[Solved] Expanding Multi-Room Service with Third SAMSUNG ICU 100 Decoder: Possible with Orange?
Cairax 5448 2
  • #1 17152663
    Cairax
    Orange allows you to connect only 2 set-top boxes SAMSUNG ICU 100 to FunBox 3.0, I have both connected to a cable, of course the outputs in FunBox sa 4.
    If I could get and connect a 3rd samsung decoder, could I receive the signal normally in 3 places at home?
    I did not sign a contract for 2 years with orange their whole salesman assured that it is indeed a multi-room in 2 places but you can easily receive and in 4 rooms, he turned out to be a liar because even if I connected a 3ci tv with a decoder via this jack and 3x cinch, I would only have the image that someone switches the remote control in the decoder elsewhere. I think I lost my question. also:
    If I could get and connect a 3rd samsung decoder, could I receive the signal normally in 3 places at home? Can orange somehow block it or do some problems because of it?
    thank you in advance for your reply.
    bestboy21
    Level 40  
    Help: 566
    Rate: 782
    Decoders are assigned to the service. A foreign decoder will not work, even if the model is the same.
  • #3 17180522
    Cairax
    if so I don't buy this decoder, thanks
    topic is closed
