Top Loading Washing Machine Recommendations: 1000 RPM, 1 Hour Wash, Easy-to-Clean Dispenser
Efelinkaaa 5172 8
  • #1 17176146
    Efelinkaaa
    I am asking for advice: which washing machine to buy?
    It must be loaded from the top (no space for the front one) and have little goodies, i.e. be less emergency. Turns up to 1000, 1h washing function, preferably a good dispenser - so that it could be cleaned somehow, because the previous one had in the door - some twisted tunnels, etc., it was impossible to put anything there and clean - only the compressor ?
    Ps. My washing machine ended its life yesterday. She turned 10 in March. Top loading Indesit with knobs (no displays). She stopped spinning. Bie makes sense to repair, and that's how she worked (washing with two small children - practically everyday).
    Greetings!
  • #3 17176243
    Efelinkaaa
    Piterr you think she has a container inside - not in the door?
  • #4 17176249
    olador
    Level 37  
    Help: 429
    Rate: 1443
    It definitely has inside ...
  • #5 17176254
    Pedros050
    Help: 2471
    Rate: 3918
    You open the top cover and there you have a standard powder container in washing machines loading from the top.
    r103
    Level 37  
    Help: 280
    Rate: 942
    This "standard" does not include Miele and Elextrolux / AEG washing machines 8-)
    We will not write about the former here because of the budget, in the latter it is solved like this:
  • #7 17176869
    Efelinkaaa
    Exactly. I have a bad experience with the door box. Not only is it difficult to wash it, but the washing machine will rust after years, because water leaks from the container ...
    Thank you, look around for electrolux.
    Is the display in the washing machine very problematic? I used to have a Samsung (when I was renting an apartment) and every now and then an error - the door is not completely closed, time is jammed .. Horrible!
  • #8 17176887
    r103
    Level 37  
    Help: 280
    Rate: 942
    Today's washing machines usually do not have time to rust - something will fall faster and repair will be impossible / unprofitable ...
    And the message with these unlocked doors - what's in the way, you need to close it and that's it?
  • #9 17176921
    Efelinkaaa
    Oh, no no. She was crazy. The door was closed, you could even hear the lock activated and the display anyway err - the door is not closed properly. It jammed programs, time instead of decreasing it increased. Maybe that's why I have a grudge against these displays :)
    The one-year-old washing machine went to the trash - it was won, so the complaint was a bit different.
    I hope that the new washing machine will serve at least half of what the old one ... Probably delusional dreams :)
    Thank you for your help, I will be looking for an electrolux with dispensers in the washing machine. greetings
✨ The discussion revolves around recommendations for a top-loading washing machine that meets specific criteria: a maximum spin speed of 1000 RPM, a one-hour wash cycle, and an easy-to-clean dispenser. The user shares their experience with a ten-year-old Indesit washing machine that has stopped functioning and expresses a preference for models that avoid complex door dispensers, which can be difficult to clean and prone to rust. Suggestions include Whirlpool and Electrolux models, with a focus on the importance of a standard powder container located inside the machine rather than in the door. Concerns about the reliability of displays in washing machines are also raised, particularly based on past experiences with Samsung models.
