Choosing the Best Model: Baofeng UV-5R vs UV-6R - Radio Comparison & Tips
Myrcik79 20307 10
What is the best Baofeng radio choice between the UV-5R and UV-6R?
There is no meaningful difference between the Baofeng UV-5R and UV-6R, so choose the one you like more; if you want a direct pick, the UV-5R is the safe choice [#17187433][#17189391] One user also suggested looking at the Baofeng GT-3TP instead because it has a nicer housing, selectable 1/4/8W output, and can use either an 1800mAh or 3800mAh battery [#17189833][#17191387] The 1800mAh battery was reported to last about 5 scanning afternoons, around 6 hours of continuous talk at 1W, over 1.5 hours at 4W, and under 1 hour at 8W [#17191387] A programming cable is recommended because some settings can only be changed from a PC, such as memory names, SKIP, and the startup display text [#17191387]
  • #1 17187427
    Myrcik79
    I want to buy a radio but I don't know which model is best to choose?
    Baofeng UV-5R or UV-6R
  • #2 17187433
  • #3 17187438
    Myrcik79
    cristal2242 wrote:
    The one you like more, all the rest without a difference ...
    I like the UV-6R more
    Only there is no larger battery and this 1800mAh I don't know how long it will last.
  • #4 17188194
    Jap
    Help: 114
    Rate: 654
    and take a look at the Baofeng GT-3TP (not to be confused with UV3R). It is in a much cooler housing, has a power of up to 8W, it is possible to install a huge 3800mAh battery. The only thing to replace is the antenna - the original is quite poor. The Nagoya NR771 works EXCELLENTly.
    I had some equipment from China - generally Wouxuny are nice. The coolest, however, was Zastone ZT2R - because it was really Yaesu VX2 - and it was not burdened with typical inconveniences of Chinese equipment based on the SDR receiver.
  • #5 17189072
  • #6 17189250
    Myrcik79
    More 8W power means faster power consumption and no noticeable increase in range to 5W.
    771 they went crazy with these anenes ? buy only the original fake acts as the original cat's tail.
    Woxuma's fact as a colleague says nicely done.
    Well this radio looks great only if this price is worth just to have 8W.
  • #7 17189391
  • #8 17189833
    Jap
    Help: 114
    Rate: 654
    Sorki, I didn't know that 36PLN plays a role here
    GT3TP around 140 PLN with delivery
    https://www.ebay.com/itm/Baofeng-GT-3TP-Mark-...Power-1-4-8W-Two-Way-Radio/261348037419?epid= 222544738 & hash = item3cd98e932b: g: MC4AAOSwI8laL0LP
    UV5R around PLN 104 with delivery - not much more from local distribution.
    https://www.ebay.com/itm/Baofeng-UV-5R-V-UHF-...-Dual-Dand-FM-Ham-Two-way-Radio/190835509376? hash = item2c6eaec880: g: iDYAAOSwAHBaBaZP
    To this day, I use Chinese nagoye 771 - and I do not know where my colleague cristal2242 concludes that they are bad ... I tested dozens of different antennas and somehow I did not notice that Nagoya 771 from China had worse parameters ... Maybe colleague cristal2242 give some examples / tests?
    I had both Bidafungi (and dozens of other trxes). I had GT3 in all versions from GT1 to GT3. I would never exchange for UV5R though the same radio inside. Housing, however, is a different level.
    Interesting facts - after sparring RX on militia bands between GT3TP and Yaesu FT8800 (12 times more expensive) - I sold the latter :)
  • #9 17190076
    Myrcik79
    I chose to buy GT-3TP
    only now the question is whether with 1800mAh or 3800mAh
  • Battery life and power tradeoffs on the UV-5R/UV-6R
    #10 17191387
    Jap
    Help: 114
    Rate: 654
    and it depends what you are going to do with this radio. From what I remember, the receiver walked a few afternoons (about 5) on scanning on a 1800mA battery - you can choose between transmitting 1, 4 or 8W. The battery has 13Wh - assuming that the radio needs 2x more power than it emits, it gives you about 6h of continuous talk with 1W, over 1.5h with 4W and below 1h with 8W. Surprisingly, these 8W sometimes saved me in mountainous terrain to reach the inverter. Communication was illegible with 4W.
    ps it is worth buying the version with the programming cable or do it yourself because some functions (as in most Chinese) can be set only with the help of PC (names of memory cells, SKIP function, or e.g. the inscription on the display when starting the radio.
  • Battery life estimates and programming cable advice for Baofeng radios
    #11 17191995
    Myrcik79
    So I'm taking 3800mAh
    Added after 11 [hours] 40 [minutes]:
    I bought
    Baofeng GT-3TP with a 3800 mAh battery
    + Antene nagoye 771
    + PC cable with board
    I already had a pear
    So this set will be cool.
    Thank you all for your help and advice because it is thanks to your entries that I made such a choice, so thanks again.
The discussion revolves around choosing between the Baofeng UV-5R and UV-6R radios. Users express varying preferences, with some favoring the UV-6R for its design but questioning the battery life of its 1800mAh capacity. Others recommend considering the Baofeng GT-3TP, which offers higher power (up to 8W) and a larger 3800mAh battery, although concerns about power consumption and range are noted. Users share experiences with battery life, suggesting that the 1800mAh battery lasts approximately 6 hours at 1W, 1.5 hours at 4W, and less than 1 hour at 8W. The importance of a programming cable for advanced features is also highlighted. Ultimately, one user decided to purchase the GT-3TP with a 3800mAh battery and a Nagoya 771 antenna, indicating satisfaction with their choice based on community advice.
