Navigon 40 Easy GPS Signal Issue: Unlocking Navigation, AutoMapa & iGo Primo 9.6.13.267029 Install
tekondo 18801 7
  • #1 16461020
    tekondo
    I have a problem with the GPS signal on Navigon 40 easy.
    I have downloaded at the beginning unlocking navigation and AutoMape- everything works GPS finds no problem. However, I missed the TIR profile option in this map, so I installed iGo Primo 9.6.13.267029. And everything works but does not find any satellites can not find the GPS signal. He also has an efficient antenna on the original software. Nothing was given even while traveling outdoors still does not find the GPS signal. I tried to search for options in the GPS setting program but there is no such option. Has anyone the idea how to fix it?
  • #2 16461088
    barteksmrek
    Help: 89
    Rate: 223
    Is it talking about hacking? Upload the original software. There are special GPSs with the right map on the sawmills.
    jajacekpl
    Help: 65
    Rate: 268
    In iGO, look for the [GPS] section in the sys.txt file and enter the correct port and baudrate parameters.
    Where to get? see UserSettings.xml file, section
    If it does not help, it means that the factory Navigator process blocks the GPS port (to be confirmed by VisualGPS)
  • #4 16465404
    tekondo
    There is no such entry
    [Debug]
    skip_eula = 1
    reserve_memory = 3145728
    [Route]
    * = hnr_ignored_missing_country_ids
    save_route_after_auto_recalc = 0
    [Camera.roundabout]
    enabled = 0
    centery = 20
    [Navigation]
    parking_ad_enabled = 1
    congestion_ad_enabled = 1
    quickdetour_enabled = 1
    [Feature]
    tunnel_guidance = 0
    [Power]
    skip_resume_process = 1
    skip_suspend_process = 1
    powermgm_state = 0
    [Scheduler]
    idle_execution_restrained = 1
    Is it enough to add sections to the entry
    [Gps]
    port = "auto"
    baud = "auto"
  • #6 16478350
    tekondo
    koala106 wrote:
    You have a solution in another post https://www.elektroda.pl/rtvforum/topic3076145.html
    I wrote what and how and you have the program in the attachment.
    I gave COM2 but when I press OUTPUT, there is nothing to indicate what I can do?
    koala106
    Help: 471
    Rate: 1240
    Review the program config that is in the program from the thread I gave and match to the device.
  • #8 16482031
    tekondo
    Okay, I came to the same but what COM and baudrate set to make it smigalo because I still do not want to detect me GPS- I set COM2 input COM0 output.
✨ The discussion revolves around a GPS signal issue with the Navigon 40 Easy device after installing iGO Primo 9.6.13.267029. The user initially had success with GPS functionality using AutoMapa but encountered problems with satellite detection after switching to iGO. Suggestions include checking the sys.txt file for the correct GPS port and baud rate settings, as well as potential conflicts with the factory navigation software blocking the GPS port. Follow-up messages indicate attempts to configure COM ports and baud rates without success, leading to further inquiries about proper settings to restore GPS functionality.
