Best Chinese 4-Stroke Garage Generators: 2500W-3000W, AVR Voltage Stabilization, Budget 900 Zeta
alsababnur 8334 9
What power of a 4-stroke single-phase garage generator should I choose so that a drill or angle grinder does not slow down under load, while staying within a budget of about 900 zeta?
For single-phase devices, leave about a 20% power reserve in the generator [#16471005] A 2.2 kW generator was enough for a drill and a flex, but when a 2000 W flex was switched on, the unit’s engine sagged for a moment [#16436194] Another user bought a BOLTERO from Pezel for about 1000 and reported that it handled a 1300 W drill and a vacuum cleaner; the AVR worked dynamically at first and then stabilized [#17535445] If you want to run tools in the 800 W to 1300 W range without noticeable slowing, a 2500 W to 3000 W generator is a reasonable target based on these experiences [#16471005][#16436194][#17535445]
  • #1 16435975
    alsababnur
    Rate: 10
    I am just at the stage of purchasing a Chinese generator for the garage.
    I am interested in a 4-stroke unit because it is said to be quieter and there is no problem of making a mixture and one-phase.
    AVR voltage stabilization, although I will not connect the electronics.
    Manual start.
    Budget up to 900 zeta.
    It will be powered by a drill, some 800W or an angle iron, something around 1300W, maybe a vacuum cleaner, and in the future, maybe a small grinder, or a small compressor (300W - 1300W), and if not, it's hard.
    Everything works separately.
    The question is, what equipment from Alledrogo can be "invested" as safely and with what power of this device so that the drill or angle does not stop or slow down when pressing, I thought something like 2.500W - 3000W.
    I thought something about it:
    3000W AVR TAGRED PRO
    But I'd like to know some other proposition.
  • #3 16436177
    alsababnur
    Rate: 10
    Perhaps I would like someone to write what power is needed, so that nothing would be silted up at work and work like electricity at home.
  • #4 16436194
    lamerb
    Help: 86
    Rate: 166
    I once bought a 2.2kW generator in Castorama for the needs of one service at the construction site without electricity. The drill and the "flex" worked without any problems, although when the 2000W "flex" was turned on, the motor in the unit "sat" for a while. I'm not sure but it must have been "dedra". He earned himself a couple of times ;)
    He once "saved" the company's office after a serious power failure of ENEA.
  • #5 16471005
  • #6 16471030
    WędkarzStoLica
    Help: 146
    Rate: 300
    alsababnur wrote:
    Alledrogo
    Sorry for OT, but wherever I would not ask about it, it will come out the same.
    Why do so many people transform the name Allegro so insultingly, neither is it (censorship) any abbreviation, nor the actual and correct nomenclature, because allegro is cheaper than any store.
    I absolutely do not understand it. There are so cheap things on the Allegro that I would sooner call it Alletanio.
    Take a bicycle lamp with a laser as an example. On the Allegro PLN 10, in Carreforora about PLN 40. same identical. And there are millions of such examples.
    Someone shut down the brain by making up this slogan and people keep repeating it without thinking about it.
  • #7 16471233
  • Private sellers face different costs than stores
    #8 16471845
    alsababnur
    Rate: 10
    In that case, to the information that so cheap things come from China, bought for less than a dollar and sold on an all-inclusive basis, and probably the guest does not run a business and does not have to pay anything, and this is quite different than with a store.
    In addition, alledrogo was created for private people who have something to sell, something like a marmot and not for mass traders, and now it looks like a trade fair.
    And so many people prefer to expose to OLX already.
    Not to the point at all.
  • #9 17535445
    alsababnur
    Rate: 10
    I bought this unit for the price of one thousand, the choice fell on BOLTERO from Pezel.
    He managed a 1300 watt drill and vacuum cleaner, the AVR did some dynamic work, but eventually leveled off.
    I think the cutter fell, but I fixed it a bit :)
  • #10 17536387
The discussion revolves around selecting a suitable Chinese 4-stroke generator for garage use, specifically in the 2500W-3000W range with AVR voltage stabilization, within a budget of 900 zeta. Users share experiences with various models, emphasizing the importance of having a power reserve of about 20% to prevent equipment from stalling under load. One user mentions a 2.2kW generator from Castorama that successfully powered a drill and a "flex" tool, while another user recommends the BOLTERO model from Pezel, which handled a 1300W drill and vacuum cleaner effectively. The conversation also touches on the perception of online marketplaces like Allegro and Alledrogo, with some users expressing confusion over the negative connotations associated with these platforms.
