Brother DCP-J105 Printer: Inconsistent Black Printing Quality and Interruptions
eternia94 15294 3
  • #1 17245027
    eternia94
    I need help with the brother DCP-j105 printer, I'm about 5 years old and it has rarely caused any problems with printing, it was enough to clean it and do a test print and it was fine, and recently the printer does not print properly in black. Sometimes it will print the page quite legibly (although it is still not suitable for delivery, e.g. as letters to the office, etc.), and other times it prints tragically, one sentence is nicely and the next one is practically invisible and so on alternately. I cleaned the printer several dozen times, thus cleaning I used two black inks. On the test prints, the remaining colors print nicely, only the black one is interrupted every time. Unfortunately, I have not found a similar case to mine and I am fed up with fighting windmills.
  • #2 17246838
    dr.master
    Help: 518
    Rate: 927
    Service cleaning has to be released.
    There are instructions on how to do this on the forum.
  • #3 17248077
    serwis.urz.biurowych
    Help: 27
    Rate: 277
    dry print head, if cleaning from the menu level of the printer no longer helps, take it to a service center, they should clear it for you, the sooner the better, it will be hard for you to do it yourself at home.
