Dell D620 Laptop Battery PC764 11.1Vdc 56Wh - Addressing Rapid Charge & Short Life Issues
MRCZ 14728 12
How can I fix a Dell D620 battery that charges to 100% but only lasts a few minutes, and is resetting the CEA F53 EEPROM enough?
Do not reset the CEA F53 EEPROM; the problem is in the BQ20857DBT fuel gauge, which has integrated EEPROM and is the part that should be read/reset [#8368240] Use a battery-interface and Be2Works/SBW to connect SCL, SDA and GND to the battery socket contacts, with +5 V from the USB/PS2 supply, and first try reading the battery data to confirm the wiring [#8368240] [#8488977] If the chip is password-protected, the data may not read, and one reply says you may need to clone the contents and replace the system before resetting [#8368290] Another reply advises that the battery should have working cells and can be checked in the laptop after regeneration, or you can inspect the chip with the old cells still connected before cell replacement [#8490116] If there is no password, a short Be2Works license may be enough to perform the reset; if there is a password, the repair may not be worth it [#8368290]
  • #1 8367958
    MRCZ
    Help: 19
    Rate: 75
    Hello!
    Suddenly, the battery in the Dell D620 laptop, type PC764 11.1Vdc 56Wh, stopped working. Earlier, it held about 1.5 hours, it is currently charging quite quickly - after charging it to 100%, it shows the working time about 30 minutes, but it only keeps a few minutes. They connect a laptop without a battery, everything is ok. Apparently, my battery is on the BQ20857DBT, BQ29311PW and eeprom CEA F53. Is it enough to reset the contents of the CEA F53 eeprom, does anyone know what is the layout (smd coding)?
    Pzdr.
  • #2 8368240
    krzychu1985^
    Help: 132
    Rate: 151
    Leave CEA F53 alone. You need to take care of BQ20857DBT - it has an integrated eeprom. Build an interface whose schematic and board are in suspended themes, download be2works, connect sda, scl and gnd from the interface under sda, scl and gnd on the battery pinout. In the be2works program, select bq208x from the drop-down menu and click read but top right. If the system is not encrypted, the data should be read. If they do not read, the system probably has a password. At the bottom, a little on the left is also read and with this button you can read the battery data via smbus. Begin with this - because if you read the data you will know that you have connected yourself to the right contacts at the battery output.
    Krzysztof Łukasik LukasKomp
    Elizy Orzeszkowej, Ostrzeszów, 63-500
  • #3 8368262
    MRCZ
    Help: 19
    Rate: 75
    krzychu1985 ^ thanks for ans reading the FAQ. If the BQ2085 system is stuck, I will not do anything?
    krzychu1985^
    Help: 132
    Rate: 151
    It probably goes to clone the contents of this encrypted layout with the full version of the program. Then you have to replace the system with the same uncluttered or some clone of this system (I do not know what is equivalent to bq2085) and upload the copied content and only then the reset is performed. I have not done such an operation yet, I do not have the full version of the program. If there is no password - my opinion is that the game is worth the candle - you will buy a version of be2works for $ 10 for 24 hours and then it will be reset. If there is a password, you have to answer for yourself if it is worth investing in this battery.
  • #5 8369190
    misiozol
    Help: 233
    Rate: 641
    The equivalent of BQ2085 is BQ2085 :D , it is not a Chinese clone, it is original with TI.
  • #6 8439756
    MRCZ
    Help: 19
    Rate: 75
    I made an interface for communicating with the battery eeprom, but I do not want to act. The correctness of the submission was checked twice, despite this program SBWorkshop 3.7 demo does not detect the interface when connected to the LPT port, the power download from PS2. For the construction of the interface, I used 4 resistors 11k om, because I did not have all 10k om (as it was described in the FAQ), can it affect the interface does not work?
    misiozol
    Help: 233
    Rate: 641
    Should it work badly, correct pin numbers from the LPT port? How do you have LPT port set? Is everything good on the plate? Upload photos of what you did when you do not talk about it, we'll see what can be wrong.
  • #8 8440023
    MRCZ
    Help: 19
    Rate: 75
    misiozol, but you were right I missed one bridge on board :) SBW shows that the adapter is OK, but I can not read the battery parameters - by soldering into the battery connector. In general I am surprised by the fact that on the external terminals of the battery connector, where there is a + and - contact I do not have a battery voltage and measuring directly on the links I have about 12V, which is as much as it should be. I will add that the transition is between the + and - pins of the battery connector and the cell tabs.
  • #10 8488940
    MRCZ
    Help: 19
    Rate: 75
    I desolded the PQ2085 chip and soldered directly to the legs of the chip:
    VDDD + 5V - foot 8
    VSSS GND - foot 19
    SCL - foot 6
    SDA - foot 10
    I enter the Integrated Flash EEPROM tab, press read eeprom, but there is no reaction and after several such attempts, the SBW program hangs up and I do not want to turn on again, showing the message that the adapter is OK. Do you have any ideas what could be wrong, I soldered in good feet at all?
    misiozol
    Help: 233
    Rate: 641
    You told me that you have to solder into a scalak, connect to the place where the battery contacts the laptop (battery socket) there are SCL SDA GND lines, and + 5V from the PS2 / USB socket in the computer
  • #12 8489627
    MRCZ
    Help: 19
    Rate: 75
    And the links are to be disconnected?
  • #13 8490116
    misiozol
    Help: 233
    Rate: 641
    The battery is to be functional with working cells and inserted into the laptop and checked with the action (after regeneration) then you can do reset, or as you prefer immediately after dismantling and checking what is the scalak (still with connected links even old) before the exchange of cells (regeneration) .
The discussion revolves around issues with the Dell D620 laptop battery (PC764 11.1Vdc 56Wh), which has experienced rapid charging and significantly reduced runtime. Users suggest focusing on the BQ20857DBT chip, which contains an integrated EEPROM, rather than the CEA F53 EEPROM. Recommendations include building an interface to connect to the battery's SDA, SCL, and GND pins for data reading using the be2works program. If the system is encrypted, users may need to clone the EEPROM contents and replace the system with an equivalent. Troubleshooting steps include ensuring correct connections and checking for voltage at the battery terminals. Some users report issues with their interface setups and seek advice on resolving detection problems with the SBWorkshop program.
