IGO Primo Android - Skin Change: How to Modify Content/Skin Directory on SD Card?
marok11 25521 9
How can I make iGO Primo on Android recognize and let me change skins stored on the SD card?
The skin must match both the iGO program version and the device resolution, and on newer iGO versions skins should be placed in the UX folder rather than content/skin [#17185616] If the skin-selection list is empty, check that you have a compatible skin for version 9.6.29.390522 and your screen resolution, because one user with 9.6.29 reported no problems when using a matching skin such as GjAk v.2.3 AriNe Typhoon [#17186994] The skin chooser should appear under Options > Program settings > Screen, so if nothing shows there, the installed skins are likely not compatible with the build or resolution [#17186994] The thread also notes that a 480×234 Android car-box/Audi A6 setup may not have suitable skins available [#17187053][#17187476]
  • #1 17185525
    marok11
    Rate: 18
    I have installed Igo Primo on the adroid. unfortunately I can not change the skins that I have on the SD card in the content / skin directory.
    Maybe a hint?
  • #2 17185616
    jajacekpl
    Help: 65
    Rate: 268
    Skin version must match the program version.
    In addition, skins in the higher versions of iGO are to be the UX folder
    What is your program and skins (full file name)
  • #3 17185627
    marok11
    Rate: 18
    My version is 9.6.29.390522,
    and I have different skins but can not see any
  • #4 17185672
    jajacekpl
    Help: 65
    Rate: 268
    marok11 wrote:
    pounded on the SD card in the content / skin directory.
    Map files do you have on SD too?
    Enter the names of the skinai files (along with the extension)
  • #5 17185682
    marok11
    Rate: 18
    tak , mapy też są na SD
    a nazwy plików to dopiero potem , ale na pewno sa spakowane zip
    a może masz , albo podasz link do odpowiednich skinow ?
    generalnie rzecz biorąc to w sumie zalezy mi na opcjach ustawień komunikatów odległości do manewrów , bo ostatnio na S8 dopiero przy 100 m do zjazu powiedziała zjedzi , no i przejechałem
    Próbowałem w sys.txt w warning dodać linijkę bo takiej nie było, a gdzieś wyczytałem ,że ta instrukcja za to odpowiada:
    warn_distances=130:450,110:350,90:300,60:200,40:10 0 ;These numbers are apparently in the format of speed and distance.
    skórki mam różne w tym folderze. printscreen:
    A tak wygląda mój sys.txt
    [device]
    devtype_fallback_to_model=1
    [android]
    ;fullscreen=1
    ;tablet=0
    ;has_physical_home_button=1
    ;select audio stream
    ; 0-STREAM_VOICE_CALL, 1-STREAM_SYSTEM, 2-STREAM_RING, 3-STREAM_MUSIC, 4-STREAM_ALARM, 5-STREAM_NOTIFICATION
    ;navigation_audio_stream=4
    create_sdcard_dir=0
    [interface]
    ;vga=1 ; for full HD
    skin="ui_android"
    capture_to_jpeg=1
    extra_settings=1
    save_checksum=0
    maxzoom2d=6000000
    ;show_scroll_button=1
    ;show_glonass=1
    [rawdisplay]
    force_renderer="RENDER_MOYA"
    ;highres=1 ; for full HD
    ;driver="gdi"
    ;driver="engine"
    screen_xy="auto"
    [gps]
    location_net=1
    location_gps=1
    background_navigation=1
    [map_update_checker]
    enabled=0
    [3d]
    usepolyfarroads=0
    ; this is for resolution full HD:
    ;road_polytrack_switch_pixelwidth=2
    ;max_loading_time_immediate=100
    ;double_pixel_similarity_check=0
    [poi]
    ;featured_provider="netlocalsearch.naviextras.google"
    featured_provider="netlocalsearch.naviextras.nokia"
    [poi.netlocalsearch.naviextras]
    services="nokia,google"
    ;services="google"
    [network]
    available=1
    [http]
    enabled=1
    ;[tmc.src.http]
    ;enabled=1
    [naviextras]
    boot_service_address="http://zippy.naviextras.com/services/index/rest/2/boot"
    [services]
    software_download_location="http://www.igomaps.co.il/Jquery_Report.html"
    [activation_manager]
    activate_google_naviextras=0
    activate_online_speedcam=0
    activate_community_speedcam=0
    activate_http_traffic=0
    [tmc-http]
    enabled=1
    start=1
    servers.size=3
    servers[0].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-iphone/0/"
    servers[1].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-russia/0/"
    servers[2].url="http://tmchttp0.naviextras.com/nng-igo-tmc-primo/0/"
    [other]
    demo_enabled=0
    [debug]
    imei="000000000000000"
    skip_eula=0
    screenshotsavecameraini=0
    ;screenshotfilename="/captures/image_%02d.jpg"
    screenshotfilename="/android_linked_root/captures/image_%02d.jpg"
    experimental_features=1
    ;double_pixel_mode=1
    [feature]
    back_exit=1
    back_button=1
    tmc_event_coloring=1
    signpost_coloring=1
    [sound]
    csv_voice_enabled="1"
    [folders]
    linked_root_list="/storage/extSDCard/iGO /storage/sdcard2/iGO /sdcard2/iGO /sdcard/external_sd/iGO /ext_card/iGO /mnt/_ExternalSD/iGO /mnt/emmc/iGO /mnt/extern_sd/iGO /mnt/external_sd/iGO /mnt/exsdcard/iGO /mnt/ext_card/iGO /mnt/ext_sd/iGO /mnt/extsd/iGO /mnt/extSdCard/iGO /mnt/sdcard/_ExternalSD/iGO /mnt/sdcard/external_sd/iGO /mnt/sdcard/ExtStorages/iGO /mnt/sdcard/extStorages/SdCard/iGO /mnt/sdcard2/iGO /storage/sdcard1/iGO /storage/sdcard0/iGO /storage/iGO /sdcard/sd/iGO /mnt/sdcard-ext/iGO /mnt/sdcard/sd/iGO /mnt/sd/iGO /mnt/sdcard/iGO /mnt/iGO /sdcard/iGO /storage/sdcard1/iGO /mnt/sdcard1/iGO /mnt/ext/SdCard/iGO /storage/ext/SdCard/iGO /storage/emulated/0/iGO"
    has_secondary_root=0
    ;android_secondary_root_path="/mnt/sdcard/addons"
    [warning]
    speedcam_enabled=1
    is_spoken=1
    speedcam_continuous_approach_beep_when_tonal=0
    warn_distances=130:850,110:650,90:400,60:200,40:10 0 ;These numbers are apparently in the format of speed and distance.
    ; S P E E D C A M - C A T : 0
    [speedcam_category:0]
    overspeed_spoken_type=sound
    overspeed_sound="speedcam_over_speed"
    skin_first_sound="Fixed_Camera"
    skin_speed_sound_delay=0
    skin_repeat_sound="Fixed_Camera"
    skin_repeat_distance=150
    skin_off_sound="speedcam_off"
    use_road_speedlimit=0
    ; S P E E D C A M - C A T : 1
    [speedcam_category:1]
    overspeed_spoken_type=none
    overspeed_sound="none"
    skin_first_sound="Mobile_Camera"
    skin_speed_sound_delay=120
    skin_repeat_sound="Mobile_Camera"
    ;use_road_speedlimit=0
    ; S P E E D C A M - C A T : 2
    [speedcam_category:2]
    skin_first_sound="Redlight_Camera"
    skin_speed_sound_delay=140
    skin_repeat_sound="Redlight_Camera"
    ; S P E E D C A M - C A T : 3
    [speedcam_category:3]
    skin_first_sound="Section_Start"
    skin_speed_sound_delay=160
    skin_repeat_sound="Section_Start"
    ; S P E E D C A M - C A T : 4
    [speedcam_category:4]
    ; S P E E D C A M - C A T : 6
    [speedcam_category:6]
    skin_first_sound="Railroad"
    skin_repeat_sound="Railroad"
    ;use_road_speedlimit=1
    ; S P E E D C A M - C A T : 7
    [speedcam_category:7]
    skin_first_sound="BusLane_Camera"
    skin_repeat_sound="BusLane_Camera"
    ; S P E E D C A M - C A T : 8
    [speedcam_category:8]
    skin_first_sound="Accident_Zone"
    skin_repeat_sound="Accident_Zone"
    ; S P E E D C A M - C A T : 9
    [speedcam_category:9]
    skin_first_sound="School_Zone"
    skin_repeat_sound="School_Zone"
    ; S P E E D C A M - C A T : 10
    [speedcam_category:10]
    skin_first_sound="Town_Entry"
    skin_repeat_sound="Town_Entry"
    ; S P E E D C A M - C A T : 11
    [speedcam_category:11]
    skin_first_sound="Redlight_Camera3"
    skin_repeat_sound="Redlight_Camera3"
    ; S P E E D C A M - C A T : 12
    [speedcam_category:12]
    skin_first_sound="Toll_Booth"
    skin_speed_sound_delay=80
    skin_voice_rep="skin_arimi"
    skin_repeat_sound="Toll_Booth"
    ; S P E E D C A M - C A T : 13
    [speedcam_category:13]
    skin_first_sound="Hospital"
    skin_repeat_sound="Hospital"
    ; S P E E D C A M - C A T : 14
    [speedcam_category:14]
    skin_first_sound="Fire_Station"
    skin_repeat_sound="Fire_Station"
    ; S P E E D C A M - C A T : 15
    [speedcam_category:15]
    skin_first_sound="Charge_Zone"
    skin_repeat_sound="Charge_Zone"
    ; S P E E D C A M - C A T : 16
    [speedcam_category:16]
    skin_first_sound="Give_Way"
    skin_speed_sound_delay=100
    skin_repeat_sound="Give_Way"
    ; S P E E D C A M - C A T : 17
    [speedcam_category:17]
    skin_first_sound="FixMobil"
    skin_repeat_sound="FixMobil"
    ; S P E E D C A M - C A T : 18
    [speedcam_category:18]
    skin_first_sound="Speed_Breaker"
    skin_repeat_sound="Speed_Breaker"
    ; S P E E D C A M - C A T : 19
    [speedcam_category:19]
    skin_first_sound="Children"
    skin_repeat_sound="Children"
    ; S P E E D C A M - C A T : 20
    [speedcam_category:20]
    skin_first_sound="Dangerous_Turn"
    skin_repeat_sound="Dangerous_Turn"
    ; S P E E D C A M - C A T : 21
    [speedcam_category:21]
    skin_first_sound="Tunnel"
    skin_repeat_sound="Tunnel"
    ; S P E E D C A M - C A T : 22
    [speedcam_category:22]
    skin_first_sound="POI"
    skin_repeat_sound="POI"
    ; S P E E D C A M - C A T : 23
    [speedcam_category:23]
    skin_first_sound="RPS_Post"
    skin_repeat_sound="RPS_Post"
    ; S P E E D C A M - C A T : 31
    [speedcam_category:31]
    skin_first_sound="Dangerous_way"
    skin_repeat_sound="Dangerous_way"
    ;--------------- arimi ----------------------
  • #6 17186994
    jajacekpl
    Help: 65
    Rate: 268
    I also have 9.6.29 and zero skins problems (matching this version and resolution). I'm using now GjAk v.2.3 AriNe Typhoon
    How does the skins selection screen look like (options> program settings> screen)?
    There should be something like this:
    What screen resolution does your device have?
  • #7 17187053
    marok11
    Rate: 18
    My screen 480 * 234
    Do you have a skin file on SD in the content / skin directory?
    And you can send this spot on the email: marok(_at_)poczta.fm
  • #8 17187472
    jajacekpl
    Help: 65
    Rate: 268
    marok11 wrote:
    My screen 480 * 234
    Do you have an Android device and a 480 * 234 screen?
    What is this invention?
  • #9 17187476
    marok11
    Rate: 18
    car android box, and factory display in AUDI A6
    will there be any help with these communiqués?
  • #10 17188170
    jajacekpl
    Help: 65
    Rate: 268
    I do not know if you can find something for this resolution.
    Messages - I use the TTS voice, and there are separate settings. But go to program options> sounds and warnings> Longitude of Communists set LONG. And in ADVANCED, tick "give distance to maneuver"
    The line "warn_distances = 130: 450,110: 350.90: 300.60: 200,40: 10 0" is responsible for linking the warning with speed, but in sections SPEEDCAM
The discussion revolves around modifying the skin directory for the iGO Primo navigation software installed on an Android device. The user is unable to change skins located in the content/skin directory on their SD card. Responses highlight that the skin version must match the iGO program version (9.6.29.390522) and that skins should be placed in the UX folder for compatibility. Users inquire about the presence of map files and the specific names of skin files, noting that skins must be compatible with the device's screen resolution (480x234). Suggestions include checking program settings for skin selection and adjusting warning settings in the sys.txt file to improve maneuver notifications.
