Best 55-inch TVs under PLN 2,500: Samsung UE55MU6172, UE55NU7172, TCL LED 55C7026 Comparison
poltek81 3213 11
Which 55-inch TV should I choose under PLN 2,500: Samsung UE55MU6172, Samsung UE55NU7172, or TCL LED 55C7026?
The Samsung UE55NU7172 is the safest choice from this group, and one reply explicitly says to bet on the NU71 series [#17433508] The UE55NU7102 and UE55NU7172 are from the same TV series, so the picture will not be different; the only noted difference is the DVB-S tuner [#17434024][#17434173] The TCL 55C7026 was confirmed to be 60 Hz, so it is not the higher-refresh option some buyers look for [#17433065][#17433129] If you need Android TV, the TCL C70 was suggested instead, but with the note that this model has no image liquefiers [#17433508] If you can add about PLN 300, another recommendation was the Sony KD-55XE7005 [#17433058]
  • #1 17433029
    poltek81
    Here I have what I chose but please give your suggestions in advance, thank you for your help :)
    SAMSUNG UE55MU6172 4K UHD Smart TV
    SAMSUNG UE55NU7172 TV
    TCL LED 55C7026
    Ronin64
    Help: 248
    Rate: 349
    Check what refresh rate TCL has, 60Hz or 120Hz.
  • #4 17433129
    poltek81
    Certainly 60Hz
  • #5 17433508
    Ludwik XVI
    Help: 1325
    Rate: 788
    I would probably bet on NU71, and if you need android tv, you can take TCL C70 (only this model has no image liquefiers)
  • #6 17433765
    poltek81
    I have another Or maybe this model
    Samsung UE55NU7102 but what is the difference? SAMSUNG UE55NU7172 price for sure.
    Ludwik XVI
    Help: 1325
    Rate: 788
    The picture won't be different, it's the same tv series.
  • #8 17434053
    poltek81
    It doesn't make any difference between these tv ???
    Ludwik XVI
    Help: 1325
    Rate: 788
    differs in tuner dvb-s. one has the other is gone.
  • #11 17435034
    poltek81
    I have already chosen I am buying the SAMSUNG UE55NU7172 TV, thank you all for your help :)
    Ludwik XVI
    Help: 1325
    Rate: 788
    Write after purchase as impressions. This will help other buyers, especially since it is a very popular model.
The discussion centers around selecting the best 55-inch TVs under PLN 2,500, specifically comparing the Samsung UE55MU6172, UE55NU7172, and TCL LED 55C7026. Users suggest considering additional models like the Sony KD-55XE7005 and Philips 55PUS6262. The refresh rate of the TCL model is noted to be 60Hz. The Samsung UE55NU7172 is favored for its features, with a follow-up confirming the choice of this model. Other alternatives mentioned include TCL 55C7006, Hitachi 55HZT66, and Toshiba UC78. The discussion concludes with a request for feedback post-purchase to assist future buyers.
TL;DR: 55-inch options cluster around PLN 2,199–2,599; "All with package" deals were noted. This FAQ clarifies NU71 vs C70, DVB‑S, Android TV, and 60Hz to help you buy under PLN 2,500. [Elektroda, Anonymous, post #17434203]
Why it matters: It quickly resolves model confusions so you don’t overpay or miss key features like DVB‑S or Android TV.
What’s the best 55-inch TV under PLN 2,500 from this thread?
Community advice favored the Samsung UE55NU71 series for balanced value. As one expert put it: “I would probably bet on NU71.” If you prefer Android TV, consider TCL C70 instead. Match the OS and features to your habits and inputs. [Elektroda, Ludwik XVI, post #17433508]
Is the TCL 55C7026 a 60Hz or 120Hz panel?
It’s 60Hz. The refresh rate was checked in-thread and confirmed with, “Certainly 60Hz.” For everyday TV and streaming, that is adequate. Gamers seeking extra motion clarity may want 120Hz, if budget allows. [Elektroda, poltek81, post #17433129]
What’s the difference between Samsung UE55NU7102 and UE55NU7172?
Only the DVB‑S satellite tuner. One variant includes it, the other does not. Edge case: choose wrong and satellite channels will not work. Always verify the tuner spec before checkout, especially with retailer-specific suffixes. [Elektroda, Ludwik XVI, post #17434173]
Will picture quality differ between NU7102 and NU7172?
No. “The picture won’t be different, it’s the same tv series.” Expect similar image characteristics across both suffixes. Choose based on tuner needs, not panel differences. Panel capability and processing remain aligned within the series. [Elektroda, Ludwik XVI, post #17434024]
Does TCL C70 have Android TV, and does it use motion smoothing?
Yes, TCL C70 provides Android TV. It also omits motion smoothing; the thread notes it “has no image liquefiers.” Many viewers prefer this to avoid the soap‑opera effect. If you like ultra‑smooth motion, test first. [Elektroda, Ludwik XVI, post #17433508]
Should I stretch the budget by PLN 300 for Sony KD‑55XE7005?
One member suggested adding PLN 300 for the Sony KD‑55XE7005. Decide if the extra cost fits your needs and budget. Check availability and bundle value before committing. [Elektroda, Pedros050, post #17433058]
What other sub‑PLN 2,600 options were mentioned with bundles?
Listed with packages: Philips 55PUS6262 (PLN 2,199), TCL 55C7006 (PLN 2,550), Hitachi 55HZT66 (PLN 2,499), TCL 55P6046 (PLN 2,299), Thomson 55UC64 (PLN 2,299), and Toshiba UC78 (PLN 2,599). Availability varies. [Elektroda, Anonymous, post #17434203]
Which TV did the original poster finally buy?
The buyer chose the Samsung UE55NU7172. That outcome reflects the thread’s leaning toward the NU71 series for value. Post-purchase impressions were requested but not yet posted in the thread. [Elektroda, poltek81, post #17435034]
Do we have post‑purchase impressions from the buyer?
Not yet. A member asked, “Write after purchase as impressions,” to help future shoppers. Check back later in the thread or request an update. [Elektroda, Ludwik XVI, post #17435652]
For Android TV apps, should I pick Samsung NU71 or TCL C70?
Pick TCL C70 if Android TV is a must. The advisor noted it as the Android TV path among the compared models. Also remember it lacks motion smoothing, which some prefer. [Elektroda, Ludwik XVI, post #17433508]
Does 60Hz vs 120Hz matter for sports or gaming?
Yes. A 60Hz TV displays up to 60 frames per second, fine for most TV. 120Hz can reduce motion blur and judder, especially with fast sports and games. Gamers on 120fps consoles benefit from 120Hz support. Check the panel spec before buying. [“TV Refresh Rate: 60Hz vs 120Hz”]
Are NU7102/NU7172 suffixes mainly about tuners and region?
In this series, the key difference flagged is the DVB‑S tuner. Suffixes can reflect regional or retailer variants. Confirm the tuner you need to avoid missing satellite reception. [Elektroda, Ludwik XVI, post #17434173]
