Best Router for LTE ORANGE: TP-Link MR3220 vs MR200 vs Huawei B525 in Legnica, Jesionowa St.
Elas74 4089 4
  • #1 17183161
    Elas74
    Hello all.
    The current TP-Link MR3220 router does not work very well, it often disconnects, I connected the modem to a hub with its own power supply, but when I connect via wifi with more devices, the router resets every now and then.
    I would like to buy something good, I was thinking about MR200 but from the posts I read I know that it is a waste of money because the functionality is poor. Will the Huawei B525 also be better when it comes to Orange?
    The address is Legnica, Jesionowa Street.
    At a given location, it shows me 4 BTSy LTE2600 but in any case suggests an antenna.
    Regards
  • #2 17183716
    robson_rwx
    I use HUAWEI B315s-22 and I am satisfied. As for hanging up the equipment via wi-fi, remember that the transmission speed decreases adapting to the weakest device on the network. I would suggest checking if the router hangs with more devices or if any particular one is blocking it.
    Regards,
    r.
  • #4 17187046
    Elas74
    Thanks for the tip. I will make measurements with these BTSs
    Is there a good counterpart to Network Cell Info Lite for aphone?
