Wireless rear view camera - flashing screen after connecting the receiver
mrozilla 14835 14
How can I stop a rear-view monitor from flashing when a 2.4 GHz wireless receiver is powered but no camera signal is present?
Power the receiver and display only when reverse gear is engaged; when they are permanently powered, the screen can keep flashing, and connecting their + supply to the reverse sensor/backup signal makes the flashing disappear [#17237388] If the reverse light circuit is CAN-bus controlled, do not power the camera directly from it; use a relay and take camera power from a separate source, with the relay coil triggered by the reverse light signal [#17942418] In most cases the monitor only needs the video signal to switch on, but some setups also require an extra + trigger wire to the radio/monitor depending on the unit [#17942418] This workaround avoids having the wireless receiver active all the time and prevents the flicker effect [#17237388]
  • #1 17182488
    mrozilla
    Rate: 30
    I want to connect the rear view camera to the monitor using a 2.4GHz wireless transmitter and receiver kit
    Wireless set and display (photos taken from the forum and the web):
    Wireless rear view camera - flashing screen after connecting the receiver Wireless rear view camera - flashing screen after connecting the receiver
    The problem occurs when the receiver is connected to the power supply and to the screen. The screen flashes all the time (it has two video outputs), when I connect to the yellow, which is the main one, it flashes faster, when I connect to the second, which is the white one, it flashes more slowly. When I turn on the camera with the transmitter (or throw in the back) the image appears on the display and everything works fine. After turning off the problem returns.
    In the forum I read that the transmitter with the camera must be connected to a separate power supply or pod to make it through the relay but it does not help because even when the camera and the transmitter are disconnected at all the display flashes, it is enough that the receiver is plugged in chinch. I even checked that the display was connected to one battery, and the receiver to the other (transmitter and camera disconnected from everything) and the display still flashes. A possible workaround would be to connect the receiver to the reversing light, but the reversing light fuse is located under the hood and there would be a problem with bringing it to the cab, because it is very tight but it's not about circumventing the problem but solving it and I have no idea what can cause this situation. In various instructions on the network from such transmitters I read that the receiver must be permanently connected together with the display and turn on after ignition, and the reversing camera with the transmitter against the reversing light, and there was no way of flashing.
    Has anyone had such a problem and managed to solve it or at least know what is causing it?
  • #2 17182613
    mieszaczwcz
    Help: 185
    Rate: 258
    First make sure that your installation is controlled by plus or mass feeding and check if you have bought a reversing camera kit in the correct variant. Otherwise the power supply will be "impure".
  • #3 17182650
    mrozilla
    Rate: 30
    I mean, it happens by connecting only the receiver and display regardless of whether the car is installed, separate batteries or even a laboratory power supply. In addition, I only have to connect with this set (receiver + display) black cable (-) and red (+) both on the receiver and the display. The manual also contains information about connecting black to (-), red to (+).
    Description of the set:
    Wireless Transmitter:
    1) Cable Length: 1.5m
    2) 2.4G wireless, Color video
    3) Transmission Distance: 50m
    4) Input: DC 12V
    5) Operating Temperature: -10-60oC
    Wireless Receiver:
    3) Input: DC 12V
    4) Receiving Sensitivity:
  • #4 17184211
    mrozilla
    Rate: 30
    I checked the second set from another manufacturer and it happens the same, without any changes, although I know that, for example, the display has a different driver. The receivers are rather the same, but as you can see it is not the fault of the given copy but "it is so" and the question is how to get rid of this effect without pulling the cable from the bonnet inside the car.
  • #5 17210550
    thomsoon88
    Hi
    I have the same problem as you wrote. Today I connected the same set with a wireless module to my Ford Mondeo and the screen flashes in the same way in white after turning on the reverse you can see the view from the camera but when I turn off the screen, the screen flashes, you can't drive like this.
    Did you find any solution to this problem? I also have a cable to run through the car, but that's not the point.
    I had the same set connected a few years ago in another car and it was connected the same way and there was no such thing.
  • #6 17210558
    mrozilla
    Rate: 30
    Maybe the display driver has changed all these years although I checked two sets and the displays had different PCBs and worked the same. Unfortunately, I have not approached this for the second time, but now the most reasonable solution will be to connect the display under voltage, which appears after throwing back.
  • #7 17210722
    web69
    Help: 188
    Rate: 629
    Isn't it easier to throw out this senseless wireless system and connect the camera to the monitor with a cable? Why the hell do you need a 3m transmitter? After all, toto works on 2.4GHz, like bluetooth, WIFI or LTE, there will always be interference ...
  • #8 17237388
    mrozilla
    Rate: 30
    thomsoon88 wrote:
    Hi
    You can take the + from the reverse sensor in the gearbox, the display and receiver will turn on when you turn on the reverse just like the camera and transmitter. Connecting in this way has no flashing effect.
  • #9 17238506
    web69
    Help: 188
    Rate: 629
    But you still have to drag the cables to connect the camera's power supply to the monitor. Isn't it simpler to add shielded and throw out this wireless jammer?
  • #10 17238515
    mrozilla
    Rate: 30
    Short section with technological holes. A bigger problem would be pulling 6 meters of cable from the rear camera placed outside into the car under the cockpit while hiding it along the entire length.
    Of course, you can throw wireless transmission as well as connect and use it.
  • #11 17340830
    thomsoon88
    Earlier I had a problem with the camera flashing so I connected it via a cable which I dragged from the trunk to the monitor which I stuck to the front of the steering wheel on the left there is a little space. And now the question is how to connect the monitor power supply?
    That it would not be turned on all the time because I hooked up to the cube of daytime running lights and there are red and black and a few more with other colors but I chose those. And it seems to me that there is tension all the time.
  • #12 17942418
    hotair
    And what is all this for. A likely cause of the problem is interference from the CAN bus. The problem arises as a result of supplying the camera with a reversing light. If you have a cigarette lighter socket in the trunk then you take the power supply and put it on an additional relay. You connect the relay output to the rear view camera power supply. The relay coil should be connected to the ground on one side and to the reversing light on the other. In this way you power the camera bypassing the CAN bus. It does not matter whether you connect the camera with a Wi-Fi kit or connect with a cable throughout the car. You can buy a relay with a stand at any automotive store. It looks like this https://www.google.com/search?hl=en&tbm=isch&...%C5%BCnik+samochodowy&oq=przeka%C5%g.3_samoch 0.1905.7457..8122 0.0..0.110.2209.9j13 ... ...... 0 .... 1..gws-visa-img ..... 0..0i24.JhXiHAZbu2s # imgrc = gynVOEExzxvZOM :
    When it comes to controlling the image display, in most cases it is enough that a video signal appears on the chinchini. It also happens that sometimes you need to introduce an additional plus cable to the radio depending on the radio. If you only have a monitor without a radio, then this camera power cord is also connected to the monitor power supply. Then when you turn on the reverse, the monitor turns on. I hope I cleared up the situation.
  • #13 17944193
    Gerri
    Mercedes specialist
    Help: 865
    Rate: 3629
    And what CAN you have in this bulb? Is it sometimes the case that interference is generated by the bulb efficiency control system?
  • #14 17944261
    hotair
    This is the problem that the bulbs are controlled by an integrated circuit with efficiency control. CAN-BUS is not like polonaise or toddler.
  • Receiver driver likely causing flashing screen
    #15 21015628
    its808punaboy
    I also have this flashing/blinking problem and I am not even using it in a vehicle...
    I have a wireless camera that I custom built a birdhouse around so we can watch for any shenanigans in our neighborhood. However, I suspect that the receiver driver is the culprit. It cannot properly regulate voltage inputs causing the irritating flashing screen. Or its internal circuits are not sufficient for voltage calibration. Still equally maddening for every person this issue will affect. They ought to replace and/or refund all whom have to suffer this electronic debacle.
The discussion revolves around issues with a wireless rear view camera system using a 2.4GHz transmitter and receiver kit, where users experience a flashing screen on the monitor after connecting the receiver. The problem persists regardless of the power source, whether connected to the vehicle or using separate power supplies. Users suggest that the flashing may be due to interference from the CAN bus or issues with the display driver. Some propose connecting the display to a power source that activates with the reverse gear to eliminate the flashing. Others question the necessity of a wireless system, suggesting a wired connection might be more reliable. Solutions discussed include using a relay to power the camera independently of the CAN bus and ensuring proper voltage regulation to avoid interference.
TL;DR: Monitor blinking with 2.4a0GHz reversing kits is real"it happens by connecting only the receiver and display." These kits typically advertise 50a0m range. This FAQ explains stable wiring and power options to stop the flicker. [Elektroda, mrozilla, post #17182650]
Why it matters: A flickering display distracts drivers and can hide hazards when reversing.
Why does my monitor blink when only the wireless receiver is plugged in?
This symptom is documented: the screen flashes continuously with only the receiver connected. It can blink faster on the yellow input and slower on the white input. When the camera and transmitter turn on, the image stabilizes. Separate supplies or batteries did not change this behavior. "The screen flashes all the time ... when I turn on the camera ... everything works fine." [Elektroda, mrozilla, post #17182488]
Does powering the receiver and monitor from the reverse sensor stop the blinking?
Yes. Taking +12a0V from the gearbox reverse sensor to power the display and receiver cured the flashing. They power up only when reverse is engaged, just like the camera and transmitter. "Connecting in this way has no flashing effect." This prevents the monitor from seeing an idle receiver. It is a practical, in-car fix with minimal rewiring. [Elektroda, mrozilla, post #17237388]
How do I isolate reverse-light noise with a relay?
Use a relay so the camera gets clean power while the reverse lamp only triggers it. "A likely cause of the problem is interference from the CAN bus." How-To:
  1. Feed relay common from a clean 12a0V source (e.g., trunk socket) and ground the camera.
  2. Connect relay coil between reverse lamp +12a0V and ground.
  3. Use relay NO output to supply the camera +12a0V when reversing. [Elektroda, hotair, post #17942418]
Is 2.4a0GHz wireless too noisy for a reversing camera?
It can be. 2.4a0GHz shares airspace with WiFi, Bluetooth, and more, so interference happens. "There will always be interference ..." Some users replace wireless links with shielded video cables. Cable removes RF issues but requires routing through the cabin. Consider your vehicle layout and interference sources before choosing. [Elektroda, web69, post #17210722]
Will separate power supplies or a lab PSU fix the blinking?
No. Users report identical blinking with the receiver and display on entirely separate batteries. The behavior also persists when using a laboratory power supply. "It happens by connecting only the receiver and display ... even a laboratory power supply." The image stabilizes only when the camera and transmitter are active. [Elektroda, mrozilla, post #17182650]
I tried another kit and it still blinks. What does that indicate?
It points to a design or interaction issue, not a single faulty unit. A second kit, even with a different display PCB, behaved the same. The receivers looked similar and produced the same effect. That suggests the monitorreceiver idle behavior is the trigger. "It is not the fault of the given copy." [Elektroda, mrozilla, post #17184211]
How should I power a stand-alone monitor so it only turns on in reverse?
Tie the monitor power to the camera power that appears in reverse. Then the monitor powers up only when the camera does. Many head units switch automatically on video presence; some need an extra +12a0V trigger. "Then when you turn on the reverse, the monitor turns on." This keeps the screen off during normal driving. [Elektroda, hotair, post #17942418]
How do I choose a camera variant for plus- or ground-switched reversing circuits?
First verify if your reverse circuit switches on the positive side or the ground side. Buy a camera kit that matches your vehicles switching method. Otherwise, you can get an "impure" supply and unstable operation. This simple check avoids chasing noise later. "Make sure that your installation is controlled by plus or mass feeding." [Elektroda, mieszaczwcz, post #17182613]
Why does the yellow input blink faster than the white one?
Users observed faster blinking on the primary yellow input and slower on the white input. Both inputs display a stable image once the camera transmits. This difference shows during idle receiver connection only. It reflects how the display treats each AV input path. The underlying cause was not detailed, only the behavior. [Elektroda, mrozilla, post #17182488]
If I go wired, how long a cable run should I expect?
Plan for about 6a0m from a rear-mounted camera to the front cabin. One installer called it the bigger challenge versus short local runs. "A bigger problem would be pulling 6 meters of cable ... while hiding it along the entire length." Use a shielded video cable if you choose this route. It trades routing effort for a noise-free picture. [Elektroda, mrozilla, post #17238515]
Does this blinking happen outside vehicles too?
Yes. A user saw the same blinking in a stationary birdhouse camera setup. They suspected the receivers driver couldnt regulate voltage properly at idle. The result was an "irritating flashing screen" even off-vehicle. Replacement or refund may be the only remedy in such cases. This is an important edge case to note. [Elektroda, its808punaboy, post #21015628]
Will powering the receiver with ignition ACC stop the flashing?
Not necessarily. Some manuals suggest the receiver stays powered with ignition and the camera on reverse. The OP still experienced blinking whenever only the receiver was connected. This shows ACC power alone wont cure idle-output blinking. Use a reverse-triggered feed or a relay-based solution instead. [Elektroda, mrozilla, post #17182488]
Do I need a trigger wire, or will video presence auto-switch the display?
Many radios switch to the camera when a composite signal appears on RCA. Some systems require an additional +12a0V trigger wire to the radios reverse input. For standalone monitors, tie the camera power to the monitor power. "In most cases it is enough that a video signal appears." This ensures activation only when reversing. [Elektroda, hotair, post #17942418]
Is the CAN bus causing the issue, or the lamp electronics?
The noise source is the lamp control electronics in CAN-managed vehicles. Reverse bulbs are driven by an integrated controller with efficiency management. That control can poll or modulate the line and disturb camera power. "Bulbs are controlled by an integrated circuit with efficiency control." Isolate the camera supply to avoid these effects. [Elektroda, hotair, post #17944261]
