[Solved] Fiat Seicento 1.1 - Difficulty Shifting into 1st & 2nd Gears: Clutch, Transmission Issues?
7812 5
  • #1 17188699
  • #2 17188797
    sagem173
    Rate: 8
    pillow chest whole? check move the engine hard see if it is flying.
    2. or with the brake in the floor, you hit 1 and push the clutch down. you shoot with impulse and the other person watches what is going on, if the whole engine is not flying from the gearbox
  • #3 17188825
    SKM 1964
    Help: 150
    Rate: 660
    I bet on broken synchronizers. I had such a case in the 900 hundred. I replaced everything, including the bearings. I was doing for myself. But such a repair is not worth it. :|
  • #4 17190311
    wichurewicz
    Help: 7
    Rate: 326
    The entire gearbox for this model is 150-200 PLN, of course used. If the floor is not rusting, the papers are fine and the general condition is satisfactory, you can look for a mechanic (the labor will be rather cheap, it's a Fiat and a simple model) and buy it.
  • #5 17190608
    SKM 1964
    Help: 150
    Rate: 660
    For two hundred, take it and assume it. Even the same as someone mechanic. :|
  • #6 17217932
