[Solved] Brother DCP J105 – Yellow Printing Issue: No Yellow Color, Ink Check & Replacement Tried
Thiety 28902 3
  • #1 17156412
    Thiety
    The BROTHER DCP J105 suddenly began to print the image incorrectly, as if without the yellow color, the display shows that the ink is still one line on the yellow rectangles test is not at all, check the ink and the yellow is '' zero '' I put a new one and the display shows the full state of yellow, but there are still no yellow rectangles in the test and I print without yellow (instead of yellow it is once pink and lilac, as if she remembered that yellow ink is still missing.
    Thanks in advance.
    mieszaczwcz
    Help: 185
    Rate: 258
    In the printer driver there is an option to clean the printhead run it
    Added after 30 [minutes]:
    You open Devices and printers / Printing preferences / then from the upper tab select Maintenance / Advanced cleaning,
    This type of cleaning consumes ink, which is why we use it in cases of heavily soiled nozzles. if repeated cleaning does not bring the result, then we remove the head and the whole with a warm liquid to unclog the heads with a hose and syringe and in the event of last resort, using warm, best distilled water, hold for several hours and then rinse with low pressure.
  • #3 17157050
    dr.master
    Help: 518
    Rate: 927
    It is better to let go of cleaning the device directly.
    If this does not help, you need to run the service cleaning from the maintenance menu.
  • #4 17157110
    Thiety
    The user "Mieszaczwcz" helped me a lot and everything works.
