Unicable I, 2x ultrabox NC + - 2 4k ultrabox decoders for one unicable
wiktoriano85 6795 5
  • Question about using two Ultrabox decoders on one Unicable converter
    #1 16878299
    wiktoriano85
    Rate: 11
    I want to connect two NC + ultrabox decoders to one Unicable converter via a splitter
    In the ultrabox decoder you can choose the IDLB-QUDL42-UNI2L-1PP converter
    I inadvertently ordered the IDLU-QUDL42-UNR2L-1PP converter
    Will simultaneous recording of 3 programs and pause on 2 decoders work? i.e. 8 programs will pass through the converter.
    With one ultrabox it's logical that automatic settings, and with two manually? What channels etc?
    Best regards and please let me know.
  • #2 16878378
    andpol 33
    Help: 513
    Rate: 1146
    Sure, it won't work on both decoders because the converter only supports 4 channels. Besides, who will give you 2 UHD decoders, except on separate contracts.
  • Wideband LNB question for 4K recording and pause
    #3 16878808
    wiktoriano85
    Rate: 11
    Well, I can see that I ordered with 4 channels, theoretically Unicable I is for 8 channels, but at the same price I will buy a unicable II converter and 24 akals.
    2 4K ultraboxes for two contracts.
    It is cheaper to make an installation for 2 antennas.
    Wideband is also some technology with channels?
    Such an INVERTO Wideband Pro 40mm LNB converter (IDLP-WDB01-OOPRO-OPP price PLN 110) is enough to record 3 programs at once and one pause at one ultrabox 4K decoder and one pause + fast channel switching?
  • Questioning antenna placement on a Wide Band converter
    #4 16879019
    andpol 33
    Help: 513
    Rate: 1146
    "Wide Band installation allows
    watching one program at a time
    and recording at the same time even
    three different television programs,
    provides greater download efficiency
    VOD content and speeds up switching
    channels.
    Connect the cables from the Wide converter
    Band to the inputs in the decoder marked
    SAT 1 / V and SAT 2 / H. "
    If you connect, show off because you'll probably be the first. The question is, how do you place the antenna on such a converter?
  • #5 16879109
    wiktoriano85
    Rate: 11
    This is not hotbitda?
    Is it somehow set up differently?
    Any tips?
    Any other dish again or something?
