[Solved] Amica PI6509LNU Induction Hob: Starting, Compatible Pots, and Troubleshooting U Icon Issue
Warson 7788 3
  • #1 17171651
    Warson
    Rate: 11
    Hello, I bought and connected the above hob, unfortunately after starting the cooking zone the U letter icon with underline appears, I read that there is no pot placed on the hob, and so it will not turn on, so I poured water into the pot and unfortunately I put the same thing ... Did this hob doesn't detect all types of pots? If so, is the option to turn it off so that you can cook on all types of pots?
  • #2 17171671
    stanislaw1954
    Help: 2013
    Rate: 4665
    There is no option. Either special pots, marked with the symbol "induction", or a special washer, and only a regular pot on it.
    Piotr2608
    Help: 851
    Rate: 4487
    It is not possible. Pots must be special and intended for cooking on an induction hob.
    ZimTech Piotr Zimny
  • #4 17171685
    Warson
    Rate: 11
    thank you :)
