Choosing a Walkie Talkie for Urban Use: Baofeng BF-888s or Other Options Under 250 PLN?
mazbasi 9828 9
Can a pair of walkie-talkies reliably cover about 1 km in a built-up urban area, possibly indoors, within a 200–250 PLN budget?
For a built-up urban area and especially indoors, the BF-888S is unlikely to be the best choice, because walls, rooms, and cars cut the range heavily and the advertised "5 km" applies to open space [#16378847][#16378890] If you want a legal setup with the expected range, the replies point to PMR 446 MHz or CB 27 MHz; other frequencies require a permit [#16378894] One suggestion is to buy Baofeng UV-5R instead of BF-888S, since it offers much more functionality and was reported to work at 2–2.5 km in a large city, but it needs an additional radio license for PLN 30 to legally use PMR and the assigned FM band [#16378890] Another alternative mentioned is MaxCom WT207, which was said to work well up to about 3 km, with reception getting worse at 4–5 km [#16454021]
  • #1 16378756
    mazbasi
    Rate: 96
    Welcome,
    I would like to buy something mobile for communication at a distance of about 1km in a straight line, but the area is not open. It is a small town, blocks of flats etc. Will there be something in the budget, say 200 - 250 PLN for a set (2 items)? Can Baofeng BF-888s manage?
  • #2 16378847
    raptowny13
    Help: 22
    Rate: 50
    Do you want to talk inside the building or outside? Each room reduces range, the car almost completely suppresses it. This baofeng what you gave the link can and has these "5km" range but in open space. I own Baofeng UV-82 and the UHF band in the city is OK, I mean these 2-3 km only that it has 5W of power and for this you need a license.
    ASPOL
    Świątniki 61, Pabianice, 95-200
  • #3 16378890
    kałboj61
    Hello, my humble shame on the BF-888S, for 129 zlotys you have Baofeng UV-5R.
    Incomparable possibilities (including scanner)
    By purchasing an additional radio license for PLN 30 you are legally talking on PMR and the allocated FM band.
    Tested in a large city 2-2.5 km without any problems
  • #4 16378894
    sq9fmc
    Help: 129
    Rate: 406
    Devices without the required permit offering the expected range are only PMR 446MHz or CB radio 27MHz. Permits are required for other frequencies (devices), even if the seller assures that they are not.
  • #5 16380283
    mazbasi
    Rate: 96
    Only here is the price for one device, and here for two. ;)
    But thank you for the answers. It would be nice to be able to talk inside the building. According to geoportal, the distance is about 860m.
    Where can I read about this permit for PLN 30? Is it a one-time fee or a monthly / annual subscription?
  • #7 16381051
    Hektar Zahler
    Help: 230
    Rate: 528
    At the moment I see four ads:
    - Auoradia 158.375MHZ 448.125MHz
    - Avanti 158.100MHz 448.825MHz
    - HamRadioShop 157.9625MHz 448.1125MHz
    - NAVCOMM 157.9625 MHz 448.6375 MHz
    The permit entitles you to use the radio only on the assigned frequency.
    There are two nationwide channels (VHF channel plus UHF channel).
    Radios are manual and max power 5W.
    Two correspondents are two callsigns - that means two permits.
  • #8 16454021
    ratio_b
    I recommend this product: MaxCom WT207. Works well in any terrain and weather, even in the mountains there is a good range, and convenient to use. Up to 3 km, excellent reception, within 4-5 km deteriorates.
    RATIO Andrzej Pstrusiński
    Friedleina 4-6/122, Kraków, 30-009 | Tel.: 12 XXX-XX-XX (Show) | Company Website: http://ratio.pl
  • #9 16705402
    Hektar Zahler
    Help: 230
    Rate: 528
    Welcome back.
    In response to user inquiries, I am supplementing the list with a list of radios for broadcasting today.
    I immediately say that this is not surreptitious advertising, but undoubtedly an expression of personal support for conducting such an activity that allows amateurs of all sorts for a small fee and in a legal way to connect over longer distances than, say in the PMR band, a number of benefits unlike others devices such as extending the time the radio is left to sleep, etc., etc.
    Two-way radios Autoradia.pl and link to page - link
    Baofeng UV-82
    Baofeng UV-5R
    Wouxun KG-669E
    Wouxun KG-699E
    Wouxun KG-833
    Wouxun KG-929
    Wouxun KG-889
    Wouxun KG-UV899
    Wouxun KG-UVD1P
    Wouxun KG-UV2D
    Wouxun KG-UV6D
    Wouxun KG-UV8D
    Wouxun KG-UV8D (Plus)
    Wouxun KG-UV9D
    Wouxun KG-UV9D (Plus)
    Two-way radios Avanti and link to page - link
    Baofeng UV5R
    Baofenh UV-82
    Baofeng UV-8HX
    Baofeng T57
    Baofeng WP9700
    HYT TC610U
    HYT TC620U / V
    HYT TC610V
    HYT TC780U / V
    Icom IC-F2000D
    Icom IC-F1000 / S / T / D
    Icom IC-F2000 / S / T
    Abell A-511 VHF / UHF
    Abell A-80 VHF / UHF
    Abell A-600 VHF / UHF
    Abell A-510T
    Recent RS-208D
    Recent RS-618D
    Recent RS-628D
    Two-way radios HamradioShop and link to page - link
    Baofeng UV-5R, UV-5RA, UV-5RB, UV-5RC, UV-5RE
    Baofeng UV-3R, UV-3R Plus
    Kanwee TK-928 UHF
    Kanwee TK-928 VHF
    Zastone ZT-V68
    Zastone UV-8A Plus
    Zastone ZT-2R
    Baofeng UV-82
    Two-way radios Navcomm PR1 and link to page - link
    TK-750
    TK-750MKII
    TK-760 and TK-890
    NC-900
    NC-33M
    Two-way radios Navcomm PR2 and link to page - link
    TK-750
    TK-750MKII
    TK-760 and TK-890
    NC-900
    NC-33M
    At the same time, it can be seen that currently there are four channels on the last list.
  • #10 16741018
    |bst|
    Help: 7
    Rate: 54
    On Chinese portals you have baofengs even for ~ 50 PLN (PMR) e.g. BAOFENG BF-999S
    or other with a mini antenna.
✨ The discussion revolves around selecting a suitable walkie-talkie for urban communication within a budget of 200-250 PLN, specifically considering the Baofeng BF-888s. Users highlight that while the BF-888s claims a range of 5 km, this is only achievable in open areas. For urban settings, especially in buildings, the range is significantly reduced. Alternatives like the Baofeng UV-5R are recommended for their superior capabilities, including a scanner, and a legal radio license can be obtained for 30 PLN to operate on PMR frequencies. Other options mentioned include MaxCom WT207, which reportedly performs well in various terrains. Users emphasize the importance of understanding licensing requirements for different frequencies and suggest exploring additional models from Baofeng and Wouxun for better performance.
