How to check the battery charge cycles of a laptop - when the cycle is done
opelr 4887 3
  • #1 17176267
    opelr
    Help: 66
    Rate: 33
    Hello, the first question is is there any soft that shows the battery charging cycles?
    Second question, in what discharge and charge range is one cycle counted?
  • #2 17176338
    icosie
    Help: 298
    Rate: 239
    Try the Batterymon program, come on it doesn't read the cycles of all types of batteries.
    Some motherboards do not read this parameter and you would have to get to the driver in the battery and read it.
    Cycles are counted depending on the driver, some counting below 90%, some 80%. But I have never found a clear answer to this.
  • #3 17176413
    Hektar Zahler
    Help: 230
    Rate: 528
    So far, I have not heard and saw that it was otherwise, ie when the light goes out, the indicator increases by 1. Sometimes, eg in Dell, additionally removing and inserting the battery. Let's say my friend says to remove the battery from the handle when it is permanently powered, then the battery lasts longer. As a result, the young lady changes the battery every few months. It is so blunt that you won't translate not to do it, because Dell will lock the driver in this good battery. . What's this for?
  • #4 17178429
    opelr
    Help: 66
    Rate: 33
    Batery mon does not show what I need it for? For the sake of knowledge, I want to know when the cycle starts, then I will know what not to do and how to delay the charging blockage.
    I also think that removing the batteries is illogical, I do not have a laptop to keep the batteries in a drawer ...
