years and knows little about it and does not know if it was replaced at all), the first 1l I added blue, the next 1.5l is pink, as if both are miscible with other liquids - so yes can stay for now?
    The liquid currently smells a bit like a burn, but it is not a very strong "smell", you just smell something there, and I smelled it, warm.
    Could something have happened or it just took air and this delicate burning smell is normal or the liquid has not been replaced for a long time?
    Tomorrow I would like to drive to work by car, and I have 25 km one way, and it is known that I will not be able to go to the mechanic.
    What do you think, any advice?
  • #2 17198014
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Perhaps the head gasket has just broken.
  • #3 17198031
    phoe
    Help: 113
    Rate: 56
    For what reason? Because the car did not give any symptoms ...
    It was hard to say that something hurt him, I changed the timing, oil in the box (because it is an automatic machine), engine oil, a set of filters and rods because they had small slack ... the mechanic also said that the car is ok, and he got it for the weekend to ride it a little.
    zadam64
    Help: 552
    Rate: 738
    Hello, I would suspect that the thermostat is inoperative, during the return ride you correctly vented the cooling system where you changed about 3 liters of fluid for 5.5 liters in the system
    Or maybe it was not a liquid that poured out, only water? Constant control of the quality of the fluid and its condition!
  • #5 17198062
    phoe
    Help: 113
    Rate: 56
    In winter, the car ran without problems, so if it did not freeze it was probably liquid?
    But as for this liquid, I poured pink and blue, and putting a handkerchief into the container out of curiosity to see the color of the liquid, it can be said that it is colorless, maybe slightly yellowish (no traces of oil).
    I have never penetrated these colors either, but something is wrong here?
  • #6 17198087
    zadam64
    Help: 552
    Rate: 738
    And after the return trip, all the pipes to and from the radiator were hot?
  • #7 17198094
    phoe
    Help: 113
    Rate: 56
    I did not check the pipes that thoroughly. The cooler had a temperature similar to the temperature of the tank, touching it for a fraction of a second felt "hot" - you know that with your hand otherwise and it's safe to check it. ;)
    And what exactly does the coolant indicator light mean between the clocks on the display? Too high temperature, too high pressure or too little?
    Temperature probably not, unless it has sensors in 2 different places?
    Level? It was almost max.
  • #8 17198117
    Adam1988
    Help: 49
    Rate: 161
    Do a coolant exhaust gas test.
    You have to replace the thermostat, the working temperature of this engine is 82 degrees. C.
    Also check that you have all gears of the radiator fan in working order, it is very important due to the automatic mechanism.
  • #9 17198137
    phoe
    Help: 113
    Rate: 56
    How? I know that a mechanic can do it, but it's nice to be sure that something works and you know how to check it.
    Adam1988
    Help: 49
    Rate: 161
    The computer, unfortunately, - test of actuators, the presence of errors.
  • #11 17198194
    phoe
    Help: 113
    Rate: 56
    There was only an error from the pillow, because the mechanic deleted it recently, and another question, of course, I bought the car at the beginning with a copied display (a factory defect and mine from 2007 was still caught) and I do not know if I could see this error from the pillow from the display level, but, for example, a burnt bulb, I can see what errors he gives me from the display?
    I know that Citroen C5 100% shows errors from EGR, clogged FAP or no refrigerant.
    Adam1988
    Help: 49
    Rate: 161
    Airbag error, for example, will show because it is quite an important system. Fap, egr will also show because it's EKOlogy :)
    Fan error (especially 1st gear) will not show.
    Of course, it will not show on the clocks because there will be an error in the engine controller.
    PS: as for the fluid level sensor, these sensors fall sometimes and show that there is no fluid while physically it is, the sensor is resistive, so the quality (age?) Of the fluid also has something to say :)
  • #13 17198379
    phoe
    Help: 113
    Rate: 56
    Adam1988 wrote:
    there is no fluid while it is physically there, the sensor is resistive so the quality (age?) of the fluid also has something to say :)
    So it could be "such a situation" that it was a message from a low fluid level, the fluid was, the sensor worked incorrectly, and I just have a thermostat screwed up and that's it?
    Everything else is ok, same with this 2l of liquid? If the system has a capacity of 5.5 liters, it "spat out" a bit.
    Added after 17 [hours] 11 [minutes]:
    That's 1 more question, does the 407 have a coolant level sensor?
    Because I was at the mechanic's today and he says no, and what he displayed was overheating of the engine from some sensor, it's good that I stopped, it was wrong that I moved the cap, the thermostat to be replaced, the fluid too, and rather that's a preliminary diagnosis.
    2 temperature sensors to be, or the tip can be kicked for me? But there is something wrong with the bank, because he was a mechanic during the stop and the fan did not turn on, and according to him it should already be.
  • #14 17202926
    Adam1988
    Help: 49
    Rate: 161
    Some have, the other not - a black cube on the tank
    the sensor is one.
    Computer connected or should it? Were there any mistakes? What temperature ? What control?
    If he has not connected and if he proposes to change the mechanic - seriously ...
  • #15 17202930
    phoe
    Help: 113
    Rate: 56
    Well, mine doesn't have a fluid amount sensor.
    He did not connect, because he did not have time, next week I will leave his car for him, he generally knows himself, so he will get it.
    Added after 4 [hours] 38 [minutes]:
    I was at another mechanic and I did not like him too much, a text like first PLN 150 for connecting to a computer and diagnosis, and then looking for what and how ... and the first one has no time yet.
    Do you know what the value of an efficient water temperature sensor in the thermostat should show on the ohmmeter? Because I will replace it myself without a problem, but I prefer to check it first, with the thermostat myself, it will be a bit of fun from what I looked at. And I measure it, I understand it with an ohmmeter, on the contacts after removing the cube from it?
    Adam1988
    Help: 49
    Rate: 161
    20st.C - 6,2kΩ
    80st.C - 580Ω
  • #17 17203417
    phoe
    Help: 113
    Rate: 56
    Ok thanks, I'll check tomorrow!
The discussion revolves around the Peugeot 407 2.0 HDI's oil and coolant temperature ranges, particularly after a drive that included a steep hill. The user reports coolant temperatures around 60-65 °C and oil temperatures between 110-120 °C, expressing concern that the coolant temperature seems low. After a drive, a warning indicated low coolant, prompting a stop. Responses suggest potential issues such as a faulty thermostat, air in the cooling system, or a malfunctioning coolant level sensor. Recommendations include performing a coolant exhaust gas test, checking the radiator fan operation, and verifying the thermostat's functionality. The user also inquires about the coolant level sensor's presence in their model and the expected resistance values for the temperature sensor.
TL;DR: On the 2.0 HDI, normal coolant is 82b0C; "Do a coolant exhaust gas test." If the gauge stays at 6065b0C while driving, replace the thermostat and verify both radiator-fan gears using actuator tests. [Elektroda, Adam1988, post #17198117]
Why it matters: This helps Peugeot 407 2.0 HDI owners fix low coolant readings, air build-up, and post-climb overheating fast.
What coolant temperature should my 2.0 HDI run at?
Expect about 82b0C once warmed up. If yours stays near 6065b0C while cruising, the thermostat likely sticks open. Replace it. Then confirm both radiator fan stages work using a diagnostic actuator test. "The working temperature of this engine is 82b0C." [Elektroda, Adam1988, post #17198117]
My oil shows 110120b0C while coolant is 6065b0Cwhat does that mean?
Oil can run hotter than coolant under load. But a coolant gauge stuck low points to a bad thermostat. Replace the thermostat and verify fan operation via actuator tests. That restores proper coolant regulation and helps oil temps stabilize. [Elektroda, Adam1988, post #17198117]
Why did coolant erupt when I opened the expansion cap hot?
You released hot system pressure. The expansion tank can vent violently and spray coolant. Do not open the cap when hot. Let it cool at least 15 minutes and use a cloth on the cap. Opening hot can also introduce air. [Elektroda, phoe, post #17198379]
Could this be a blown head gasket? How do I check?
Its possible. Run a coolant exhaust-gas (block) test at the tank. A positive result suggests combustion gases in the coolant and points to a head gasket issue. "Do a coolant exhaust gas test." [Elektroda, Adam1988, post #17198117]
Should I replace the thermostat if the coolant stays cold while driving?
Yes. A steady 6065b0C on the move indicates a stuck-open thermostat. The 2.0 HDI should regulate around 82b0C. Replace the thermostat and recheck warm-up behavior afterward. [Elektroda, Adam1988, post #17198117]
How do I test all radiator fan speeds?
Use a diagnostic computer to run actuator tests on the fan. 1) Connect to the car. 2) Open actuator tests and command low and high fan speeds. 3) Confirm both stages engage. Repair wiring, relays, or the fan if a stage fails. [Elektroda, Adam1988, post #17198182]
Does my Peugeot 407 have a coolant level sensor?
Some do, some dont. Look for a small black cube attached to the expansion tank. If present, the car can monitor the level. If absent, warnings generally relate to temperature, not level. [Elektroda, Adam1988, post #17202926]
Why did I get a low-coolant warning even though the tank looked full?
The level sensor is resistive and can misread when coolant quality degrades. Aging fluid can cause false low-level alerts. Sensors also fail. If warnings persist, renew coolant and consider sensor inspection or replacement. [Elektroda, Adam1988, post #17198360]
What does the coolant warning icon mean on the 407 cluster?
It can indicate overheating, and on versions with a level sensor it may also mean low level. In the case described, a mechanic read it as an overheating alert, not level. Confirm with a scan tool. [Elektroda, phoe, post #17198379]
How do I check the coolant temperature sensor with a multimeter?
Unplug the sensor and measure resistance across the pins. Expect about 6.2 ka at 20b0C and about 580 a at 80b0C. 1) Measure cold. 2) Warm the engine and remeasure. 3) Replace the sensor if readings are far off. [Elektroda, Adam1988, post #17203406]
Will radiator fan faults show on the dash?
Often not. A failed first gear of the fan may not trigger a cluster message. The fault can sit in the engine controller instead. Use diagnostics to read errors and run actuator tests. [Elektroda, Adam1988, post #17198360]
Are there one or two coolant temperature sensors on the 2.0 HDI?
Theres one coolant temperature sensor. It feeds the ECU and display. Diagnose the single sensor and its wiring if readings seem incorrect. [Elektroda, Adam1988, post #17202926]
Is it safe to keep driving after a STOP message or coolant alert?
No. Stop safely and let the engine cool. Do not open the cap hot. Arrange diagnostics to check thermostat, fan operation, and temperature readings before driving again. The mechanic feedback was that stopping was right. [Elektroda, phoe, post #17198379]
How much coolant does the 2.0 HDI system hold when refilling?
Plan for about 5.5 liters. That helps you estimate concentrate and distilled water needs during a full drain, flush, and refill. Bleed the system properly to remove air afterward. [Elektroda, zadam64, post #17198043]
