Top Budget Smartphones for Stellar Sound Quality: Sony Xperia L, Xperia Z3 Compact & More
zwiro07 3591 12
How can I get noticeably better headphone sound from a cheap smartphone, and is an Xperia Z3 Compact much better sounding than an Xperia L?
The sound-quality difference between ordinary phones is basically cosmetic, so an Xperia Z3 Compact will not be a dramatic upgrade over an Xperia L for headphones [#17160370][#17160584] If you want a real improvement, use a USB sound card/DAC with the phone instead of chasing a “better-sounding” smartphone [#17160370][#17160584] The phone must support OTG; then you connect the microUSB adapter, plug in the USB audio device, and connect your headphones to it [#17160584] The thread says the difference compared with a regular smartphone should be very noticeable, even “cosmic” [#17160584] For the budget you mentioned, one reply suggests looking at cards like the ASUS Xonar U3 or Creative Sound BlasterX G1, and warns that the Sound Blaster Play 1 is poor for this use [#17172945]
  • #1 17160304
    zwiro07
    Hey, I'm looking for a smartphone that has above-average sound quality and I don't expect anything more from it. I intend to use the smartphone only as mp3. Until now I used Sony Xperia L and it worked quite well but unfortunately it is now flooded. I admit that I used the smartphone well to listen to music, so I thought to look for something with better sound quality. I intend to search mainly used and broken ones (e.g. problems with the sim card or camera, etc. The most important thing is that the sounds and headphone output work) which will be cheap (up to about PLN 100 - 150). I can see that HI Fi smartphones are entering the market but they are still too expensive, even broken ones. Are there any smartphones preferably some Sony xperia that stands out with such sound quality and good output for headphones?
    In addition, I am interested in whether such, e.g. Xperia Z3 compact or similar (which can be found for around PLN 100 when it does not read the sim card or has another type of damage) has a much better sound quality on headphones than, for example, Xperia L?
  • #2 17160370
  • #3 17160403
    zwiro07
    Thanks so much for your reply. The most important info for me is that the sound quality is not much different. For now, enough for me what a normal smartphone because I usually make up for with headphones. But I will also consider buying such a card. I found the USB Sound Blaster X G1 card on the Allegro and it seems cool ;) I still have a question whether after connecting the smartphone to the card I put headphones into this card input and it works immediately? The sound then goes through the card? And is there sense? Will the difference be very noticeable compared to a regular smartphone?
  • #4 17160497
    E8600
    Help: 529
    Rate: 2523
    It is not these times that to have good sound in the phone you had to change the drivers in the software e.g. k550i, k800i. Nokia had the worst sound although I did not have contact with these latest models. I would not look for a phone, only an mp3 / mp4 player, e.g. from Sony or maybe an iPod.
    Personally, I am of the opinion that the sound on the phone will never match that of a device dedicated only to music because there is less electronics which translates into less interference. Although I have a phone, if I want to listen to music on headphones, I choose a Sony mp3 player (on 1 charge it works much longer than a phone).
  • #5 17160571
    zwiro07
    I know it's probably better but I can't find anything nice at a reasonable price. Mp3 with a touch (in my opinion more convenient than searching or changing songs on the button) and a readable screen cost a little. And for some time after mp4 broke down I started to use the old xperia L phone and I got used to it because the music changes comfortably etc. So I always carried two phones with me from the ring and xperia only to listen to music. For now, however, I will probably look again for some xperia to listen to and about an mp3 player maybe someday when I find something interesting. Thanks for the opinion :)
    But as a colleague above said a phone with a USB sound card is an interesting idea and the quality can be much better than with an average mp3 player
  • #7 17160647
    zwiro07
    Thanks so much for your reply :)
  • #8 17172849
    zwiro07
    I read a little about these USB sound cards. And there were a lot of comments that they do not work well when listening to music, most of them are focused on games and surround sound. And I am asking for an opinion because maybe you will know if a card like Creative SoundBlaster Play (1) will improve my sound quality when listening to music from my phone? Because I have quite cheap to buy :)
  • #9 17172879
  • #10 17172898
    zwiro07
    For 40. If so, I think I'll take it. This external one will only be used for the phone because I have already bought an adapter. In the future I am going to buy something better, even bigger, to be used with a laptop and external speakers. For now, I will buy this SoundBLaster Play for my phone. Only this is probably the first version.
    I wonder if it really will be better with music than directly on the phone
  • Recommends Asus Xonar U3 over Sound Blaster X G1
    #11 17172945
  • #12 17172951
    E8600
    Help: 529
    Rate: 2523
    Kraniec_Internetów wrote:
    I checked this Play, and I'll just say it's rubbish - literally.
    Because this equipment is typically branded and not branded.
    Personally, I wouldn't play sound cards for my phone because it's just an additional device that draws electricity.
  • USB sound card power draw and pricing concerns
    #13 17172954
The discussion centers around finding budget smartphones with superior sound quality, particularly for music playback. The user previously used a Sony Xperia L and is seeking alternatives, specifically models like the Xperia Z3 Compact, while considering used or damaged devices. Responses indicate that sound quality differences among smartphones are minimal, and suggest using external USB sound cards to enhance audio output. Recommendations include checking for OTG support on smartphones to ensure compatibility with USB sound cards. Some users express skepticism about the effectiveness of certain sound cards, particularly for music, and suggest dedicated MP3 players as potentially better options for audio quality.
TL;DR: With a 5 PLN OTG adapter, a USB sound card upgrades audio; "differences in the sound quality of the phones are literally cosmetic." Budget roughly PLN 100–150 for the card to hear a clear jump over built‑in outputs. [Elektroda, Anonymous, post #17160370]
Why it matters: This FAQ helps budget listeners using older or damaged smartphones get better headphone sound without buying a new device.
What’s the best budget path to improve phone sound under PLN 150?
Skip chasing “Hi‑Fi” phones on a tight budget. Most phones sound similar through the jack. Use a 5 PLN OTG adapter plus a USB sound card. A ~100 PLN USB card can beat typical phone audio by a lot. This upgrade gives the biggest audible gain per złoty. [Elektroda, Anonymous, post #17160370]
Do Xperia Z3 Compact and Xperia L differ much in headphone quality?
Differences between phone headphone outputs are small. As one contributor put it, “differences in the sound quality of the phones are literally cosmetic.” You’ll hear a bigger improvement from an external USB card than switching between similar Sony phones. Prioritize the DAC/amp path over handset hopping. [Elektroda, Anonymous, post #17160370]
Will a USB sound card make a big difference vs my phone’s jack?
Yes, when your phone supports OTG. One experienced user said, “The difference will be cosmic.” External USB cards often have better DACs and stronger headphone outputs. Expect cleaner sound and more drive for many headphones. [Elektroda, Anonymous, post #17160584]
How do I connect a USB sound card to my Android phone?
  1. Verify OTG support via specs or an OTG‑check app.
  2. Plug in an OTG adapter, then connect the USB sound card.
  3. Insert headphones into the card; audio should route to USB automatically. [Elektroda, Anonymous, post #17160584]
Will it work immediately, and does audio go through the card?
If your phone supports OTG, it’s plug‑and‑play. Connect the adapter, then the card, then headphones. The phone powers the card and sends audio through it. You can confirm OTG with a store app beforehand. [Elektroda, Anonymous, post #17160584]
How much should I budget for an OTG + USB DAC setup?
Plan about 5 PLN for the OTG adapter. Allocate roughly 100–150 PLN for a capable USB card. That combo can significantly outperform most built‑in phone outputs. It’s the most cost‑effective improvement in this thread. [Elektroda, Anonymous, post #17160370]
Is Creative Sound Blaster Play (1) good for music from a phone?
Forum feedback is negative. One member called it “rubbish,” pointing to poor measurements and user reports. Consider other models suggested below. Prioritize proven USB cards over this entry. [Elektroda, Anonymous, post #17172945]
Which USB sound cards are recommended under PLN 150?
Users suggested ASUS Xonar U3 and Creative Sound BlasterX G1 as stronger picks. They’re compact, widely available, and used successfully with phones via OTG. Start with these before experimenting with lesser‑rated options. [Elektroda, Anonymous, post #17172945]
Do 7.1 or gaming features help with music listening?
Not for stereo music. Virtual surround can work in films with surround mixes. Skip those modes for music; use clean 2.0 playback. “7.1 cards are a clumsy attempt to make 7.1 from stereo.” [Elektroda, Anonymous, post #17172879]
Will a USB DAC drain my phone battery or get warm?
Yes. The card draws power from your phone’s USB port during use. One user noted the device became clearly warm over longer sessions. Expect increased power use whenever the card is active. [Elektroda, Anonymous, post #17172954]
Is a dedicated MP3 player better than a phone for music?
A dedicated player can deliver cleaner output and longer playtime. “The sound on the phone will never match that of a device dedicated only to music.” Less internal interference and longer battery life help. Many still prefer phones for convenience. [Elektroda, E8600, post #17160497]
Can a USB sound card improve microphone quality too?
Yes. One user reported much better mic handling, even with basic headset mics. External cards often include cleaner mic preamps and inputs. This can help calls and voice recordings. [Elektroda, Anonymous, post #17160370]
My phone doesn’t support OTG—can I still use a USB sound card?
No. Without OTG power from the phone, the USB card will not work. Check OTG support first using specs or an app. If unsupported, consider a dedicated player instead. [Elektroda, Anonymous, post #17160584]
Is the A4Tech Bloody G480 a good alternative?
A user praised its sound and mic performance and kept it over an integrated solution. It’s a budget‑friendly USB option that impressed in real use. Availability and pricing can vary. [Elektroda, Anonymous, post #17160370]
